Step 4Using the Kit
iImage Information
First you have to twist the wires to be connected together. A good eletrical connetion is impartaive before you can solder. Next place the connection in the helping hand. I like to wrap the solder around the connection prior to heating. This makes the heating process very easy in the field and yields a great distribution of solder over the joint. Fold the joint over and heat shrink it. I couldn't have done it better in the shop.
Other than that, this is absolutely brilliant. I'm making a pen holder for use all the time.
1) Solder "Wick" isn't worth your money, a solder sucker IS!
2) Don't use a 60W soldering iron, get a 90W and you'll thank me.
3) Remember to use flux, if you don't already have flux core solder.
(If it smokes when you solder, it contains flux, if it doesn't really smoke to much or at all, then it's flux-less.)
And remember to put your shrink tubing on BEFORE you solder.... sounds funny to say, but you'll be surprised how many times you forget.....lol, memories!
It is compressed in the canister adopting its liquid phase. When the valve is opened, the gas expends and cools down (it's cold on your hand even though the canister is at ambient temperature). This allows for the liquid form of the gas for a little moment. Then it heats up, boils and takes its gas form.
