3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Killswitch
Step 6Soldering the switch to the volume pot.
This part was pretty tricky for me, mainly because I was working by myself with nothing helping me to position the wires. Remember, you don't need to solder the wires, if you cannot solder. You can twist them on, however they might fall off with time.
I soldered one wire onto the middle contact on my volume pot. (output signal), and the other wire onto the actual volume pot itself (the volume pot was grounded)
For non-Strat guitars: Though the wiring for the pickups and all are different in Les Pauls and other style guitars, the basics for the killswitch are the same. Instead of soldering the killswitch onto the volume pot, on other guitars, simply trace the wire that goes into the output jack (in this case a gray wire) and inside the wire should be two smaller wires. Simply solder one wire thats attached to the killswitch onto one of the wires found in output jack, and solder the other wire attached to the killswitch to the other wire. One of the wires coming fro the output jack should not have a rubber casing, as it is the ground. Basically what you just did was create a potential bridge in which you can kill the signal with the press of a button.
34 comments
Apr 13, 2012. 9:38 AMsmatt1 says:
If I literally attach my wires to the spots shown, will it work? Or do I have to move any other wires than the ones on the switch?
Sep 30, 2009. 10:40 AMstormtrooper85 says:
Just a note: for those of you who are unfamiliar with the wiring let me try and simplify things. The wire being connected to the volume pot is the ground wire for the switch and the one being connected to the input jack is going to be hot. The prong on the input jack should be attached to the white wire.
Sep 13, 2009. 5:57 PMrkr says:
Just a note: It is highly recommended that you solder things together if you're going to do this, because loose connections make for bad sound quality, plus, as mentioned, they can fall apart.
Aug 8, 2009. 6:15 PMphoenixinhoc says:
I think that this is the step that I'm doing incorrectly -- either that or I didn't get the right kind of switch. Anyways, I haven't drilled yet because I want to make sure it works first. I have one wire attached to the middle output from the volume, then the other to the top of the volume. Nothing happens when I push the button. Any ideas?
Feb 28, 2009. 3:52 PMShredLikeBuckethead says:
Ok. So i have my fender squire and my ibanez rg350dx both opened up right now. they are on the ground next to me. i have taken one of the tone knobs off my squire,and bent it to the side to the hole is free. as for the ibanez, i plan on drilling a hole in between the volume and tone knob and i plan to put it there. i have bought 2 switches that monts in a 1 half inch hole. currently i have cut some of the gray casing off my hot and ground, and im planning to cut the hot (white wire?) and solder one wire to each end of the hot. then i plan to solder thase 2 new wires onto each prong on the switch. am i doing this correctly, is the any chane of failure/damage to my guitar, and possibly any other tips. a request would be greatly appreciated. thanks in advance,
Jun 13, 2009. 11:45 AMShredLikeBuckethead says:
I have done my rg350dx, check out my killswitch instructable for a picture i'll be putting it on today it looks great.
Apr 24, 2009. 12:35 PMvarietyshowjoe says:
Hi, I have a Epiphone SG and want to install a killswitch in the hole that my rhythm volume knob is in. I plan on making the bridge volume the master volume so that I can still control the rhythm pickup's volume. Have you ever done this? And how would I go about making the treble volume the master volume while still maintaining the pickup's respective tone knobs?
Apr 27, 2009. 8:10 PMvarietyshowjoe says:
Well today I did just what I asked about, I made my treble volume my master volume and installed a killswitch in the open hole left by the rhythm volume knob. I'm so glad my dad used to be an electrician because he helped me know how to rewire everything to make it work. So for all of you wanting a killswitch, but not an extra hole in the body, just do as I did. It works and looks great!
Apr 4, 2009. 11:31 PMdrpdedsxe says:
ok so first off i think it is an amazing coincidence that we both have a fender starcaster from best buy. Same color and everything. almost creepy lol. then my real question is: so basically what happens is the two wires coming from the output jack are the output from the volume pot, and the ground for the volume pot. Then what i do is soder one of the wires from the switch to the same spots as the two from the output jack? (sorry if that was a little confusing)
Apr 5, 2009. 9:40 AMdrpdedsxe says:
well yea my REAL guitar is a tele. so those two red wires coming off the volume pot are the switch i assume?
Apr 5, 2009. 5:46 PMdrpdedsxe says:
thanks dude. got it in both without a prob at all. this was probably the most reliable thing ive ever seen on the internet :D
Jan 13, 2009. 4:37 PMpopperhopper says:
(removed by author or community request)
Jan 13, 2009. 7:29 PMpopperhopper says:
i have a aria stg guitar looks like kinda the one isotope has.would i have to solder the killswitch on to the volume pot or the two wires in my output jack.
Jan 14, 2009. 3:04 PMpopperhopper says:
thank you.
Nov 28, 2008. 9:58 PMblackdemonicfire says:
Ok, I know one wire is soldered to the output signal (white wire), but I wasn't sure about the second one. I can solder it directly to the volume pot since the volume pot is ground right? Or should I solder it to the wire that makes the volume pot ground?
Sep 20, 2008. 4:42 AMisotope says:
Thanks! My dad and I did it today, works great. I did it on a fake "Delta' Strat, and it's well worth it.
Aug 23, 2008. 8:41 PMa7x1st says:
hey is it ok to put the switch on the output jack? theoritically(forgive my spelling) i think both should kill the signal, but what do you think? it is like volume pot -ground goes into . . . output jack-ground (i want toput the switch here -signal -signal
Jun 19, 2008. 9:28 AMkillswitcher says:
hey, sorry to bother you, i have my squire strat opened up on my lap right now. I found the EASIEST way to completely avoid drilling into your guitar. i removed the tone knob farthest from the pickups, and am planning on using that hole for my killswitch. also, on my volume pot, there are two wires soldered onto the top. i am ASSUMING the black one, which travels to the bride, is my ground wire. i dont know about the other one. HOWEVER:P do i solder one wire onto the top, into the glob of solder where the ground is connected, and the other onto the empty tab (there are 3, 1 is empty)???? an answer would be VERY much appreciated.
Mar 8, 2008. 5:14 PMpsychodeathmonkey says:
ok, i have one last question. If there is already a wire soldered into the middle tab then would you just solder the new wire on that solder joint?
Mar 7, 2008. 5:46 PMpsychodeathmonkey says:
So.. if i can get this straight you only have two wires going into the volume potentiometer. 1 goes into a tab on it and the other goes into the ground?
Nov 30, 2007. 4:22 PMchainmail311 says:
I'm sorry. Could you make it a little more clear on where to solder the wires? I'm confused. Thanks!
Nov 30, 2007. 7:43 PMchainmail311 says:
Nevermind. I did it. Works like a charm!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:itsachen
Student, guitarist, tinkerer I've always loved tools and working with my hands. Coupled with a DIY spirit and intrinsic frugality, I try to bring you something new with each instructable.
