Grow a square watermelon
 by watermelon
Contest WinnerFeatured
This is really, really easy to do. (Note: you may be able to use this technique to grow other stuff in the form of a square ( actually in the form of a cube) and apply the general idea to other shapes.)
Step 1: Materials and tools
You need 6, 8" square, 3/8" thick (or thicker) sheets of polycarbonate plastic. (Lexan)
You will need 4 gate hinges and 2 hinged clasps with flat head machine screws and hex nuts plus at least 8 or more 1" to 1-1/2" long, thin wood screws and possibly a 36" length of angle iron or aluminum angle (cut to 8" lengths to yield four pieces) if you have thinner polycarbonate, a power drill and hole saw, and a hand saw or power saw such as a jig saw.
Step 4: Trim the inset sides
Measure the width of the sheets and trim each side of the the inset sides by this width.
Step 5: Fasten sides
The edges of the inset sides will have to be trimmed the thickness of the poly you use so they can be inset and still keep the box square. Trimming these edges is probably the hardest step.
Drill pilot holes through edge of the left and right sheets into side sheets between them to accept the wood screws. Use 2 or more screws per joined edge. A piece of angle iron or aluminum can be used to beef up the corners if the polycarbonate you have is too thin. (If the poly is too thin, however, it may bulge.)
Step 8: Usage
Plant watermelons. As soon they begin to grow large enough to place them in the box with the stem through the slit and hole, do so. Remove when ripe.
Step 9: Addendum: How to grow a watermelon
How to plant your watermelon
Watermelons come in about 1,200 varieties worldwide, divided according to season and seed production. China is by far the worlds largest grower of watermelon. Growing time is from 70 to 85 days for all varieties and growing season begins when all danger of frost has past. Watermelons can be grown indoors anytime of year but require extra amounts of space and constant temperature between 80 and 85 deg. F.
Seeds for seedlings to be transplanted outdoors may be started indoors 3 weeks before transplanting outdoors. Seeds are planted one inch deep in groups of 3 and seedlings thinned to the best 1 or 2 for planting. You can use this method with peat or potting soil to start seeds indoors. Seedless varieties must be planted alongside seed producing varieties in order to pollinate and set the fruit.
Hills for single transplants are spaced 2 to 3 feet apart while double transplants are spaced 4 to 5 feet apart. Rows are spaced 7 to 10 feet apart.
How to tell when your watermelon is ripe
Use black plastic to cover the hills and rows and plant through the plastic. Drip irrigation is sometimes used sparingly in cooler climates.
Use a combination of the following indicators to determine when your watermelons are ripe:
1. light green, curly tendrils on the stem near the point of attachment of the melon usually turn brown and dry;
2. the surface color of the fruit turns dull;
3. the skin becomes resistant to penetration by the thumbnail and is rough to the touch; and
4. the bottom of the melon (where it lies on the soil) turns from light green to a yellowish color.
Many watermelons do not emit the proverbial "dull thud"when ripe. For these, the dull thud may indicate an over-ripe, mushy melon. The above indicators for choosing a ripe watermelon are therefore much more reliable than "thumping" the melon with a knuckle.
Source: University of Illinois Extension Service
1-40 of 243Next »
ant not aunt says: Aug 4, 2012. 4:39 PM
i bet you don't need all the hardware. you can probably use big rubber bands to hold the form in place.
kcls says: Jun 9, 2010. 2:10 PM
I can see it now- instead of a watermelon, grow a pumpkin in a cube shape. Then, carve a Domo-Kun face on it. Voila! Domo-Kun Jack-O-Lantern.
I've got dibs on the 'ible.
omnibot in reply to kclsJun 9, 2010. 2:16 PM
Do it!
kcls in reply to omnibotJun 9, 2010. 2:22 PM
Gotta wait until I have a garden to grow it in! Living on a boat and all, I don't have a very big yard :D
ant not aunt in reply to kclsAug 4, 2012. 4:26 PM
you don't need a garden i grew a pumpkin in a large pot and trained the vine to a railing. when fruit formed i used pantyhose to support the weight.
Hiroak in reply to kclsJun 9, 2010. 3:55 PM
I'm on a boat Motherfu Ha ha very orginal I know I lived on a boat, the sail type for 2 years and build floating garden boxes out of blue foam board. I had a slip larger than my boat so I just attached them to the dock. Then I got a bigger boat and build two above ground planter boxes on the deck. I even tried to grow an orange tree, to combat the scurvy but I live in Alaska.
corey_caffeine in reply to kclsJun 9, 2010. 3:01 PM
you do, it's just REALLY flooded
aseaheru in reply to corey_caffeineJan 2, 2011. 1:37 PM
put it on the mast head. o_0
xenor in reply to corey_caffeineJun 9, 2010. 10:50 PM
So... rice?
aseaheru in reply to xenorJan 2, 2011. 1:39 PM
salt water.......o_0
corey_caffeine in reply to xenorJun 10, 2010. 1:31 AM
exactly
Nukeman says: Jul 10, 2012. 12:55 PM
The Lexan to build this costs about $80. Will plywood work?
GreenMeUpScotty says: Jun 4, 2012. 6:14 PM
Does the Box have to clear and made out of plastic?
myakka says: May 26, 2012. 5:35 AM
How about triangular( pyramid) shaped ones. Or dodecahedrons!
myakka in reply to myakkaMay 25, 2012. 10:40 PM
Or how about make the entire alphabet
kjohnson40 says: Oct 15, 2011. 5:35 PM
we grew a square honeydew (by accident) it was in a cement block we used to "fence" the garden with.
jameseyboy says: Oct 15, 2011. 10:27 AM
HELP barbies on the bbq
tinker234 says: Jun 19, 2011. 7:37 AM
wow i love this
moonchylde says: Jun 18, 2011. 7:29 PM
I wonder if this would work with tomatoes, or if the boxes would be too heavy for the vine to support. Another thought I had was two-liter pop bottles (watermelons with feet; they'd also be good for watermelon spikes :P), though I'm not sure if the fruit wouldn't split the plastic. I might experiment with this.
geoslim13 says: Mar 17, 2011. 8:51 AM
to quote Eurotrip "Gotta love that exchange rate!"
yiumanwan says: Jun 7, 2008. 10:48 PM
does it taste diffrent like sweetness
aseaheru in reply to yiumanwanJan 2, 2011. 1:38 PM
soil might change the taste, also chemicals, water, but thats all that might change the taste
Zaphod Beeblebrox in reply to yiumanwanDec 30, 2009. 6:41 AM
nope exactly the same exept shape
ReCreate in reply to yiumanwanOct 7, 2009. 3:29 PM
Wow how did you make large text??
Derin in reply to ReCreateNov 1, 2009. 2:26 AM
<h1>like this i guess</h1>
ReCreate in reply to DerinNov 1, 2009. 12:18 PM
Hmmm...no...
qballcat in reply to ReCreateMar 16, 2010. 4:44 PM
Hmmm....yes.  you just do it in the instructable, not on the comments.
axlrose says: Feb 22, 2008. 5:21 PM
That is so awesome how you can grow square watermelon and sell them for $82.00
bFusion in reply to axlroseJun 10, 2010. 5:22 AM
Yeah, but you have to live in Japan for that to happen. Everything, large fruit especially, is expensive over there.
aseaheru in reply to bFusionJan 2, 2011. 1:36 PM
1st of season/perfect are more expencive
awesomeman2468 says: Dec 26, 2010. 6:56 PM
in a historical note I believe this was started in china and in most recently the chinese made melons with the mascots from\for the bejing olimpics
indestructibleguy says: Jun 9, 2010. 6:18 PM
would it work with apples? then you would cut a small cube from inside an fill it with caramel and chocolate syrup... hmmm....
paperclip32 in reply to indestructibleguyJun 11, 2010. 8:33 AM
I think if you made this box and put a pipe on the middle,you'd have a holed fruit of which you can stuff.
indestructibleguy in reply to paperclip32Jun 12, 2010. 8:16 AM
will the fruit grow around it?
paperclip32 in reply to indestructibleguyAug 22, 2010. 8:17 AM
It should.I've seen Mickey shaped ones in Disneyland too.
chocogrape in reply to paperclip32Nov 14, 2010. 9:06 AM
I think those are regular apples with marshmallows for ears.
paperclip32 in reply to chocograpeNov 15, 2010. 4:10 AM
I said that further down.
hawkfrost64 says: Jul 22, 2010. 3:42 PM
you can use a cinderblock.
That Inventor Dude in reply to hawkfrost64Aug 26, 2010. 1:53 PM
genius
Kofoed says: Jun 22, 2010. 8:34 AM
god, that looks so cool :D
1-40 of 243Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
