Gripping Threaded Rod
10,015
136
18
Posted in WorkshopTools
Introduction: Gripping Threaded Rod
About: i like to build stuff, mostly mechanical and some electronical. I study Aerospace engineer and i'm an electronical technician. I love to work with lathe and mill, and tool-machines in general. My native lang...
This is a simple trick to hold threaded rod in the vise or in the lathe chuck.
Este es un simple truco para agarrar varilla roscada en la morsa o en el plato del torno.
Step 1: Step 1
You need one or two (depending on how you want to hold the rod) nuts of the same thread of your rod. On each nut make a cut as shown in the pictures.
I use brass nuts because brass don't slip on hardened steel jaws.
Solo necesitas una o dos (depende de como se quiera agarrar la varilla) tuercas de la misma rosca que la varilla. A cada tuerca se le hace un corte como el que se muestra en las fotos.
Yo utilizo tuercas de laton porque no resbalan sobre mordazas de acero templado.
Step 2: Step 2
When holding the rod in the vise, make sure the cut is pointing upwards or downwards.
Cuando se utilize una morsa, asegurese de que el corte apunte hacia arriba o hacia abajo.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    18 Comments
    Simple, easy and functional, very good, as a tradesman this is one I haven't come across before. Keep up the good work
    Oh I doube and triple nutted threaded rod as other do in jobsites , but I think I like this better. If you use a threaded rod coupling you have a really long grip device. Always a place for a few of them in a tool box
    Really nice. Well done.
    clever trick...
    I either double nut the rod, or wrap it in a piece of leather. I keep an old boot tongue on my workbench for soft gripping items in vise jaws.
    Excellent. Thanks for posting this. I have tried, unsuccessfully several ways to stabilize threaded rod for cutting to size. Obviously, your approach is the way to go.
    muy buen truco, gracias por compartir :-)
    that's pretty cool. I have always doubled or triple nutted the rod. Some of my equipment requires a draw rod and they're not always available preassembled (drilled with roll pin thru a nut.) Thanks for posting this,it will make my job much easier now.
    thanks so much for sharing this trick!
    Excellent idea! Thanks for sharing.
    Ha so obvious! Thanks
    Amazing rick :D
    Really cool because the vice can't ruin the thread!
