3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Killswitch
Step 9FAQ and Troubleshooting
So many questions come in, so I decided to make this section.
Question:Why isn't my killswitch working?
Answer:Many different possibilities. Maybe you spliced the wrong wire, remember, you want the output signal wire to be routed to the ground. If thats not it, then maybe you have the wrong switch. You want a normally open switch, otherwise known as normally off. Other possibilities might be the connections between the switch and the wires.
Question:Why do I get that popping sound when I use my killswitch?
Answer: Don't worry, you're killswitch isn't broken, you did everything right. The pop is normal. If you ever taken physics and learned about waves and stuff you might understand that cutting the signal results in a pop. This site helps explain more.This site helps explain more. This video also shows and explains the pop.
Question: Can you make a diagram for my Gibson SG or Les Paul?
Answer: Ive done it before, but if the demand is increasing I might just make a diagram and post it.
Question: What if I have no faceplate?
Answer: Drill the hole through the back of you guitar by unscrewing the back plates.
Question: Do I have to drill and solder?
Answer: No, I prefer a built in killswitch casue it looks neater and clean, but if you want to play around without damaging your guitar. Check out Super Cameramans instructable.
11 comments
Jul 20, 2009. 10:09 PMBucketbot#32 says:
Is anything any different if you want to put a killswitch in a Flying V like mine? By the way, was that Night of the Slunk you were playing near the beginning of the video? Nice.
Jun 14, 2009. 10:24 PMstratman410 says:
dude are your frets scalloped?
Jan 26, 2009. 11:32 AMrainbowfied says:
Is there anyway at all that I can get rid of the popping noise?!
Mar 7, 2009. 10:32 AMbasuramail says:
put a 2M resistor o greater between hot and ground, then in clean and distortion setting is no popping anymore. The same trick is used on stompboxes for true bypass switching.
Mar 3, 2009. 10:03 PMPrimaeNoctis says:
I play a cleaner blues tone and want to use my killswitch, but it's popping. I don't use heavy distortion. What can I do to remove the pop? Would a capacitor help? Would a capacitor/resistor help? I wired it straight to the output jack.
Aug 22, 2008. 8:03 AMutfal says:
I'm afraid that while opening the face plate if some connection is broken between the pick ups and secondly I live in India and can't get a kill switch from any where is there any alternative?
Aug 26, 2008. 2:07 PMthisiscastro says:
do you guys have a radioshack in india
Aug 23, 2008. 8:46 PMa7x1st says:
who says in india there's no switch? we 'make' a 'kill switch' from a 'switch' all you need is a switch, wire, solder if you want, and a little bit patience
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:itsachen
Student, guitarist, tinkerer I've always loved tools and working with my hands. Coupled with a DIY spirit and intrinsic frugality, I try to bring you something new with each instructable.
