Grow Your Own Bioluminescent Algae by ScaryBunnyMan
Contest WinnerFeatured
You may have memories of running after fireflies with hands outstretched on a warm summer evening. You may have even watched some discovery channel documentary on the mysteries of the deep sea and marveled at those 'glowing' organisms featured. Chances are however, you probably haven't heard too much about the plethora of other bioluminescent creatures inhabiting this planet.
Bioluminescence (literally meaning living light) occurs within many living organisms, although, most are relegated to the deep sea. This chemical reaction involves the oxidation of Luciferin (just a name for a class of biological light emitting pigments). While related, the name doesn't come from any devilish origins, but rather the latin 'lucifer' meaning "light bringer".
Depending on the organism, the light can be used for camouflage, attraction, or even communication among bacteria to name a few. Some of the more notable organisms that bioluminesce include fireflies, glow worms, bacteria, a plethora of marine life, and even mushrooms. (Here's a favorite video of mine from planet earth on the glow worm http://www.youtube.com/watch?v=kBIEmjaoE5w)
Today however, we'll focus on a particular light emitting alga known as Pyrocystis fusiformis. These dinoflagellates typically do not occur in high enough concentrations among marine algae to produce a very noticeable glow. However, when the conditions are right (excess nutrients, enough sun, etc) an algal bloom can occur and populations explode.  Chances are you've heard of this phenomenon before which (albeit not involving this particular organism) is also known as a Red Tide.
Here's a video of one such concentration in a bay in australia. They are simply throwing water into the bay as the algae only luminesce when disturbed. A popular theory is that the light is used to attract predators of the grazers of dinoflagellates.  Case et al. (1995) demonstrated that the feeding rate of squid of mysids in the dark increases significantly when bioluminescent dinoflagellates are present.
There is even a bay in Puerto Rico full of the stuff which people can kayak in. http://www.biobay.com/
With a little luck and a LOT of patience, you can grow your own bioluminscent algae at home.
Step 1: Gather the Materials
A number of marine enthusiasts already grow phytoplankton at home for use in feeding various species of marine life. The method we'll use is rather similar.
To start, you need,
-A clear growing container (shallow containers with lots of surface area work best)
-Sea Salt
-A grow light and timer
-Micro Algae Grow
-A Starter Culture
Sea Salt: No, not from your pantry you gourmet fiend, you can get this at most pet or aquarium stores.
Grow Light: you can pick up a plant fluorescent and rack from walmart for ~$10.... Make sure you have a light timer.
Micro Algae grow: our most crucial ingredient. (besides the actual algae) There are a number of nutrient formulas people have experimented with, and truthfully, I've only had mixed results with this one. Experiment with what works best.
A Starter Culture: These can be obtained from a few places online. I recommend www.empco.org/edu
Step 2: Preparation and Mixing
Sanitation is necessary so your batch doesn't crash. After you REALLY wash out the grow container, make sure there is absolutely no residue left. Some people say swirl some diluted bleach around. Others say to stick it in the microwave after it's completely dry (won't melt or deform if it's dry... wet is another story). Choose your preference.
Additionally, sanitize the tubing if you're using an air pump, and anything else you're using to prepare this batch.
Mix up a batch of salt water. Use purified water as tap water can contain chlorine or other things that might kill your batch.
  Mix the salt to a 1.019 specific gravity (sg) concentration. Directions on how to do this are on the back of the package... you'll need a hydrometer if you've never done it before.
Add in ~ 1 ml of the micro algae grow. In this case, less is more. The solution you received the culture in should already have enough nutrients to support sizable growth. If you don't want to mess with making your own solution (not necessarily a bad idea) many places that sell starter cultures will also sell culture solution.
Let both the solution and culture bag sit in the same area out of the sun for an hour or two. This is simply to let them reach room temperature. A sudden change in temp during transfer could shock the culture enough to significantly harm it. If your room temp is in the 70s (F) , you should be okay. Ideally, the water should be around 22 degrees Celsius.
Finally, transfer the algae into your bottles. Attached is a picture of a grower's setup. (Your bottles won't be green though)
Step 3: Growth
These dinoflagellates need a constant cycle of light and darkness for optimal growth. Put your grow light and bottles in a dark place (closet) where you can strictly control how much light they get. Set the timer so the grow light is on a cycle of 12 hours on, 12 hours off. Don't be worried if your starter culture doesn't emit light right after you receive it. They will only bioluminesce in their night cycle, so plan the light cycles accordingly for when you want to see it.
Monitor your cultures for any sudden changes in color, and give them a gentle shake every day or so or all the sediment will collect to the bottom. If you have a successful culture, you will eventually need to 'split' the batch. Mix up another batch of saltwater/nutrients, and halve your culture between the new bottles.
Remember, these cool creatures will only brightly flash when disturbed and only during their night cycle. Too much disturbance can both harm them,and wear them out. They have a 'recharge' time so to speak between disturbances for optimal performance.
If you're looking for something which will constantly glow, you might want to check out bioluminescent bacteria instead. You can get some from Carolina Biological supply. Culturing this is a rather different process, but you can find some guides on the net. One bioluminescent strain is Vibrio fischeri.
The pictures on this page are not mine and are mostly from this site: http://www.biology.pl/bakterie_sw/bac_pict_en.html
Good luck and have fun!
1-40 of 205Next »
mindyindyindy says: Feb 28, 2013. 12:26 AM
How much light does the algae really need? I'd love to grow some but I don't have a place to keep them that I would consider more than "low light" and a lamp isn't really an option.
kcamilleri says: Dec 9, 2012. 9:26 AM
HI i need to buy the micro algae grow to try this experiment for a school assignment and when i tried to access this site: https://3kserver7.com/~frank/secure/agora.cgi it isn't opening an error is coming up. I would highly appreciate it if you could give me an alternative of from where to buy it. Thanks a lot
thecrazymagnetman says: Jun 14, 2012. 9:18 AM
i know one word to describe it, CREEPY
J.W.N.R. says: Mar 4, 2012. 11:09 AM
Won't the algae culture be stressed to death by the movement, if an air pump is installed in their container.
puerto-rico-rolf says: Nov 14, 2010. 3:04 PM
this algae is really awesome but unfortunately it refuses to grow! :-(
i ordered some pyrocystis fusiformis from empco and tried to make my own growth medium. i emptied fresh bottles of mineral water, filled them with destilled water and added sea salt until it reached a density of ca. 1025 kg/m3 (at 25°C). finally i added some nutritions. they are not the same as in the article since i had to buy them in germany, but they are f/2 as well.
unfortunately, in my mixed media, the algae dies within a single day! now, the empco starter culture is nearly empty and i really need some good ideas about what is going wrong.
could a lack of co2 let them die that fast? the starter culture is living for a month now in it's bottle without air pump and everything. what about salinity? it's not that sensible, is it? or maybe ph? is destilled water a good choice?
any ideas whats going wrong?!?
thanks a lot!
puerto-rico-rolf says: Apr 26, 2011. 1:04 PM
Now I got a new batch of algae from Empco and it's working fine so far! :-)
I changed a few things in the protocol: First, I used "Micro Algae Grow" this time.
Second, and I think this is important, I started each experiment with a small portion of algae and added only a little bit of growth medium every few hours. This is to avoid osmosis through a a sudden change in salt levels. This might have been the problem last time.
kmuelaner says: Oct 25, 2011. 5:32 AM
How much algae did you add to what quantity of water and how long did it take after diluting the algae for it to reach the same brightness?
puerto-rico-rolf says: Oct 25, 2011. 7:20 AM
The amount of algae was dependent on how much I had. Could be everything between a few tablespoons and half a bottle. And then I started adding water (with nutritions), but only the tenth part or something (sometimes only a few drops). Then gradually more. When I can be sure that both levels of salt are similar I put in a lot of water (like same amount as the algae itself).
I have the impression that my algae is growing pretty slow. It can takes weeks until it reaches the same density as before.
zbettinger says: Apr 25, 2011. 2:02 PM
Hi,
For one I agree with kholland, and remember its not the replication of the organisms environment that matters in these kind of experiments. What you are trying to achieve is growth of a species, so you want to achieve perfect conditions for growth, i.e. the perfect environment, not their usual one. So hell make a CO2 generator and make sure you use that algae grow! I'll be trying to grow the same species in a month or two so that's what I'll be doing as I've perfected growing freshwater algae with the method above.
Hope I helped,
Zane
kholland1 says: Apr 5, 2011. 7:36 PM
Long reply time, but the problem is your salt... you want 35ppt... I.e. 35 grams of salt for every liter of water.
I realize 1025 kg/m3 is the density of sea water, but, I think you will get better results measuring that way rather then doing it based on density....
Additionally, I wouldn't use distilled water, ideally, I would just get fresh water from a source (nearby streams, which will already have some salt) and then add salt to 35ppt.
boost-67 says: Jun 28, 2011. 10:54 PM
once grown, can this be used in a regular salt water tank?
flamekiller says: Sep 22, 2011. 9:54 PM
I don't see why not. They aren't going to hurt the fish since they likely coexist in the wild. I think the difficulty would be the day/night cycle and if there's any kind of constant agitation, they'd wear out or have a short lifespan.
imshanedulong says: Aug 12, 2011. 11:53 AM
I would also like to know this.
maliksudhir says: Aug 24, 2011. 11:48 AM
Hi ,
Can any one help me out in some calculation work its really very urgent , please help me out ..... i need to consume 1932.3kg/hr of CO2 with the help of Algae in a pond (water) for example Raceway pond , so i need to know the specific area to construct that pond and its sizing and dimension (length,etc) and the quantity of water needed and amount of algae used so that it easily consumes the mentioned amount of CO2 rate per hour..... please help me out soon you can also drop your suggestion and questions if any my email id is : sudhirmalik2011@gmail.com ....i will be waiting for your reply soon and i'll be highly thankful to you, if someone can help please do tell me its very urgent....
Thank you
Matt Carl says: Jul 18, 2011. 6:34 PM
Anyone else remember these from the book Deception Point by Dan Brown? Great book :D
puerto-rico-rolf says: Apr 26, 2011. 1:08 PM
One comment about the different species: I ordered all three from Empco. In my experience Pyrocystis lunula is the one with the highest density, which is much more robust than the others and by far the brightest. So I can highly recommend these!
zbettinger says: Jun 9, 2011. 6:23 PM
Congrats! And thanks for the suggestion, I'm ordering some now and wasn't sure which species to get
187inc says: Jun 10, 2010. 11:44 AM
i sail through red tide all the time. if you happen to be sitting on your boat at night in red tide, flush your toilet, the water is drawn from below the boat, water swirls around all blue while it flushes! haha i hear your not supposed to swim in it though, something about breeding plankton and ear infections. i cant remember. but hey, lets throw some in our bong and see what happens.
Sovereignty says: Dec 18, 2010. 4:39 PM
I'm rolling. I'm so happy right now.
NostalgicStone says: Jun 10, 2010. 1:01 PM
hahahaha
breakspeare832 says: Dec 15, 2010. 4:29 PM
I just want to buy some Pyrocystic Fusiform culture and use it for a simple science project. Is it absolutely necessary to grow them, or can I just use the flasks?
ScaryBunnyMan (author) says: Dec 15, 2010. 5:24 PM
You don't have to grow them... the cultures that you get when you buy them last a surprisingly long time
breakspeare832 says: Dec 15, 2010. 7:03 PM
Thanks, I was really worried that I was going to have to get all of the other equipment required. I will probably still just grow some for fun, but not for the project.
pyrosine says: Dec 5, 2010. 6:39 AM
If the algae only illuminates a certain amount, and then needs a recharge time - what happens when it rains? This is in the case of the giant bio-luminescent algae lakes
lazer155 says: Jul 19, 2010. 12:22 PM
How do you know when the culture needs to be split into another bottle? Does the water need to be cleaned every once in awhile?
Byron says: Jul 15, 2010. 10:50 PM
Any idea where I can get some bioluminescent algae in New Zealand
davej6694 says: Jun 26, 2010. 9:59 AM
sunnyside isn't picking up the phone and empco's phone goes straight to message machine is there any other place to buy this stuff?
TheSniper says: Jun 10, 2010. 11:06 AM
Hey, would it be possible to add these to a garden and to use a small pump, not very fast or violent, but just enough to get them to glow? I was thinking to let this go on at night to make a sort of display and add some vitality to the garden. Tell me what you think. Is it too much for the algae? Thanks!
newnoc says: Jun 17, 2010. 3:40 PM
Odd enough, i wrote about that in a short story! it sounds ok, maybe distribute it through a light sprinkler?
pyroman22 says: Jun 10, 2010. 8:39 PM
but what do I do with the other things growing in my closet.....
newnoc says: Jun 17, 2010. 3:37 PM
Ick...'tis gross! Seriously. XD
newnoc says: Jun 17, 2010. 3:35 PM
Can you possibly change the colors of the algae? Sounds cool...
conrad2468 says: Jun 12, 2010. 2:42 AM
well...at least youll know when you get infected by luminous bacteria.....
guatsamosa says: Jun 11, 2010. 7:44 AM
Hey, really awesome instructable!!! do you know if the algae reacts to vibrations that they feel through the water? as in could you make them light up with sound vibrations? thanks
ScaryBunnyMan (author) says: Jun 12, 2010. 2:23 AM
You certainly could, but it wouldn't last more than a few flashes. They need time to recharge between emissions and the speaker might disturb them too much.
Calorie says: Jun 10, 2010. 2:38 PM
It's fun to look at, but it causes chaos in the Gulf States. Red Tide blooms are caused by fertilizer runoff. A glut of aerobic bacteria occurs, which then dies off. This leaves a dead zone, in which the red tide blooms can grow. You end up with dead fish all over the beach, a horrible smell and a scratchy throat from the toxins it releases. It also kills bottom dwelling sponges. You can go to Tarpon Springs (FL) and ask a sponge diver. Nasty stuff. Don't get me wrong, I'll go to one of the boat marinas and throw in a rock or two and see how the light cascades away from the impact. But it is a serious problem in Florida. What you grow in your room won't hurt anything. the problem is the fertilizers we use on our lawns, waste discharge and and farm runoff.
astrong0 says: Jun 11, 2010. 2:20 PM
DAMN BRITISH PETROLEUM!!!!!!!
mandrayk says: Jun 11, 2010. 11:58 AM
oil?
Calorie says: Jun 11, 2010. 2:12 PM
I would make a smiley face, but what is happening in the Gulf is horrible. All of the Gulf States rely heavily on the Gulf for revenue. They suffered some of the hardest parts of the recession (Florida had the highest property foreclosure rate.) Florida also heavily relies on Tourism for its budget. The lack of taxes will cripple the recovery here.
*It's funny that you mentioned it though. We had a county meeting about banning fertilizer during the high rain months for run off. The argument from the industry representative was that all of the oil from the Gulf makes the fertilizer issue moot. I thought it was a bit sleazy.
mlocke says: Jun 11, 2010. 1:41 AM
"Empco EDU is currently closed for summer recess. We will reopen in September 2010."
1-40 of 205Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
