Step 3A high pour
Mix your silicone according to the manufacturer's specifications. For the OMOO the instructions called for equal parts of compounds A and B. Stir your mixture for at least a minute, making sure to scrape down the sides and bottom. Try not to whip bubbles into the mix by moving the stick in and out of the mixture.
One of the crucial factors in making a successful mold is making sure there are no voids or bubbles in your casting. This means you pour your mixture from high above the mold in a very thin stream. This stream will pop the large bubbles that would have been included in the casting. Start in one corner of the mold, and let it fill evenly to the other side. When you've poured enough that you can only see the top of your key, go in with the paintbrush, and make sure there's silicone filling up the small divits where the rubber bumpers were. Now you can fill the mold until your silicone is about 1/4" above the level of your key.
Add Comment
