Guitar Killswitch
Guitar Killswitch
Guitarists such as Tom Morello of RATM and Audioslave and Buckethead are known for their use of killswitch in their songs to add cool effects. Although killswitches are used infrequently, they are pretty cool to have on you're guitar, and they only cost about three bucks (depending on what you have) to install. In this instructable, you'll learn how to install a killswitch in your own Strat style guitar. Keep in mind that I also explain how to install a killswitch in all style guitars, however I show with pictures Strat style guitars.
A demonstration of my killswitch...I also demonstrate the "pop" that many of you have questions about.
Disclaimer: I am not responsible for any damages that may occur while modifying your guitar. This is merely a guide. If patience is utilized, then no damage will come.
Step 1What is a killswitch?
For those of you that don't know what a guitar kill switch is, it's basically a momentary switch, that when pressed, stops signal from going out of the guitar and going into the amp. Basically, when the button is pressed, there is no noise. Les Paul players usually achieve this effect by setting one pickup's volume to zero, and switching back and forth between pickups, creating a stuttering effect. However, this cannot be done on a Strat., since there is only one volume potentiometer.
The basic concept of my killswitch design is to create a circuit in which the output signal can reach the ground. When the circuit is completed (by pressing the switch), there no sound is heard.
IMPORTANT: Simply putting an on/off switch on the outgoing signal wire is VERY BAD. The resulting sound is that of when you unplug or plug your guitar in. That annoying buzz.
Source - http://www.stinkfoot.se/andreas/diy/mods/killswitch.htm
The popping sound is normal, due to the physics of the killswitch. Adding resistors and capacitors wont do anything. Source - http://alexplorer.net/guitar/mods/killswitch.html
377 comments
1-40 of 377next »
Dec 14, 2011. 6:36 PMShaneRobertsFathom19 says:
Hey, this is a really good set of instructions! But I was hoping you could help me out, this is my first guitar mod and i want to do it right the first time. I went to radio shack and bought a R13-24a-05 button-style kill switch, and i want to make sure this will work if i solder both tabs on it to the tabs on my output jack. This switch is an Off (On) switch, and thats where I get lost. Is that what I need? Or do I need On (Off)? Also, I bought a toggle switch (On Off) that i want to install while I'm in the guitar. What would the wiring look like if i installed them right next to eachother (between the volume and tone knobs on a Telecaster)? I definitely want to solder these to the output jack, not the volume. Thank you for any help -Shane
Dec 14, 2011. 7:18 PMShaneRobertsFathom19 says:
http://www.youtube.com/watch?v=1_8PZDKoNkY&list=FLpXVcS9keRjkPiisMtjYbTA&index=1&feature=plpp_video
Will this work for a Fender style guitar?
Dec 14, 2011. 7:09 PMShaneRobertsFathom19 says:
Ah man I am getting confused, am I pretty much putting the switch between the volume and output along the hot wire, or can I do this from the two prongs on the output jack?
Nov 26, 2011. 3:20 AMdodla says:
hey itsachen can u pls tell me how to make an external killswitch.i hv tried once using a toggle switch but i play a high gain patch like bulls on parade for scratching e heavy buzzing noise is coming
Oct 14, 2011. 9:43 PMsvachon1 says:
"push on" or "push off" momentary switch? I'd imagine "push off", but I want to be absolutely sure.
Sep 20, 2011. 11:28 PMwardog says:
tell me im crazy, im gonna install one for my electric-acoustic guitar XD haha the pick-ups are similar to the electric guitar.. will it work?
Aug 26, 2011. 2:50 AMSponnie says:
Hi, thanks for the cool instructions. I just received my button but what's puzzling me is the nature of it's PUSH ON/OFF. When I push it there is a click and I assume it stays in the OFF position so I would have to push it and get it to click again to get the sound back ON? Don't they make buttons that just release when you release your finger so you'll never have to worry about leaving the sound OFF?
Aug 20, 2011. 4:59 PMjosh1324 says:
You can just connect the switch between live and ground on the output jack in the guitar.
Aug 21, 2011. 9:33 AMjosh1324 says:
Yea, and the way i did it, was that i mounted the switch inside a project box and taped it to the body of the guitar. That way, if i change my mind, i can just take it off.
Jul 10, 2011. 7:14 AMstratattack says:
When i touch the wire of the switch to the wire that goes to the output jack, my amp (which is connected to my guitar) makes a wierd, buzzing noise. Even if i use a noise gate it won't stop. Is this a normal thing? How do i fix it? If I will solder the wires, will the guitar still make that sound?
Jul 11, 2011. 11:06 AMstratattack says:
I did the connections exactly like in the image above. When i connect one of the wires to the ground every thing sounds normal but when i connect the other wire to the output wire it makes a wierd, buzzing sound (like hum, but louder). But if i press the killswitch i get no sound at all (That means i did the connections properly). The only problem i have is that noise
Aug 21, 2011. 9:35 AMjosh1324 says:
It might be a bad switch, try using another one.
Feb 5, 2011. 1:44 PMSuper Squatch says:
Would an spst toggle switch work? And how can you be sure where to make the connections so that it's on when flipped down and off when flipped up?
Aug 5, 2011. 11:05 PMzmeyers says:
It will work if you use one which has a 'on-off' or 'on-off-on' configuration.
On-Off (two way) - the sound will cut out when its in the off position.
On-Off-On (three way) - good because when the switch is accidentally turned on it doesnt cause embarrassment :P
Have Funn!!
Apr 2, 2011. 5:00 PMsteveo_calamia says:
you could probably just spin the switch around after you wire it up... or use alligator clips to find out what should be wired to get desired results...?
Jul 30, 2011. 12:14 AMbspurrier says:
The switch you recommended works great for my needs. One problem which is important to note, for those of us who don't own a strat, the switch's bushing is nowhere near deep enough to get through an archtop guitar. I tried this on my Schecter C-7 and now I have an empty hole in my guitar because I didn't think to measure the thickness of the wood in that spot. I'm going to have to carve a hold in the front of my guitar and put in a plate to hold my switches.
I opted for a two way toggle which switches between two seperate parallel circuits. One has a Normal Closed button, one is Normal Open. The electronics work great as is.
Jun 29, 2011. 11:44 PMdtyler says:
Would this be the kill switch I would need to use on a "Sky" Flying V design?
http://www.radioshack.com/product/index.jsp?productId=2062545&prodFindSrc=cart#
Sep 11, 2010. 1:09 PMAzayles says:
If you wanted to build this as an external unit, for example if you don't want to poke about in your guitar and risk damage, could you use a foot pedal which activates a zero-crossing switch circuit? For example, some chips used for muting audio signals use zero crossing circuits to eliminate clicks and pops.
Of course this means the unit will be active, and hence require batteries.
Jun 19, 2011. 3:03 PMMerleCorey says:
optocoupler could be used here.
Jun 7, 2011. 4:22 PMtshipman says:
thanks for making this! i just did it, drilling the hole was the hardest part, but it turned out great! it's going to be interesting messing around with it.
Jun 5, 2011. 2:58 PMBobMarleyFan says:
COMPLETELY OFF TOPIC
I haven't even read the 'ible yet, but i noticed that your frets look funny... are they scalloped?
Jun 6, 2011. 11:29 PMthejedilestat says:
verry tempting.... me likes me likes
Mar 8, 2011. 5:40 AMstratattack says:
The button used turns Off or On when pressed?
Jun 6, 2011. 9:00 PMbricabracwizard says:
'On' when pressed
Apr 23, 2011. 11:18 AMrespinoza1 says:
excellent way to make it, but i have a question? you said simply puttin the on of switch will create that disturbing sound, but the sound keeps on even if i put the wire on the master volume ... sorry for my bad english, how do i fix this? im using good cables i dont know what the problem is thanks
Apr 23, 2011. 4:04 PMrespinoza1 says:
thanks but i dont mean the popping sound i mean the buzz sound created when i connect the wire to the center of the master volume.. is the same anoying buzz when you try to connect to the outgoing signal... theres no difference on my guitar.. still buzz anyways..
Apr 15, 2011. 4:38 PMpecosdog says:
Thanks for the info. I put it on a SAGA strat I built and it works great. Two things I would do different though. I put it in the same place on the guitar ( it doesn't really matter, its a bit of a frankenstein experiment anyway, I will change it) that you did and it gets in the way there of chord cranking, especially ska with the upstrokes. And second, that particular switch is the hardest to press and the biggest one. Radio shack has some smaller ones that have an easier press to them and less of a profile on the guitar. Other than that, the info was great.
Apr 6, 2011. 4:18 PMdbeauchamp says:
Excellent guide, worked perfectly.
Nov 12, 2010. 2:47 PMMegaMaker says:
Your guitar looks amazing.
Aug 26, 2010. 1:50 PMCapnTac says:
Stupid question, but which artist is known for that penguin?
1-40 of 377next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:itsachen
Student, guitarist, tinkerer I've always loved tools and working with my hands. Coupled with a DIY spirit and intrinsic frugality, I try to bring you something new with each instructable.
