3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar FX by the DoomMeister
  • last photo ←
Hand built FX don't have to cost the earth, DoomMeister builds his own.
I don't think that I can add any greatly illuminating Instructables on building guitar FX pedals as there is more than enough very high quality sites out there with both step by step instructions and ready to cook PCB layouts. That's how most of my pedals were constructed. I may however at some point post some general thoughts on the process and also document my pedal board power supply.
So here are some of the pedals the DoomMeister has made both for his own enjoyment and for friends.
Edit - Some links to the best homebrew pedal sites
TonePad
runoffgroove
GeoFex
.CommonSound
15 comments
Dec 2, 2009. 6:39 PMginja_ninja says:
just had a thought while looking at this
if u find a basic effect pedle then u could just take it apart and place it in ur newly made cage for it
May 2, 2009. 9:30 AMtreemanklink says:
i am a beginner in this electronics thing and i can't figure out how to attach a 3 lug dc plug to the circuit, i know that one of the lugs is for battery and the other two are for wall power but i don't know how it should be connected
Sep 8, 2008. 8:14 AMdevinj says:
those are definitely the nicest looking home made pedals/stomp boxes that I've ever seen...makes me wish I could solder. do you happen to know anything about DIY loop pedals? I'm in a 2 member band and the ability to loop a keyboard or bass would make our sound a lot more full, and if at all possible I'd like not to spend $200+. so far the only DIY version I've come upon was a lo-fi looper using the equivalent of a yak-bak. I was also wondering if anyone knew how how to control live looping software (ableton live?) via a foot switch. again, awesome slideshow and if you ever do decide to make an instructable about DIY pedals it'd be most appreciated. it's always nice to see step by step photos rather than PCB layouts.
Apr 20, 2009. 1:26 PMhick252x4 says:
to trigger ableton you could use a usb controller like the things you see with the colored bottons they plug in to your computer and you can program it to trigger defferent sounds.
May 8, 2009. 4:22 AMquke says:
dude for a digital loop... I was thinking of hacking my sansa mp3 player... it has microphone input (which could be further hacked to allow for other types of input, 3.5mm jack, etc).. 2gb storage... and 3.5mm output.... all that really needs to be done is a bit of firmware hacking... and possibly minor physical alterations (depending on how far you want to go of course) could this work?... I've been searching but no one seems to see how cool they are... I'm a bit of a noob programmer (little bit of VB and HTML... nothing special) ... so if you know anything mate let me know yer? cheers
Sep 21, 2008. 7:47 PMfarbluestar says:
do you have a schematic for that power supply for pedals?
Sep 21, 2008. 7:44 PMfarbluestar says:
i built a simple distortion pedal last month based on site called instructables,it works it sounds good, for me well its good,when i play blues,because it sounds good when you play a blues to that simple distortion,but when i plug it this morning the sounds is different its like thinner distortion,its getting fading,but the the components was new,the chip its using a LM386 CHIP WITH A .01 CERAMIC CAPACITOR ON INPUT, IN THE OUTPUT ITS USING 220 UF ELECTROLYTIC CAP,WITH 4 DIODES 1N4148, IN A RESISTOR 47K AND A 100K between the diodes, ALL of these was new,for me its sounds good,the battery is okey,what is the problem, is this kind of distortion have a life so short, i was expecting it will serve for years,is these home made pedals have a short life span just one month, its waste of money.im disappointed,maybe its lack power filter what is the problem??i cant figure it out. i need an advice,you guys are only the one i could lend some help because you are a professional builder. thank you.
Mar 27, 2009. 9:35 AMvodo says:
and ware do you get all yor cases
Mar 27, 2009. 9:33 AMvodo says:
ware did you get the case on the ts808?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:doommeister
