Guitar Hero rocks, but it really needs some lights to liven up the virtual shredding.
What to do? Cram in some LEDs!
Step 1: Open it Up
Getting the two pieces off the back of the guitar is just a matter of taking off the 16 screws. There's one piece for the neck and one for the body. Try not to lose the screws, but we found that you can keep it pretty secure with only four of them.
Step 2: Remove the fret buttons
Undo the two little screws that hold the small board that has the real buttons on it. You should now be able to easily remove the five colored fret buttons.
Step 3: Make new fret buttons
We needed some translucent and tinted buttons that were the same size and shape as the original buttons. I was going to build the buttons with layers of frosted acrylic, but Matt insisted on a more professional technique of making a mold from the originals and casting completely new pieces.
To see how that was done, hop on over to Matt's Instructable on how he made the new pieces here.
Step 4: Drill out holes for the LEDs to go into
Now we need to put some holes in the new buttons that the LEDs can go into.
Check the height of the LED and you'll know how deep you need to drill. To make sure we didn't go too far we applied some tape to the drill bit. Just drill till you hit the tape and you're golden.
Step 5: Insert the LEDs
Insert the LEDs of your choice. We used 5mm white LEDs.
A dab of glue and the LEDs stay put.
Step 6: Bend the LED legs
The legs became the contact points and as such we needed to bend them into a very rough circular shape that would then be making contact for the circuit. We measured the gap between the LED and the circuit board and bent accordingly.
Step 7: Apply copper contact pads
On the circuit board we put on some copper tape that would become the contact pads for the LEDs. We put down two here, but in the end only used one for each LED for reasons that will become clearer soon.
The original design, that you see here, has the copper flat on the board, but after some testing we pulled the copper tape up on one side and folded that end under so as to make a very rough spring.
Step 8: Wire it up - part 1
All of these LEDs are to be run in parallel. These are run off of a simple coin battery of the type that come in the keychain LED flashlights, but for a more serious application we'd use a 9-volt and some resistors.
Here you can see the original plan for the wiring. Each set of five copper pads is wired together and the wires on the right in the photo go to the battery.
Originally, the LEDs were set up so that both legs would have to make contact to light up, but this was giving us erratic results. So instead one leg, and it doesn't matter which, gets soldered to the wires for a constant connection. This drops our possible points of failure and gives us more of a likelihood of seeing pretty lights.
Step 9: Wire it up - part 2
After testing out the original wiring plan we ran into the problem of there being too many points of failure. We were requiring that both legs of the LEDs be pushed onto the copper pads for the connection to be made. To fix this, one leg was instead wired to the pad below it. One of these is highlighted in the first photo, but the same thing was done to all of the LEDs.
In addition, the copper tape that the LED was still being pushed onto was too flat on the surface of the board. To create a very rough springiness we peeled up one side of the tape and crumpled it a bit or folded it under itself to make it a little thicker. It's crude and not a long-term solution, but it worked for the first run.
Step 10: Pack it all back in and play!
Put all the pieces back in their places, screw in the neck piece, and play. You'll want to hold off on putting the back of the body back on since odds are good that you'll be tweaking this setup a couple dozen times before you're happy with it.
When it all comes together, fire up some Guitar Hero 1, 2, or 3 (screw that 80s edition) and play!
Thanks to Matt for all the work and photos and Adam for the Guitar Hero playing.
1-40 of 229Next »
yaly says: Jul 5, 2011. 7:01 AM
you could search for the power pins on the connector between the guitar and the play-station and used them instead of the battery but be sure to use resistor(s) because the console gives any controller it uses 5volts.
spon-tan-ii-us says: Jun 16, 2011. 8:25 AM
GENIUS :D
babayaga2000 says: Feb 11, 2008. 10:43 PM
why did you use WHITE leds man, it would be so much better if youused color coordinating leds.i also dont understand yu had to make molds, you could drill a smaller hole and have he led shinethru the plastic. il make an instructable for a WII guitar soon
ZeroXL91 says: Oct 20, 2010. 3:52 PM
White ones of the same kind are eaiser to calculate the required resistor
whitish says: Mar 21, 2008. 4:44 PM
you could use the stock buttons but frosted and clear looks so much cooler.
mikeisawesome says: Jun 10, 2008. 2:50 PM
u cant make them clear really
Slagr says: May 10, 2009. 3:40 PM
strong enough LEDs would probably shine through, but it would be significantly inferior to the molding method.
mrshanko says: May 21, 2010. 9:00 PM
 Would this work for Guitar Hero for the DS?
zack247 says: Sep 27, 2010. 10:49 PM
it could, but it would be harder to do, since everything is much smaller
vvshende says: May 31, 2010. 8:02 PM
Maybe I missed it, or maybe I didn't understand it, but do the LEDs draw power from the already existing powersource or did you attach these to a battery? If they are attached to the preexisting powersource, what would you say would be the best way to attach them to a battery instead?
thirtyfivefox says: Jan 1, 2010. 1:44 PM
Hey i'm thinking that it might have been easier to board mount the leds and just relay the lighting off the boards buttons... can you think of any reason why this wouldn't work?  also do you notice any dimming of the buttons when multiples are held? since they are all on the same power supply?  Perhaps if its too noticeable you could up the battery and just use resistors in line... that way there is more voltage available for when two or three batteries are pressed.
Ravenous_Devil says: Nov 24, 2009. 5:07 PM
I am desperate for a wiring diagram for the ps2 wired sg controller, the hot glue that holds the 7 wires from the main cord down broke off, making the tiny solders break as well. do you know the pattern of the colored wires to the board, or could you look and post them to me. I can't afford a new one, and have the tools to fix it, just don't know the wiring pattern. Perhaps you have a diagram. Thanks alot.
MuGuFuTsu says: Oct 25, 2009. 11:47 AM
do you want to produce two pairs for me? plz xD
mhagen41 says: Nov 23, 2007. 8:40 PM
this is awesome! thanks! do you have any pictures of the battery that you hooked this up to?? im just wondering because i dont know exactly how to wire it up and what battery to use thanks
toastytoast10 says: Jan 26, 2008. 8:03 AM
well it seems to me that the top end of the wire, of this picture where the circuit board is on top would be the positive end, so attach that wire to the positive end of the 9volt. then the bottom would be then negative end, so attach it to the bottom wire to the negative end of the battery. if this doesn't work and you are sure you have done every thing else right, then switch the wires. It should work then
VTStevenVT says: Mar 30, 2008. 10:18 PM
Do you have to worry about adding resistors to a 9v battery? This may be a dumb question as I know absolutely nothing about electronics, but I did blow out the LED's I used on my last attempt at an LED project.
Slagr says: Jul 16, 2009. 11:11 AM
you will fry the LEDs if you run them on too high of voltage. My LEDs, 3.3-3.6 V, heated up and dimmed ominously when I ran 4.5 V (3 AAs) through them, and I'd imagine 9V would be catastrophic.
Arbitror says: Sep 15, 2009. 6:50 PM
They go super bright for 1 second, then slowly dim to nothing, they it emits smoke, and sometimes explodes in two.
zalcior says: Jul 8, 2009. 7:59 PM
Im not sure, use a resistor calculator with the voltage needed of the LEDs Running PARALLEL and for power source use 9v.
supermorph says: Jun 29, 2009. 9:49 AM
do u have a method that can take power from the usb?
smsspdh says: Feb 5, 2009. 2:30 PM
May I please have an estimate on the of the project(excluding the controller)? BTW awesome instructable
erictepe says: Jun 16, 2009. 10:48 AM
$80 or so: Molding silicone kit:$25 resin:$25 LEDs:$10 Copper tape:$13 Wire:$5 Solder:$5
Slagr says: Jun 16, 2009. 1:15 PM
and maybe $25 for resin dye I personally molded clear buttons and colored the LEDs with sharpies. It worked out quite well.
erictepe says: Jun 23, 2009. 9:29 PM
Slagr, how did you color the LEDs with sharpies. I tried and the ink does not stick.
Slagr says: Jun 25, 2009. 2:21 AM
are you sure they're sharpies you're using? Those things stick to everything.
erictepe says: Jun 25, 2009. 5:31 AM
Yea, the multicolor pack with like 8 sharpies. Oh well, I had actually purchased the resin dye and went ahead and casted colored buttons. I can run regular white leds in colored buttons off my power pack (3 aaa rechargables-3.6V) with out resistors. I actually have colored leds but really don't like the way the yellow washes out when red/yellow or yellow /blue is pushed. They are all pretty close in brightness but the other colors really over power it.
joel97 says: Jun 9, 2009. 4:12 AM
nice how long did that take
Slagr says: Jun 9, 2009. 12:37 PM
the button molding takes about 2 days for everything to cure properly, and the wiring shouldn't take any more than a day, depending on how much tweaking you have to do.
SethUchiha says: Jun 4, 2009. 12:16 PM
if only you had instructions on how to make a slider buttons light up on the WT controller
Slagr says: Jun 4, 2009. 1:19 PM
you could try splicing the LED circuit through one of the wires leading to the strip, but I don't see an effective way of getting it to work the way you'd want it to.
gblax123 says: Apr 13, 2009. 6:15 PM
The wii guitar has all of those grey things attached together... what can I do about that??
Slagr says: May 10, 2009. 3:31 PM
you could apply the copper over the rubber or (as a last resort) cut the spaces between the pads, making sure they can still spring back and still fit in place without moving.
Slagr says: May 17, 2009. 5:57 PM
I fixed this problem by taking the grey parts from an SG and hot gluing them onto the WT fretboard. The rubber part from the WT guitar fit into the SG as well, so both guitars still work. If you try this, make sure the contacts (those 2 dots what complete the circuit) line up between the rubber part and the board.
Thepage says: May 6, 2009. 5:00 PM
I know it would be hard but it would be cool if you made them all light and stay light up when you did star power.
Slagr says: May 10, 2009. 6:06 PM
the only way to have them stay lit would be some timing mechanism which may not be accurate due to varying SP amounts, or if you managed to wire it into the circuit that makes wiimotes vibrate during SP, but that would only be for Wii guitars. It would be fairly simple to have them light up when tilted by either wiring the LEDs through the controller's tilt sensor (if it uses the ball-in-cylinder type) or adding a new tilt sensor if it uses a more complex chip type unit.
Slagr says: May 11, 2009. 7:52 PM
here's a good tilt sensor for such a project: http://hackaday.com/2009/01/28/5-cent-tilt-censor/
I plan on trying this myself.
Bazzatron says: May 11, 2009. 12:14 PM
how about the rock band/world tour drum kit? if i get round to it ill post an instructable (be prewarned - i didnt check if someone has done it already...)
Slagr says: May 11, 2009. 7:48 PM
There are LEDs these days that light up by registering vibrations, and I'd imagine those would work well in the drums. I have some drumsticks with them, and the effect if pretty cool. I'd advise looking into it before I do. >.>
dave47561879 says: Mar 12, 2009. 12:58 PM
Does this work for rock band too? Please answer.
Slagr says: May 10, 2009. 6:17 PM
it would be nearly exactly the same as this (SG), but you'd have to put some electrical tape or something over the fret pcb between B and O before you put the copper tape on because the main fret wires could interfere with the LED circuit if you don't insulate them.
1-40 of 229Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
