3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Grow Your Own Musical Instrument - an environmentally-sustainable conch-substitute.
I have some friends living in a tank in my lab - Giant African Land Snails. Although ownership of GALs is illegal in the US, they make popular pets in the UK. Easy to care for, quite long-lived (an average of five years) and easy to breed they are also popular in schools.
Every so often, one dies. It's no big deal, they're only snails after all, and they lay hundreds of eggs a year if they're reasonably-well looked after. The only problem is what to do with the corpse.
I have found that the easiest way to deal with the body is to bury it for a few weeks and let minibeasts do their work. After that, it's only a matter of washing the shell out with plenty of hot water and a peg on your nose.
But what do you do with a slowly-growing pile of large shells?
Inspiration came in the form of CanDo's Conch Shell Horn Instructable.
Step 1What you will need
What you will need
As well as your donor shell, you will need something to cut and polish the shell. I used a rotary tool with a cutting disc and grinding bit.
You will also need eye-protection and preferably a dust-mask.
42 comments
1-40 of 42next »
Jul 24, 2009. 6:05 PMneverdrinkoliveoil says:
Is their any possible way to acquire one of these Great African Land Snail shells other than having a dead snail? ( I live in the U.S. by the way so I apparently can not lawfully have one of these creatures in my possession even if I wanted one.)
Jul 20, 2009. 9:34 PMmotleyjust says:
To help clean the shell after the mini beasts are done with it, try something I learned about that works with cow horns: Denture cleaning tablets. I would fill the horn with warm (not hot ) water and drop a tablet inside. Prop it upright and wait for it to quit foaming and rinse it out. Repeat until all the gunky suff is gone.
Feb 28, 2008. 1:41 PMLabot2001 says:
It sounds like a trumpet with a towel shoved in it =D
Lol, great Instructable. And, uh, no, I don't think it qualifies ;]
May 20, 2009. 11:59 PMtheelectrifier says:
you need a diamond blade to cut shells
Feb 28, 2008. 6:14 PMLabot2001 says:
Actually, it sounded a lot better than I'd originally expected it to. I'd originally thought that the natural twists and nicks and what all inside the shell would distort the sound something awful, but it really sounded pretty good. But the reason why I compared it to a trumpet is because it does sound like a brass instrument, but the tone is somewhat muffled. Good luck with the 2.0!
Jan 7, 2009. 4:51 PMmynameisjonas says:
the transition between the Flautist and you was almost seamless!
Nov 11, 2008. 5:34 AMsymeon says:
I would like to respectfully suggest that an alternative to the "moto tool" method of mouthpiece formation for Conch shells exists. I have done the whole job twice using a heavy stone. The shell does not react like a glass structure when breaking, so with carefull hitting, one can remove the 1-2 cm round, end of the conch. This will leave a pretty rough surface to put your lips on, but that can be taken care of by rubbing on a rougher stone surface or sandpaper, if you want to go that far into smoothing it. I'm not against Dremel et al. , but sometimes one has to work without noise and dust.All this I learned from my friend Ben Hume of NYC.
Aug 2, 2008. 5:19 PMUltraMagnus says:
hah, i have gotta get me some of those snails (and no, not to just make horns out of) I am beginning to wonder how long it will be before the UK gets hot enough for them to live wild thanks to global warming...
Nov 3, 2007. 8:09 PMjuicyjay says:
Lol, sounds like a baby seal being clubbed...
Jul 14, 2008. 2:10 AMcorey_caffeine says:
club sandwiches not seals
Oct 30, 2007. 7:54 PMleevonk says:
I like the tron background.
Jul 14, 2008. 2:09 AMcorey_caffeine says:
lol
Nov 13, 2007. 7:57 PMker-boom101 says:
i havve the same one or looks like the same one its made by de serres and i bought for a sale at like 8 bucks and i use it alot:p
May 10, 2008. 11:57 AMRmg12 says:
Nearly all cutting boards have measurements on like that.
Nov 1, 2007. 7:29 AMincorrigible packrat says:
The music reminds me of when I was growing up, the youngest of ten chilluns. At christmas time, after the presents was a wrapped, we'd play similar tunes on the tubes what the wrapping paper did come on (when not using them for lightsaber duels). We used a lot of wrapping paper. What I'm a wondering (being by no means a competent biologist) is if the wrapping paper tubes are a similar species to the snails. They both are constructed in spiral fashion, they makes a similar noise when blown into, etc. The main differences are one is made up of cellulose and the other is calcium carbonate. The wrapping paper tube is somewhat more convenient, having already holes on either end. Has anyone ever seen a live wrapping paper tube snail?
May 23, 2008. 5:20 PMpsychopathicdude says:
yes... but only very briefly.
Jun 2, 2008. 6:13 AMincorrigible packrat says:
Are they the snails that live at post offices and courier depots, that leave the little trails of horrible-tasting stickum, on the flaps of envelopes and the backs of stamps, that one lightly moistens with the tongue, for applicative adhesion?
Jun 3, 2008. 3:12 PMpsychopathicdude says:
Actually I was referring to the machine at a cardboard factory that makes the previously mentioned wrapping paper tubes... it looks kinda like a giant snail... ok, not really at all. :p
Jun 5, 2008. 9:27 AMincorrigible packrat says:
That would be a nifty process to see. There's a show called "How It's Made", that profiles all sorts of manufacturing processes. Fairly interesting stuff. The show itself is a tiny bit on the lame side though. Not sure if they've ever done cardboard tubes...
Oct 31, 2007. 2:50 AMkolrobie says:
Like most snails, they are an agricultural pests and they can carry some diseases from parasites on them like meningitis and salmonella, but regular snails can do that too. I think they're banned just on the agriculture aspect. I guess giant snail=larger destruction.
Jan 25, 2008. 12:27 AMalvincredible says:
dang i love how you have all this knowledge about in every comment you make. ahah
Jan 9, 2008. 9:42 PMjksloth says:
I used to manage a reptile store in Calif. in the 80's and I ordered one for myself in a store shipment. I kept it for a couple of months and I loved it. I named it Rex and fed it cut squash (lots of it). Then I got a call from the Fed. agriculture dept. They were trying to locate the last of six snails that were illegally imported into Florida and I was on the wholesalers invoice. Reluctantly, I gave them my snail and they destroyed it.(Sucked, didn't even get to keep the shell!) Apparently, the snails can reproduce asexually and if set free, a single snail can lead to the destruction of entire crops. Judging by the amount of damage the little nonnative escargot snails are doing in my own garden, I don't blame the government for being afraid of these hungry monsters. (But I still think it was a super cool pet!!!)
May 10, 2008. 11:56 AMRmg12 says:
cool. I hate snails, I think they are horrible, but I like these GAL. They had one in our school for years and then it died :'( we used to look at it in biology and it seemed quite clever haha, I did weird things with its antennae. Cool instructable
Dec 12, 2007. 1:17 PMIamTheCreator says:
SOUND THE BIBLICAL GIANT AFRICAN LAND SNAIL HORN!!!!!! I FEEL A CRUSADE COMING ON!!!!!!!
Oct 31, 2007. 8:08 AMjessyratfink says:
What a beautiful song that was!
Oct 31, 2007. 2:20 PMzachninme says:
I know! I love the internets -- I get to listen to these songs in silence...
Oct 30, 2007. 4:52 PMJack Daniels says:
I too would like to know why they are illegal
Oct 31, 2007. 12:44 AMT3h_Muffinator says:
A risk of GiantAfricanLandSnailitis?
Oct 30, 2007. 7:02 PMtyeo098 says:
The elusive kiteman, seen in the wild...
Lol... that sounds like a dying crab more than a horn, but its cool, itll keep the geese away =P
Oct 30, 2007. 7:48 PMWeissensteinburg says:
*in my best crocodile hunter voice, referring to the video*
Crikey! Here we have the rarely seen on camera Kiteman. It appears that he is gawking (as it's called) his mating call! You can see it's eyes darting back and forth, looking for a kitewoman, in hopes that his call succeeded. Unfortunately, this specimen is an ugly brute...even by kite standards, and it's unlikely that he will attract any kitewomen.
... =p
Oct 30, 2007. 7:53 PMtyeo098 says:
Ouch.... That had to hurt...
Oct 30, 2007. 6:00 PM!Andrew_Modder! says:
doesnt that sound like a ....horn ?
Oct 30, 2007. 4:28 PMjoemonkey says:
awsome instructable, but i was wondering why are those snails illegal in the US?
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
831
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
