Growing Potatoes in Buckets
92,295
521
61
Posted
Introduction: Growing Potatoes in Buckets
Bucket Challenge
Runner Up in the
Bucket Challenge
New, fresh potatoes is a treat. Why not grow them yourself? You don't need a whole field, just a couple of buckets.
You'll need:
2 black buckets (potatoes dislike sunlight!)
a sharp knife
a speedmarker
something to make holes in the bottom of the buckets (I used a soldering iron)
soil
potatoes
Step 1: Preparing the Buckets
First you'll make some holes in the bottom of both buckets in order to drain the soil. It's important because potatoes can rot if there are too much water around them. Once done set one of the buckets aside. You don't need to do anything more with that bucket. This one will be the outer bucket.
Step 2: The Inner Bucket
I divided the bucket rim in 3 parts, 120° each. Then I draw a line vertical down the bucket (a). Then I draw 2 lines parallel to the first line 5 cm (2 inch) on each side of these (b). Then I meassured 5 cm (2 inch) from the top and the bottom and made 2 lines between the b-lines. On the picture I call them c-lines. Now cut out the rectangle made from the b- and c-lines. Finally you'll have a bucket with 3 windows like the one on the third picture.
Step 3: Planting Potatoes
Before I made the buckets I started sprouting the potatoes. First I place the inner bucket in the outer bucket. Then I fill the buckets half with soil. Now I place one potato right in front of each window half the way from the middle to the side of the bucket. Then I fill the buckets with soil, taking good care of the fragile sprouts. Finally I give the potatoes a good amount of water. The soil will pack around the potatoes, so it can be necessary to add more soil. Remember, potatoes must not get any kind of light, they'll turn green and become poisonous (produce solanine). Place the buckets in a light spot, but avoid direct sun. Give the potatoes enough water but don't let them soak.
Step 4: Harvesting
When the potato plant begin to bloom the first harvest is ready. Remove the inner bucket from the outer bucket and take the amount of potatoes you want. Spare the soil that falls out of the bucket. When finished, place the inner bucket in the outer bucket and place the soil back on top of the surface where you took the potatoes. The soil will repack around the rest of the potatoes. It can be necessary to add more soil, avoiding sunlight to the potatoes.
You can continue harvesting potatoes from the same plants until late autumn/early winter.
  • Just finished my buc...-SuzanneD12
    SuzanneD12 made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
59 Comments
What is the recommended time to wait for first harvest? 6-8 weeks??
I wait until the potato plants blossom. You can try looking after 6 weeks.
Remember you have to use food grade Buckets https://ertmania.dk/blog/207-dyrkning-af-kartofler-i-spande
Yes, if they are available in your country. But not all countries in the world have these buckets. And honestly I don't think it is that important.
Very cool instructable, and would like to try it out myself. Can you elaborate some more on the sprouting part, though? You don't say much about it. Thx.
All you have to do is let the potatoes sit in the dark, they will sprout all by themselves... I usually just save some from the last potatoes in the store bought bag. When you go to plant, just slice the potatoes with a couple of sprouts/eyes on each piece. By the way, you can also cover over the soil with straw or newspaper as the soil compacts to keep the light away.
Repeat repeat
Well, in the late winter the potatoes I use to consume start sprouting. I take the potatoes with the most vigorous sprouts and place them in old egg punnets and close the lids. In the dark the sprouts will develop, growing stronger until they are ready to plant.
Would this work with sweet potatoes too?
