Step 2Padding the switches
Take some double-sided mounting tape and cut out a hole for the switch actuator, making sure that it is not blocked or impeded in any way. I used an x-acto knife to make the cuts. Make sure that yours is new and sharp. The second picture below shows what the cuts will look like when the x-acto knife blade is worn and dull.
Cut some foam to size and adhere to the mounting tape. Make sure that the foam comes above the switch actuator, with about 1/4" to 3/8" clearance. It needs to provide just the right amount of resistance to strum bar rebound without interfering with normal gameplay. I used foam from a microphone shipping container and a worn and dull x-acto knife. Once again, I recommend new and sharp.
Reassembly, as usual, is the reverse of disassembly. Be sure to include the strap buttons in the first reassembly to avoid a second disassembly and reassembly.
Add Comment
