Step 3Plexi-Boxing
- - 1/8 inch thick plexiglass cut into six pieces in order make a box which will fit around your growing media (I was able to get some cut for me at the hardware store - the pieces used here are: 2@12"x10", 2@10"x19", and 2@12"x19").
- - 2 hinges (the ones I used are 2"x1 3/16" solid brass butt hinges and have 3 holes in each)
- - 26 small screws (round head, slotted #10-24 x 3/8" used here)
- - 26 nuts or nut caps (#10-24 nut caps used here)
- -10 L-brackets (1" are used here - 2 on either side of the back piece, 1 on each of the others, and one on each side of the left and right ends)
- - Some epoxy or other adhesive (I used marine adhesive) - I also used a neat little corner edging tool, but you don't really need it
- - A dremel or drill
Once you've got all that on hand, you'll just need to:
- Lay out your pieces and decide which will be the front and which will be the top
- Mark and drill holes for the hinges on both the front and the top. Making a hinged portion will allow for easier access to water the mushrooms, while still keeping them enclosed to prevent moisture loss.
- Mark and drill holes for the L-brackets.
- Assemble the box by affixing the pieces to one another with the L-brackets.
- Apply the glue/epoxy to the inside of the seams of the box and smooth it down.
- Screw the hinges onto the top and front pieces to affix the front of your fully formed box
- Find a dark and cool (dim and cool also works, but try not to have it too cold) area to house the box and get to growing your mushrooms!
| « Previous Step | View All Steps | Next Step » |
comments
Add Comment
shesparticular (author)
says:
Add Comment
