3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Amp "power soak"
Guitar Amp \"power soak\"
Guitar players generally love tube amplifiers, especially when they are driven hard to get that nice, creamy tube distortion. Problem is, the amp will be friggin LOUD - even a small 15 watt amp can be too loud in certain applications. So, how do we get that overdriven tube sound without rattling the windows or destroying the ear drums of the people in the first row at our gig? We use a "power soak" device. This is essentially a load that is placed between the amplifier output and the speaker that reduces the signal to the speaker, but lets the amp drive hard. The trick is that the amplifier wants to see a constant impedance on it's output - in many cases 8 ohms - in order to transfer the correct amount of power. Just adding a simple resistor in series with the speaker won't work.
This Instructable will show you how to build a simple power soak for your low-wattage tube amp - basically any power level up to 25 watts into a 8 ohm load. Total parts cost is around US$15, and all parts can be ordered online from one source. I assume that you have basic soldering and wiring skills, and the tools to go along with that work.
Here we go...
Step 1Tools and Parts
Tools and Parts
You will need basic soldering and wiring tools such as:
  • Soldering Iron
  • Solder
  • diagonal wire cutters
  • wire stripper
  • long nose pliers
  • small wrench
  • screwdriver
The parts you need are as follows, and can all be sourced form Parts Express:
  • Mono L-Pad, 50W , 8ohm, p/n 260-255
  • 1/4" mono phone jack, p/n 090-321
  • 1/4" mono phone plug, p/n 093-140
  • Zip Cord wire, 18 gauge, 2 feet max length (it is sold by the foot), p/n 100-050
You will see that Parts Express sells (as of the date of this writing) three different L-Pads, a 15W, 50W and 100W. My particular application is for a Fender Pro Jr. amp, which can deliver 15W into 8 ohms. I chose the 50W L- Pad so that I can be sure it will never overheat. In general, always use power components rated at least twice what their actual power dissipation will be. (I learned this many years ago designing military grade power supplies)
13 comments
Apr 9, 2012. 2:53 PMstonykill says:
tell me about the longevity of this. Does it hold up? Or are you replacing it s lot? If yours has held up well, I plan on building one!
Dec 24, 2011. 1:39 PMreidhowland says:
My order from Parts Express arrived today, so I'm looking forward to putting Jr. through some paces this weekend. I'm confident this is going to work well for me. That said, out of sheer curiosity...
What exactly is the difference between something like this and say, a THD Hotplate--(features aside, obviously)? I guess I'm wondering, given that Hotplates etc. are sort of pricey, why hasn't anybody thought of this before? If I get a hundred-watt L-pad, will it tame my AC-30, or is that where the Hotplates etc come into their own?
Thanks for sharing your expertise with a bunch of guitar players!
Aug 6, 2011. 4:32 AMbmasschelein says:
Hi. Interesting instructable. I'm wondering if I could apply the same for my Peavey Vypyr 30W:
http://www.peavey.com/products/instamplifiers/guitaramps/vypyr/index.cfm/item/116751/Vypyr%26reg%3B%26nbsp%3B30.html
It's not a tube amplifier, but I have the same problem: when I enable distortion, it's hard to put the amp at an enjoyable sound level.
I guess I would need a higher-watt L-Pad, but would the overall idea work on this non-tube amp?
Dec 16, 2011. 7:17 AMjimmyjive5 says:
Hi,
While this will work fine, solid state amplifiers don't get the same sonic benefit from being driven hard that tube amps do. If it is sounding better at high volumes it may be more related to how the speaker itself reacts to the output then a factor of the amp being driven hard. Since the speaker will "see" the power that it does at lower volumes you may not notice a benefit.
Still for $15 it might get you what you want...
Nov 26, 2011. 5:41 PMbigkidalex says:
I have heard that this kind if setup is hard on tubes. Is that true?
Aug 3, 2011. 10:36 PMSideburnsBrent says:
I definitely need to make one of these for my setup. (Hopefully) quick question:
How would someone go about making one of these for a 300 watt 4ohm head ala. Ampeg SVT Classic?
Aug 6, 2011. 12:05 PMSideburnsBrent says:
Thank you r3son8tr! If you wouldn't mind me tapping your knowledge to be able to build one of these that would work for my setup I would be so grateful!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:r3son8tr
I'm a guitar playing electronics engineer...
