Step 6Potting up
I use 16-ounce disposable plastic cups. These work well and are cheap.
Fill the cups with Miracle Gro Potting Mix or similar potting mix. I use Miracle Gro because it eliminates the need to apply fertilizer manually.
Use a pencil to make a hole in the center of the mix in each cup. The hole should be about 1 inch wide and 3-4 inches deep.
Choose the best seedlings to pot up, and discard the rest. If you pot up more than you can grow in your garden, just give away the extra plants when they are bigger.
Carefully loosen the seed starting mix around your chosen seedlings. Gently scoop out each seedling, being careful not to damage the roots or stem. Tap off excess mix from the roots so they will fit easily into the hole you made in the mix in the larger cups. Do this one at a time, and when a seedling has been uprooted, put it in the larger cup immediately.
Firm the potting mix around the roots and the stem of each seedling. Bury the stem all the way up to the cotyledon leaves - roots will grow from the stem and benefit the plant.
Label your cups with the variety name of each plant. I write on the side of the cup with a Sharpie.
Thoroughly water all the cups. Make sure you don't splash potting mix all over the seedlings when you water them.
When the seedlings are all potted up, put them under the grow light(s) and keep them within 4-5 inches of the lights.
Add Comment
