loading
Step 5: Create a hinge
cut the middle third of one of the frames' seat tubes out. hold it back in place and shove the seat post down through the tube, holding in the middle third of tube while allowing it to rotate freely. This will be welded as in the picture, allowing the welded attachment to rotate.
AWESOME! This rack is outside of BICAS in Tucson. bicas.org Killer post.
Awesome idea. just make sure it's not easy to pull the sign out of the ground :)
nice use of part , may come in handy to build shelving and storage too,possible ny mounting the rear triangles to a wall . In ny are the frames are two thin, and would be cut too easy, same as any cable lock,hacksaw zip threw them. .<br>we just lock up to those sign poles, you have to make sure it is cemented in securely though. people set up traps, like like plugging up payphones and the return slot in the old days and sucking out the coins(yuck) check ther rigged pole for a bike that they can steal by pulling a pin out and lifting the pole off. Also if there are not signs securely on top , kids will stand on each others shoulders and lift the bike over the top, they will ,also will do it if there is too much slack in the chain or take off the signs in the bike is worth the work. 3 little kids like a circus act. .same with parking meters, i have heard people in the know, that will never lock up at a meter. i guess it is impossible to tell how tight the meter is threaded on. It may seem real secure ,but if they know a common street found device works like a wrench and applies torque, a tight meter will easily come off with a 6 foot extension. The original u locks were pried open by leverage by using the center piece of the he street closure or construction wood horses, it would just slide out at over 6 feet length of 4x6 of strong wood, pop a u lock in a second. The clear cheap ,old price 19cents round bic pens were the lock picks of the most $100 plus expensive locks with the cylinder pickproof// tumblers. <br>even some of the new nyc bike racks, that were bolted into the sidewalk were compromised in the first couple weeks,unknown to the unlucky bike owners.however the internet has been the best thing to fight bike theft, i am sure twitter and apps are around i don't know about yet. Passing info about weaknesses can be done in under a day, where in the old days it may take years before you found out there was a easy weakness in your lock. You may have been on your 3rd bike and still using the same krptolock that was the original problem. The smart thieves would leave the lock there, with the hasp inserted , so you would think you screwed up and didn't lock it properly, buy a new bike. lock up to the same pole, like when they steal your car battery and then your brand new battery the same week. <br>i saw a couple gps things at maker faire nyc that may be usable to follow bikes that are stolen. got to find a way to may bike theft a losing proposition. <br>
I like the idea to upcycle a bike to a bike rack.
About This Instructable
6,749views
20favorites
License:
More by dswaim:Faux Wood Cardboard Shelving Cardboard Kayak (part 1) Power Polished Ring Jig
Add instructable to:
