3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Grow Your Own Rock Candy
Looking for something sugary to satisfy your sweet tooth, and at the same time have something fun to fill your time?  Then try growing your own rock candy!  Often times seen at carnivals, fairs, or theme parks, this sucker will not only taste great, but you'll learn something in the process as well.  Once you try it, and you decide you want to branch out, try some new flavors!  It does take 3 to 5 days to grow, but the end result is a delicious treat that you can impress your friends with!
Step 1Ingredients
Ingredients
I guarantee you have all the ingredients needed to grow your own rock candy at your home already.  If you decide to get a little more experimental, you may want to take a trip to your local grocery store, they'll have everything you need!
Ingredients
1 Cup of Water
3 Cups of Sugar (not powdered, but then again I haven't tried it.)
1 Wooden Skewer (also known as a brochette in the cooking world.)
       If you don't have one, a piece of string and a paper clip will work.
1 Clothespin (I needed two because my glass had a wider rim than I expected)
       If you don't have a clothespin, a paper clip will work.  Or if you're using a string then a          toothpick would work.
1 Pan or Pot, and a stove
Fork or Wooden Spoon
1 Tall glass (A regular dinner glass will work, but do not use plastic or paper)
Those are all the ingredients you really need.  I used some other things as well, but that is because I had done it once before and wanted to try some new things.
1 Cookie sheet
2 Tablespoons of Vanilla
Aluminium Foil
67 comments
1-40 of 67next »
Jun 17, 2011. 6:45 PMJohnDeere312 says:
Love how you put some science into this! Very interesting!
May 16, 2011. 9:41 PMMomarabbit says:
Anyone have an idea how to make several at a time for a kids birthday party. If I follow above i would have to use a LOT of glasses. I can't think of how to go about this. Thank you in advance!
Mar 23, 2011. 8:47 AMCollarina says:
This only make one?
Aug 1, 2010. 8:04 PMObediah says:
It would only take a a little bit of effort to give the powdered suger version a test. Maybe it would work, maybe not. Failure is ALWAYS an option. Either way you learn something.
Aug 4, 2010. 5:13 AMSaturn V says:
Are you a Mythbusters fan?
Mar 13, 2011. 9:44 PMBUBBA RAY says:
i am
Aug 4, 2010. 7:04 AMObediah says:
definitely, it just seems that everyone is assuming that powdered sugar has starch, and that would make it impossible to grow rock candy. MB has taught me never to take public opinion as wise. $3 and 20 minutes of work and you have your answer, maybe you have something totally better.
Mar 13, 2011. 9:39 PMBUBBA RAY says:
this is a great project me and the family were doing it right now as i speak great idea
Mar 8, 2011. 4:39 PMShany120 says:
yummy!!!
Aug 24, 2010. 3:23 PMSaturn V says:
Mine isn't growing on the skewer, it's recrystallizing on the top. Why is this? The skewer was straight down the middle, 1 inch from the bottom.
Aug 26, 2010. 6:10 PMSaturn V says:
Ah. Now some is finally growing on the stick, but it's just a very tiny bit. Some of it's even growing on the glass. Darn variables!
Feb 15, 2011. 7:10 AMbeehard44 says:
decant it into a new glass when it grows in the side
you can break it up and eat the crystals
Feb 12, 2011. 4:10 PMbuild52 says:
sweet!!!!! I can't wait to make it.
Dec 18, 2010. 6:09 PMdramioneforinfinity says:
Instead of skewers, I use chopsticks.
Dec 8, 2010. 7:23 PMBoogieWipes says:
Nice Instructable I am going to make these some time.
Oct 29, 2010. 5:11 PMSagi says:
I like those for tea! In German tea stores you can buy ready-made baskets with some tea, a nice cup and some sugar sticks. Its a nice thing if you can make something like this all by yourself!
Oct 20, 2010. 4:00 AMmark_taner says:
try arenga palm (liquid) sugar ..... hmmm...
Aug 28, 2010. 10:11 AMmattbomb says:
were and what kind of flavoring can i use. and were can i find it
Aug 18, 2010. 3:26 PMJimmy Proton says:
ive had mine out for over 2 weeks and nothing has happened
Aug 21, 2010. 7:01 PMJimmy Proton says:
i didnt use any flavoring, i put as much sugar as i could, and i am using thick twine for it to grow on, ive noticed that the liquid is very thick and gooey, like the waters evaporating and leaving behind the sugar but it wont grow..nothing. maybe if i take the twine out and let the sugar thats soaked into it dry and harden then put that in there it mite grow
Aug 22, 2010. 7:36 AMJimmy Proton says:
i think i used sink water, maybe thats it
Aug 1, 2010. 3:39 PMHollyHarken says:
For flavoring try LorAn oils. Add them in after the boiling process. It would probably be best to add any flavoring including vanilla at that time. Otherwise you boil off the flavor! LorAn oils are made especially for candy making and can be bought in some craft stores depending on where you live. I buy mine through a local party supply store that carries cake decorating supplies. If you use the oils only use a drop or two as they are concentrated. Food coloring will work to color the candy. Put it in after the boiling process as well.
Aug 7, 2010. 5:21 PMjoemonkey says:
i always used Ammonia and Bleach. that makes the coolest colors.
Aug 10, 2010. 9:12 AMjoemonkey says:
just kidding. don't do that :)
Jul 29, 2010. 11:51 AMSchober says:
Technically speaking powdered sugar should still work. Because powdered sugar is simply regular sugar crystals broken down to one tenth of their original size, and the crystaline form of a mineral remains the same no matter the size; so the cryatals should form the same way on the skewer. As for the dissolving it should actually dissolve better than regular sugar because the crystals are so much smaller but, the sugar may end up clumping together so I would recommend sifting the sugar into the boiling water. You may end up needing less of the powdered sugar due to the fact that there is less air between the crystals. Then again, these are just my semi-educated guesses and have not been tested.
Jul 30, 2010. 10:20 AMtrmpt99 says:
Actually, I would not use powdered sugar, since most powdered sugar includes starches to help alleviate moisture issues.
Aug 18, 2010. 5:45 AMSchober says:
You could make your own powdered sugar. Either in a small electric coffee grinder, a food processor or a blender. Whatever you think has a sharp enough/ fast enough blade to pulverize regular sugar. There were no Ible's on the process so eHow provided the next best thing, here. Simply omit the corn starch and you have pure powdered sugar. If you're not going to use it quickly you will want to add the corn starch to prevent clumping. While this will not create perfect one tenth size powdered sugar, it will create a much smaller crystal possibly allowing them to dissolve better.
Aug 9, 2010. 9:48 AMThefireball says:
Why does yours look red and mine loioks yellow? Is it ok to be yellow?
Aug 3, 2010. 10:12 PMsuperscientist1 says:
Will someone please tell me how much rock candy this will make. And thank you in advance.
Aug 4, 2010. 5:12 AMSaturn V says:
It depends on how long you let it grow, how much sugar is in the mix, and probably several other things. There's no telling how much you'll get.
Aug 2, 2010. 12:29 PMLettucehead says:
What if you added kool-aid powder for flavor? That would be really good!
Aug 2, 2010. 10:10 AMbikerbob2005 says:
if you get the temp right with out burning the crap out of the sugar you can disolve about 10 pounds of sugar into 2 cups of water and still call it a liquid. if it cools it will stay a liquid because of a thing called latenent heat. this computer does not have a spell checker on it. go reasearch 1: carnot cycle 2: the laws of thyerdymonics 3:basic air condishoning rats i can not spell any way trust me ring the bell when it is cool and the crystals will form.:)
1-40 of 67next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:JBarker09
