3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar A/B Switch
Guitar A/B Switch
This instructable covers how to make an A/B switch (designed for a guitar).
The whole instructable is split into three main sections:
Step 1 looks at my research and prototyping.
Steps 2-3 look at the simple switch – the basic concept which can be modified to fit many situations.
Steps 4-5 look at mounting the simple switch to a guitar - only a Gibson-style is shown, but others could be used.
Each main section will begin with the necessary equipment and parts for itself.
I hope you like it! Please feel free to comment!
Step 1Research and Prototyping
If you just want to get straight in to making it, check the intro for your pages. Otherwise...
First I decided to work out if I could connect two amps to the one guitar simply by connecting the cables. I had a very crude, but effective working test for this. The tips were all hooked up with the guitar lead in the middle and a bit of metal wire linking it to one amp lead on each side. This was on top of a lump of foil, which connected the sleeves of the connectors together in a similar fashion.
I tested that this definitely worked by plucking a string on the guitar, and turning one amp off at a time.
(I hadn't got the right equipment, so I had to postpone it at this point, and in that time I gained more equipment, knowledge and experience)
Next, I needed to find a way to switch between them. I tried connecting the sleeves directly and the tips through a SPDT switch. However, while this worked for whichever was active, there was feedback from whichever wasn't. After a tiny bit more testing, I discovered that the feedback didn't happen if the tip was connected to its own sleeve. I then decided to use a DPDT switch. I connected it up as shown in the diagram (A=Amp G=Guitar S=Sleeve T=Tip). I also connected all the sleeves together.
This worked, so on with the first part of the instructable!
The second part didn't really require any extra research.
The third part - the first footswitch. I looked into various types of switch and quickly discovered the existence of DPDT buttons . This erased any need for research.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:H4ZZ498
I love music (playing and listening to), computers (and all other electronics), DIYing anything I can, and (obviously) eating,
