Step 2What you need
1 SPST "Push to make" Momentary switch - I got mine at Radioshack for 3.20
Important: You must get a switch that is normally open (off), and when pushed, closes a circuit.
Wire - This should be about the same guage as the wire in your guitar, it doesn't have to be exact, but don't have a huge thick wire.
Solder & Soldering Iron - This project requires some simple soldering, nothing too complex. I learned to solder with this handy instructable.
Wire strippers
Screwdriver
Electric drill & drill bit (on the back of the momentary switch packet theres dimensions for the hole you should drill) - I'd recommend that the drill be corded, since cordless drills lack the power that corded drills have
Things that would be really helpful to have:
Helping hands: These things make this project 500 times easier, instead of duct taping wires to hold them in place, or asking somebody to help you, the Helping hands can hold them.
On-Off (two way) - the sound will cut out when its in the off position.
On-Off-On (three way) - good because when the switch is accidentally turned on it doesnt cause embarrassment :P
Have Funn!!
http://alexplorer.net/guitar/mods/killswitch.html
it's a little bit different, but works the same. keep in mind normally closed means the circuit is connected, and normally open means the circuit is disconnected. there a plenty of ways to wire this, depending on your switch.
