iImage Information
I had heard many reports of the drum sets that came with world tour being defective. One guy I know can't get long streaks because the drum set just wasn't of high enough quality. When I set up my drum set it worked great! I was relieved. It seemed the build quality had improved. Not so fast.... Within a few days of some serious rocking out the yellow cymbal failed altogether. I was livid. I knew the stores wouldn't take it back, and it would be weeks to get it shipped and fixed, at a cost. So I did what I do best... I voided the warranty.
I figured the cymbal was a pretty simple piezoelectric device, and anything wrong with it was an easy fix for a geek and his soldering iron. So I set to work. My cymbal was totally non-functional, and broken is a certain way, your mileage may vary.
Step 1Acquire testing ability.
iImage Information
Credit goes to this
other instructable on drum set repair for the idea of using the mii freestyle as a test bed. You should start this up and leave it running. Whenever you need to test the cymbal, just plug it in, and see if it works. Very productive!
Here;s a utube video showing the installation:
http://www.youtube.com/watch?v=ar46G7IyWAM
And here's where you can buy a pair of cables:
http://krazeekrazees.com/selected-krazees-part/cymbal-cable-p2.php
Hope this helps out some people!
Thomas
Thanks a lot for this guide - It worked perfect for me!
Cheers
Moschme
There is a very, very small amount of copper connecting the black ground plate to the female socket's pin. mine had a hairline crack which is probably a stress crack that widened and opened the cuircuit very shortly after we started playing the cymbal. I would consider this an engineering defect, the PCB was etched with too narrow a connection here at a high stress point. In any case I just scratched off some of the green resist from the PCB and used a bit of copper braid wire to create a "stitch" between the pin and the board (on the side opposite the hairline crack). Even a solder bridge (extra solder bridging the gap) would work for some time.
I named my cymbals too! Ultra Rigged 3000 A & B
Situation
U don't have a spare Male 1/8th jack.
U know how to solder, got the gear.
Butchered the old Male jack or other.
Can't be bothered stuffing about.
Want a somewhat permanent fix.
Simply use some wire (e.g vehicle speaker wire) to lengthen existing snapped wires. maybe another 50-100mm or more. measure twice, cut once.
Remove underside rubber protector from offending cymbal.
Neatly cut speaker wire to length. Both ends.
Cut Cymbal side as close as possible to jack.
Strip back maybe 10mm or more.
Speaker wire same as above.
Use Earth, black line along speaker cable, for Earth connection.
Positive for Positive.
Solder speaker wire ends directly onto Chip.
There are 3 solder points for this operation.
Very bottom is earth.
Top left is power
third is connection unused in situation I bypassed(buggered jack point)
eg; of solder point orientation.
Power Connection
1 1
Earth
2 Internal wire from Drum-kit end is Power
3 External wire is Earth.
Before soldering test correct orientation of wires using MII play.
If incorrect fix it....
Solder the correct ends together. Problem solved.
Put it all back together.
There are some basic steps not included like splicing wires together etc, if u can't do the basic I think u maybe in the wrong place
either that or I am.
Cheers
