3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Grow Your Own Bioluminescent Algae
You may have memories of running after fireflies with hands outstretched on a warm summer evening. You may have even watched some discovery channel documentary on the mysteries of the deep sea and marveled at those 'glowing' organisms featured. Chances are however, you probably haven't heard too much about the plethora of other bioluminescent creatures inhabiting this planet.
Bioluminescence (literally meaning living light) occurs within many living organisms, although, most are relegated to the deep sea. This chemical reaction involves the oxidation of Luciferin (just a name for a class of biological light emitting pigments). While related, the name doesn't come from any devilish origins, but rather the latin 'lucifer' meaning "light bringer".
Depending on the organism, the light can be used for camouflage, attraction, or even communication among bacteria to name a few. Some of the more notable organisms that bioluminesce include fireflies, glow worms, bacteria, a plethora of marine life, and even mushrooms. (Here's a favorite video of mine from planet earth on the glow worm http://www.youtube.com/watch?v=kBIEmjaoE5w)
Today however, we'll focus on a particular light emitting alga known as Pyrocystis fusiformis. These dinoflagellates typically do not occur in high enough concentrations among marine algae to produce a very noticeable glow. However, when the conditions are right (excess nutrients, enough sun, etc) an algal bloom can occur and populations explode.  Chances are you've heard of this phenomenon before which (albeit not involving this particular organism) is also known as a Red Tide.
Here's a video of one such concentration in a bay in australia. They are simply throwing water into the bay as the algae only luminesce when disturbed. A popular theory is that the light is used to attract predators of the grazers of dinoflagellates.  Case et al. (1995) demonstrated that the feeding rate of squid of mysids in the dark increases significantly when bioluminescent dinoflagellates are present.
There is even a bay in Puerto Rico full of the stuff which people can kayak in. http://www.biobay.com/
With a little luck and a LOT of patience, you can grow your own bioluminscent algae at home.
Step 1Gather the Materials
A number of marine enthusiasts already grow phytoplankton at home for use in feeding various species of marine life. The method we'll use is rather similar.
To start, you need,
-A clear growing container (shallow containers with lots of surface area work best)
-Sea Salt
-A grow light and timer
-Micro Algae Grow
-A Starter Culture
Sea Salt: No, not from your pantry you gourmet fiend, you can get this at most pet or aquarium stores.
http://www.petsmart.com/product/index.jsp?productId=2754897
Grow Light: you can pick up a plant fluorescent and rack from walmart for ~$10.... Make sure you have a light timer.
Micro Algae grow: our most crucial ingredient. (besides the actual algae) There are a number of nutrient formulas people have experimented with, and truthfully, I've only had mixed results with this one. Experiment with what works best. You can get it here:
https://3kserver7.com/~frank/secure/agora.cgi
A Starter Culture: These can be obtained from a few places online. I recommend www.empco.org/edu
202 comments
1-40 of 202next »
Mar 4, 2012. 11:09 AMJ.W.N.R. says:
Won't the algae culture be stressed to death by the movement, if an air pump is installed in their container.
Nov 14, 2010. 3:04 PMpuerto-rico-rolf says:
this algae is really awesome but unfortunately it refuses to grow! :-(
i ordered some pyrocystis fusiformis from empco and tried to make my own growth medium. i emptied fresh bottles of mineral water, filled them with destilled water and added sea salt until it reached a density of ca. 1025 kg/m3 (at 25°C). finally i added some nutritions. they are not the same as in the article since i had to buy them in germany, but they are f/2 as well.
unfortunately, in my mixed media, the algae dies within a single day! now, the empco starter culture is nearly empty and i really need some good ideas about what is going wrong.
could a lack of co2 let them die that fast? the starter culture is living for a month now in it's bottle without air pump and everything. what about salinity? it's not that sensible, is it? or maybe ph? is destilled water a good choice?
any ideas whats going wrong?!?
thanks a lot!
Apr 26, 2011. 1:04 PMpuerto-rico-rolf says:
Now I got a new batch of algae from Empco and it's working fine so far! :-)
I changed a few things in the protocol: First, I used "Micro Algae Grow" this time.
Second, and I think this is important, I started each experiment with a small portion of algae and added only a little bit of growth medium every few hours. This is to avoid osmosis through a a sudden change in salt levels. This might have been the problem last time.
Oct 25, 2011. 5:32 AMkmuelaner says:
How much algae did you add to what quantity of water and how long did it take after diluting the algae for it to reach the same brightness?
Oct 25, 2011. 7:20 AMpuerto-rico-rolf says:
The amount of algae was dependent on how much I had. Could be everything between a few tablespoons and half a bottle. And then I started adding water (with nutritions), but only the tenth part or something (sometimes only a few drops). Then gradually more. When I can be sure that both levels of salt are similar I put in a lot of water (like same amount as the algae itself).
I have the impression that my algae is growing pretty slow. It can takes weeks until it reaches the same density as before.
Apr 25, 2011. 2:02 PMzbettinger says:
Hi,
For one I agree with kholland, and remember its not the replication of the organisms environment that matters in these kind of experiments. What you are trying to achieve is growth of a species, so you want to achieve perfect conditions for growth, i.e. the perfect environment, not their usual one. So hell make a CO2 generator and make sure you use that algae grow! I'll be trying to grow the same species in a month or two so that's what I'll be doing as I've perfected growing freshwater algae with the method above.
Hope I helped,
Zane
Apr 5, 2011. 7:36 PMkholland1 says:
Long reply time, but the problem is your salt... you want 35ppt... I.e. 35 grams of salt for every liter of water.
I realize 1025 kg/m3 is the density of sea water, but, I think you will get better results measuring that way rather then doing it based on density....
Additionally, I wouldn't use distilled water, ideally, I would just get fresh water from a source (nearby streams, which will already have some salt) and then add salt to 35ppt.
Jun 28, 2011. 10:54 PMboost-67 says:
once grown, can this be used in a regular salt water tank?
Sep 22, 2011. 9:54 PMflamekiller says:
I don't see why not. They aren't going to hurt the fish since they likely coexist in the wild. I think the difficulty would be the day/night cycle and if there's any kind of constant agitation, they'd wear out or have a short lifespan.
Aug 12, 2011. 11:53 AMimshanedulong says:
I would also like to know this.
Aug 24, 2011. 11:48 AMmaliksudhir says:
Hi ,
Can any one help me out in some calculation work its really very urgent , please help me out ..... i need to consume 1932.3kg/hr of CO2 with the help of Algae in a pond (water) for example Raceway pond , so i need to know the specific area to construct that pond and its sizing and dimension (length,etc) and the quantity of water needed and amount of algae used so that it easily consumes the mentioned amount of CO2 rate per hour..... please help me out soon you can also drop your suggestion and questions if any my email id is : sudhirmalik2011@gmail.com ....i will be waiting for your reply soon and i'll be highly thankful to you, if someone can help please do tell me its very urgent....
Thank you
Jul 18, 2011. 6:34 PMMatt Carl says:
Anyone else remember these from the book Deception Point by Dan Brown? Great book :D
Apr 26, 2011. 1:08 PMpuerto-rico-rolf says:
One comment about the different species: I ordered all three from Empco. In my experience Pyrocystis lunula is the one with the highest density, which is much more robust than the others and by far the brightest. So I can highly recommend these!
Jun 9, 2011. 6:23 PMzbettinger says:
Congrats! And thanks for the suggestion, I'm ordering some now and wasn't sure which species to get
Jun 10, 2010. 11:44 AM187inc says:
i sail through red tide all the time. if you happen to be sitting on your boat at night in red tide, flush your toilet, the water is drawn from below the boat, water swirls around all blue while it flushes! haha i hear your not supposed to swim in it though, something about breeding plankton and ear infections. i cant remember. but hey, lets throw some in our bong and see what happens.
Dec 18, 2010. 4:39 PMSovereignty says:
I'm rolling. I'm so happy right now.
Jun 10, 2010. 1:01 PMNostalgicStone says:
hahahaha
Dec 15, 2010. 4:29 PMbreakspeare832 says:
I just want to buy some Pyrocystic Fusiform culture and use it for a simple science project. Is it absolutely necessary to grow them, or can I just use the flasks?
Dec 15, 2010. 7:03 PMbreakspeare832 says:
Thanks, I was really worried that I was going to have to get all of the other equipment required. I will probably still just grow some for fun, but not for the project.
Oct 23, 2009. 3:53 PMpyrosine says:
If the algae only illuminates a certain amount, and then needs a recharge time - what happens when it rains? This is in the case of the giant bio-luminescent algae lakes
Jul 19, 2010. 12:22 PMlazer155 says:
How do you know when the culture needs to be split into another bottle? Does the water need to be cleaned every once in awhile?
Jul 15, 2010. 10:50 PMByron says:
Any idea where I can get some bioluminescent algae in New Zealand
Jun 26, 2010. 9:59 AMdavej6694 says:
sunnyside isn't picking up the phone and empco's phone goes straight to message machine is there any other place to buy this stuff?
Jun 10, 2010. 11:06 AMTheSniper says:
Hey, would it be possible to add these to a garden and to use a small pump, not very fast or violent, but just enough to get them to glow? I was thinking to let this go on at night to make a sort of display and add some vitality to the garden. Tell me what you think. Is it too much for the algae? Thanks!
Jun 17, 2010. 3:40 PMnewnoc says:
Odd enough, i wrote about that in a short story! it sounds ok, maybe distribute it through a light sprinkler?
Jun 10, 2010. 8:39 PMpyroman22 says:
but what do I do with the other things growing in my closet.....
Jun 17, 2010. 3:37 PMnewnoc says:
Ick...'tis gross! Seriously. XD
Jun 17, 2010. 3:35 PMnewnoc says:
Can you possibly change the colors of the algae? Sounds cool...
Jun 12, 2010. 2:42 AMconrad2468 says:
well...at least youll know when you get infected by luminous bacteria.....
Jun 11, 2010. 7:44 AMguatsamosa says:
Hey, really awesome instructable!!! do you know if the algae reacts to vibrations that they feel through the water? as in could you make them light up with sound vibrations? thanks
Jun 10, 2010. 2:38 PMCalorie says:
It's fun to look at, but it causes chaos in the Gulf States. Red Tide blooms are caused by fertilizer runoff. A glut of aerobic bacteria occurs, which then dies off. This leaves a dead zone, in which the red tide blooms can grow. You end up with dead fish all over the beach, a horrible smell and a scratchy throat from the toxins it releases. It also kills bottom dwelling sponges. You can go to Tarpon Springs (FL) and ask a sponge diver. Nasty stuff. Don't get me wrong, I'll go to one of the boat marinas and throw in a rock or two and see how the light cascades away from the impact. But it is a serious problem in Florida. What you grow in your room won't hurt anything. the problem is the fertilizers we use on our lawns, waste discharge and and farm runoff.
Jun 11, 2010. 2:20 PMastrong0 says:
DAMN BRITISH PETROLEUM!!!!!!!
Jun 11, 2010. 11:58 AMmandrayk says:
oil?
Jun 11, 2010. 2:12 PMCalorie says:
I would make a smiley face, but what is happening in the Gulf is horrible. All of the Gulf States rely heavily on the Gulf for revenue. They suffered some of the hardest parts of the recession (Florida had the highest property foreclosure rate.) Florida also heavily relies on Tourism for its budget. The lack of taxes will cripple the recovery here.
*It's funny that you mentioned it though. We had a county meeting about banning fertilizer during the high rain months for run off. The argument from the industry representative was that all of the oil from the Gulf makes the fertilizer issue moot. I thought it was a bit sleazy.
Jun 11, 2010. 1:41 AMmlocke says:
"Empco EDU is currently closed for summer recess. We will reopen in September 2010."
Jun 10, 2010. 9:04 PMeL3VEn says:
Have u considered growing them in a clear tube and attaching the sides of speakers to the ends of the tube, I don't imagine it to be very damaging unless your into metal.
Jun 10, 2010. 11:10 AMzascecs says:
I love this kind of stuff. Perfect for Halloween...
Mar 22, 2009. 2:42 PMDELETED_cholo71796 says:
(removed by author or community request)
1-40 of 202next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:ScaryBunnyMan
