Introduction: Growlight Bookshelf
No more hauling in your lights every spring, setting them up for a few weeks of seed-starting and then storing them the rest of the year. With the Mother Earth News Growlight Bookcase, your lights are ready whenever you need them. Then when you don't need all the shelves and lights for growing plants, you can use the unit as a bookcase. How-to books, healthy house plants and your favorite hot peppers will live happily together on the Mother Earth News Growlight Bookcase.
For more information on the Mother Earth News Growlight Bookcase, visit our website.
Step 1: Materials and Tools
You can make this shelf as tall and wide as you like, so measurements can vary, but here are the main components of the shelf:
2 4-foot, 2-tube fluorescent light fixtures
4 cool-white or warm-white fluorescent tubes
2 1-by-10-inch shelves
2 1-by-10-inch sides
3 1-by-4-inch valences
2 1-by-6-inch backboards
Screws or nails
I like to keep my carpentry projects as simple as possible, and you could build this one with just a handsaw and a hammer, if those were the only tools you had. Or just ask someone to cut the pieces for you.
The cuts will be cleaner if they're made with a power saw, and using screws and an electric drill will be easier and stronger than a hammer and nails. The curved cuts along the top trim and the bottom sides of the bookcase are optional. If you want to include them and have access to a saber saw or other way to cut them, they provide an attractive, ornamental touch.Step 2: Light Fixtures
To get started, first go to an electrical supply store and buy 4-foot, two-tube fluorescent light fixtures and quality cool-white or warm-white tubes. (You don't need to buy the much more expensive special lights designed for plants — the inexpensive standard tubes work fine.) You may also want to pick up a timer that will turn the lights on and off at whatever times you specify.
Step 3: Choose Dimensions
Once you have the fixtures, you can determine the length of your shelf, and how wide to make the valances (the boards that will cover the front of the fixtures). The shelves will have to be long enough to hold the fixtures, of course, but you can make them longer if you want, giving you more room for books even when the lighted section is being used for plants. You can also decide how high you want each shelf and whether you want just two shelves or maybe three or four.
Step 4: Lumber and Hardware
After you've chosen the dimensions you want, make a list of all the pieces and take it with you to the lumber store. One-by-10 poplar or pine boards probably will be your easiest and least expensive option, but whatever size and kind of lumber you choose, inspect each board carefully to be sure it's not warped or damaged.
While you're getting the lumber, shop for the hardware you'll need. To put the unit together, you'll want some 2-inch screws, plus a few short, fat screws to secure the fixtures under the shelves. Get a counter sink bit to drill the starter holes in the boards and scoop out space for the screw heads to set cleanly into the boards without splintering. Buy some fine grade sandpaper, and, if you don't already have one, I recommend a sanding block to hold the sandpaper and make sanding the boards easier.
Step 5: Prepare the Wood
After you have all the boards cut to length, mark and drill the starter holes, then sand each board until smooth.
Step 6: Put It Together and Apply a Finish
You may want to have someone help you when you're ready to screw everything together, especially if this is the first time you've built a project like this. Then, choose a finish. I used a cherry stain, covered with polyurethane to protect the wood from water spills. Follow the directions on the cans, and be sure to buy a good brush if you don't have a clean one at home.
Now, let it dry, plug it in and watch those little plants grow.
