A demonstration of my killswitch...I also demonstrate the "pop" that many of you have questions about.
Disclaimer: I am not responsible for any damages that may occur while modifying your guitar. This is merely a guide. If patience is utilized, then no damage will come.
Remove these ads by
Signing UpStep 1: What is a killswitch?
The basic concept of my killswitch design is to create a circuit in which the output signal can reach the ground. When the circuit is completed (by pressing the switch), there no sound is heard.
IMPORTANT: Simply putting an on/off switch on the outgoing signal wire is VERY BAD. The resulting sound is that of when you unplug or plug your guitar in. That annoying buzz.
Source - http://www.stinkfoot.se/andreas/diy/mods/killswitch.htm
The popping sound is normal, due to the physics of the killswitch. Adding resistors and capacitors wont do anything. Source - http://alexplorer.net/guitar/mods/killswitch.html
Visit Our Store »
Go Pro Today »
Will this work for a Fender style guitar?
1) Your circuitry might be different than a strat circuitry. If so, no fear, just bypass the hot and ground at the input jack
2) Using a killswitch on CLEAN settings makes a noticeable popping sound! This may make you not want to install it...
http://www.instructables.com/id/Removable-Guitar-Killswitch/
On-Off (two way) - the sound will cut out when its in the off position.
On-Off-On (three way) - good because when the switch is accidentally turned on it doesnt cause embarrassment :P
Have Funn!!
I opted for a two way toggle which switches between two seperate parallel circuits. One has a Normal Closed button, one is Normal Open. The electronics work great as is.
http://www.radioshack.com/product/index.jsp?productId=2062545&prodFindSrc=cart#
Theres an easy hack to get around this though. Just wire the switch so that it shorts the hot signal to the ground.
Of course this means the unit will be active, and hence require batteries.
Happy playing!
I haven't even read the 'ible yet, but i noticed that your frets look funny... are they scalloped?
http://www.instructables.com/id/Scallop-Your-Guitar-Standard-Scallop-Frets-14-21/
http://www.youtube.com/watch?v=1RSlh-npdQg&feature=player_embedded
You can't fix the popping with anything, its just the physics of the device:
I recommend first using a better quality switch, like those on arcade games or my favorite, the Lumex CLS-PC11A125S00 switches (LED illuminated red, yellow, green or blue) available from DigiKey. Also mounting the switch on a metal bracket screwed directly into the body wood in the control cavity and a clearance hole in the pick guard would eliminate the resonance caused by the pick guard.
Lastly, I usually wire the kill switch directly to the jack's solder tabs (less chance of screwing up the control wiring).
Your resonance theory with the soft and hard taps does not make sense.
I own the guitar and I can testify that hard and soft taps make the pop.
Resonance does not work like that...
Its the wave being cut off by the killswitch that is producing the pop
Style A : (simple & cheap)
1. Take 2 wires and solder one end of each directly to the output jack terminals.
2. Solder the other ends of the wires to a SPST Normally Open switch.
Style B: (as used by Eddie Van Halen and Buckethead)
1. Use a DPDT switch and solder 2 wires (one end of each) to the common terminals (Com.) of the switch.
2. Unsolder the circuit's output wire from the jack's tip terminal and splice it to one of the switch's common wires.
3. Solder the switch's other common wire to the jack's tip terminal.
4. Solder the switch's Normally Open (N.O.) terminals together and solder a wire from them to the jack's ground terminal.
5. Solder the switch's Normally Closed (N.C.) terminals together.
P.S.: I would have added a picture but the website's "add images" doesn't work!!.
Did the toggle switch reroute the hot signal to the ground?
NEVER USE A NORMALLY CLOSED SWITCH TO OPEN THE CONNECTION TO THE JACK. It's like unplugging the patch cable. Anyone ever unplug the cable with the amp still on? "POP".
By wiring the kill switch the way I described below, it works like those new "Silent" plugs from Neutrik. It's like turning your guitar's volume knob instantly to zero.
Worked perfectly thanks for instructions.
Are you sure that the diagram you sent is right?
In the diagram the two tone pots are DPDT, I'm guessing for coil tapping or something like that.
The diagram shows that they must have taken out one of them...
I was checking with you to see if the diagram is 100% accurate, because that would mean you would need a 500k push-pull pot. You could pick one up at stewmac: www.stewmac.com/shop/Electronics,_pickups/Potentiometers/Push-pull_Pots.html
As for short or long, I would say it all depends. Longer would be better because (if you have a saw) you can cut it to length. If you can, see how long the remaining tone pot's shaft is and compare to the data on the product sheets.
Let me know how things went or if you have any problems.
Also, one more thing. What is the difference between a standard pot and a push-pull pot? And is there different wiring for that?
A standard pot just has the three tabs, and it controls a varying amount of resistance. A pushpull pot has the three tabs, and it also doubles as a DPDT switch, when pushed and pulled. So it has 9 connections total.
nice strat by the way, where did you get that pickguard?
Actually I get that question alot, but my pickguard came with my strat.
is that an ibanez?
The sticker is from a sheet of Ibanez stickers my friend gave me.
http://www.instructables.com/id/easy-killswitch/
For the player looking for a permanent killswitch, I don't think a box taped to the profile of their guitar is the solution. Seriously.
i did everything right and when i tried it out...well lets just say i dont have a killswitch.
i have a liveswitch, my killswitch works backwards.
i have the volume wire (from V knob to guitar's input hooked up each to one side of the switch).
did i do something wrong?
oh and i have a behringer (its the same as a strat style but with a bridge humbucker and not a single.
help out please.
Since your setup is doing the opposite of what is supposed to happen, you may have accidentally bought a push to break instead of push to make.
You want a push to make, or normally open switch, not a push to break or normally closed.
But then again your wiring might be messed up. From what you described it sounds right though. Try intercepting the signal right at the guitar jack, just to be sure. Find the hot and ground that lead from the input jack and intercept it there.
Congrats, you're the first person to actually realize that.
My bad on the diagram, but yeah.
But the gx-200 has a glued in neck, not a neck through like the picture shows.
http://www.corel-srl.it/images/dremel_foto.jpg
A router can make smooth cavities in the body of your guitar with ease.
http://i.ehow.com/images/GlobalPhoto/Articles/12158/RidgidRouterGallery-main_Full.jpg
Dremels have router attachments I think, which could work as well.
What you should really aim for is a rotary tool with bits made for routing, not drilling.
you should of just put the switch down by the pots.
It required a little routing out of the guitar, but it is perfect. It won't wear you out like a smaller switch would.
It wont work with the instructions I give. With a SPST, when the switch is pressed, the signal is rerouted to the ground. When a SPDT switch is pressed, or switched, the pole changes positions. You could easily use a SPDT switch though.
1) Literally killing the signal, ie. putting an on/off switch instead of rerouting the signal is VERY BAD, and wrong. You'll get the "accidentally unplugged guitar" sound. Source - http://www.stinkfoot.se/andreas/diy/mods/killswitch.htm
2)You're suggesting what I have in my instructable.
3) The popping is due to physics, nothing to do to change it. You just literally stopped the signal. Source - http://alexplorer.net/guitar/mods/killswitch.html
i took the wiring schematics of a telecaster and drew a red line, basically signifying a wire. You can put the button anywhere u want on the wire.
http://i23.photobucket.com/albums/b393/Pandaman0529/TeleSchematic.jpg
if u have ne other questions jus reply
it's a little bit different, but works the same. keep in mind normally closed means the circuit is connected, and normally open means the circuit is disconnected. there a plenty of ways to wire this, depending on your switch.
