Guitar Hero World Tour Drum Mod for Rock Band 2
I began my addiction to faux drumming on guitar hero world tour. Having recently tried the drum controller on rock band 2 I was less than impressed. I did not like having to use the green drum for the crash cymbal in rock band 2 when there is a perfectly good cymbal pad on the guitar hero drums. To remedy this I have installed a switch to allow the right cymbal on the guitar hero drum controller to control the green drum pad and allow you to use it as the crash cymbal in rock band 2. Confused yet? It is a very simple mod and allows a more natural integration of the guitar hero drum controller into rock band 2.
You will need the following:
-soldering iron
-solder
-wire (a relatively small gauge)
- 1 DPDT switchDPDT switch (radioshack part # 275-407)
-dremel rotary tool for cutting hole
Simple Schematic
Step 1Disassemble the drums
here is a view from the bottom of the controller after you have removed all of the screws (switch is installed here..will get to that shortly).
8 comments
Jun 24, 2010. 1:36 AMrickyA says:
Hey peoples i'm new to this site,I have been reading some of your fixes and i'm amazed how simple you all explain them. I have worked in the automotive electronics repair for nearly 20 years repairing the computerized systems. your directions and pics deserve the highest kudos possible
Aug 22, 2009. 6:01 PMJoeySchmidt says:
I did it slightly different, I just spliced in a wire on the green and orange signal lines and stuck a switch in the middle of that.
Jun 3, 2009. 6:50 PMj0ey says:
I did a similar mod but just used a basic on/off switch to connect the green (+) and orange (+) on the underside of the board. (Also bridged the grounds (-) between the two.) This way you don't have to cut any wires and can easily desolder the wires in case you have to return your drums.
Mar 20, 2009. 12:08 PMhawke777 says:
Good mod. With the cymbal expansion kit, you may want to link up how to fix them when they inevitably fail as well:
http://www.protoolreviews.com/how-to/build-it-yourself/repair-broken-rock-band-2-cymbals
Mar 6, 2009. 9:35 AMjmrank says:
Excellent idea... tried it, realized how poor my soldering skills are... but hot damn, it works!
Jan 6, 2009. 8:46 AMDeusXMachina says:
I think you mean cymbal. A cymbal is a piece of metal you hit to get a crash noise, a symbol is a character or glyph that represents something.
Jan 6, 2009. 6:14 AMDecepticon says:
Too bad RB2 doesn't know the difference between them. With the cymbal kit (or a home made cymbal) RB2 turns the green pad into the third tom drum and the cymbal is the crash. Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TeamSkenes
