Grow your own Magic Crystal Tree
Step 1Gather Your Materials
Gathering the ingredients is probably the most difficult step. To grow your Magic Crystal Tree, you'll need:
- Mrs Stewart's Bluing
- Table salt
- Household Ammonia (the kind with no soap added)
- Cardboard (not corrugated)
- Bowl
- Water
- Measuring spoon
- Food Coloring (optional)
The bluing is the hardest item to find but can be found in the cleaning section of many grocery stores. You can find the ammonia close by.
The cardboard I used came as packing material from a new shirt, or the backing from a paper notepad. Cereal box cardboard might work, but it's thinner & has printing on one side...
Depending on the temperature & humidity of your location, the ammonia is optional, but speeds up the crystal growth -- the tree in this Instructable started "sprouting" in less than an hour. Without ammonia, it may take a couple of days to start.
11 comments
May 2, 2010. 1:51 PMmuseumoftechno says:
Does the bluing do anything, apart from colouring the salt? Would the project work without it?
Thanks!
Nov 20, 2011. 4:51 PMggibbs2 says:
the bluing is a colloid aka the crystal seed you need it to grow the crystals it otherwise is just a mix trust me it doesn't grow a thing.
Dec 5, 2009. 1:58 PMOliver Larsen says:
So, it's a great instructable, undoubtly gonna try it. BUT, I'm from Denmark, and therefore I don't understand what "Bluing" is. Can you explain for a Dane?
Thanks.
Oct 24, 2010. 2:35 PMCamillaLuvzMusic says:
Denmark!! Me too!! Well no my mom is, dad isn't, i'm half-and-half!
Dec 20, 2009. 4:09 PMIronfounderson says:
It's a additive used to make whites whiter in the laundry.  It was quite popular years ago, but not widely used now.
http://en.wikipedia.org/wiki/Bluing_%28fabric%29
Dec 23, 2009. 8:50 AMOliver Larsen says:
Uh, I see. Do you think chlorine could be a good alternative?
Jan 10, 2012. 9:28 PMTANZMEISTER says:
DO NOT EVER MIX BLEACH WITH AMMONIA~!!!@!!!!
If you don't believe it from me, then read this.
http://chemistry.about.com/od/toxicchemicals/a/Mixing-Bleach-And-Ammonia.htm
Apr 10, 2010. 4:37 PMcdeerinck says:
 No, no, no!  Ammonia tries to evaporate, and will carry the chlorine with it.  I almost died once from breathing chlorine.  Probably the worst way imaginable to die.
Also, don't try bleach (another whitener), as mixing that with ammonia makes truly dangerous things.  Read here: www.bbc.co.uk/dna/h2g2/classic/A795611
Dec 23, 2009. 8:57 PMIronfounderson says:
No, I wouldn't think so.
Jan 12, 2009. 11:05 AMalienpsychomom says:
Do you think you might be able to use the cone styrofoam? The food dyes would certainly be absorbed. I will go ahead and try it unless you know why it would not. I will email you a picture of it if it turns out great. Thank you for the idea because I have grandkids that would it.
Feb 14, 2010. 1:02 PMskylane says:
 YEARS ago, my grandmother and I did this very same thing.
We used pieces of brick.  Made a little pile like a small mountain range.
Then the ''forests'' grew!!  Place drops of different colors of food coloring
in different locations for a multi color effect
Feb 8, 2010. 4:25 PMbriannamarie21 says:
uuuhhhgggh!!? i need your help.? my tree is taking forever to grow, help me, did i do something wrong? HELP! its a goood idea thoughh(:
Jan 7, 2010. 11:39 AMMissMush says:
Just though I would jump in here:  If you are trying to find the Mrs. Stewarts Bluing - check this list of all the stores in Canada/USA that stock it!!
http://www.mrsstewart.com/pages/wheretofind.htm
Nov 30, 2008. 11:40 AMk8monster says:
Hobby or art stores will sell a thin cardboard that us usually used to build working models... It's called chipboard
Mar 19, 2009. 4:57 PMfrogmama says:
Or ask a scrapbooker or a place that sells open-stock scrapbook paper. The OS paper comes wrapped with that as a stabilizer for packaging.
Nov 12, 2008. 1:30 PMDELETED_GuardianFox says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:mik3
