Guitar Pick Necklace
15,900
60
18
Published
Introduction: Guitar Pick Necklace
Hi this is my first instructable and im only 13 so be nice! Also something else about this instructable, i didnt have enough supplies to make a new necklace so i took apart the one i made before to show you how to make it. I'm REALLY SORRY about that. But this pick seriously looks cool and is easy to make.
Step 1: What You Will Need....
for some reason this picture turned out bad so what you need is:
Small, circular hole punch
Pick (doesnt matter what size)
Thin but strong wire that will hold its shape.(really cheap at craft stores)
Step 2: Pokin' Holes!
Take your hole punch and punch holes like whats in the picture. I made pencil marks on the back of the pick to help line up holes. Just estimate as well as you can for top middle hole.
Step 3: Time for Wire
make sure the side of the pick that has writing on it has the gross messed up wire on it. like in the pic, fold wire in half and pokethe two end through the hole in the top (on the side without writing). make a horizontal line on the top two notches in the back with the wire. flip pick around and take two wire ends and make an "X" with them through the bottom notches. flip back over and wind them together and your done! Now just poke a string through it and put it on your neck!
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    18 Comments
    That's very clever. What if you used a string long enough to wear and threaded it up through the loop at the top? It might take another knot to hold it together.
    thats what i did and it looks awesome
    that might work if you try it and it works let me know!
    or you could make a long loop of string that you can pull over your head and slip knot it through the hole.
    Hey. Great instructable :) If you(as I) don't have a hole punch, I am sure you can drill the holes too.
    Hold a lighter under a paperclip or pin and heat it up till it goes red and just poke that through the pick. The fact that it's red hot makes it reeeeaallly easy to poke the hole
    thanks! yeah im sure you could use a drill. but you would need a really small bit though. or just old fashioned pokin holes with a knife!
    very gooD, very good. Im taking this to school next week(one week thanksgiving vacation, WOOOOOOOOOOT  WOOOOOOOOT!!)
    so wait..what side faces out? the side with the writing or the side with the X??
     the side with the X. the side with the writing has all the ends of the wire and ugly stuff behind it.
    This is really more for style than actual use. the wire makes it pretty hard to play with. just an idea if you want to show off that you play guitar ;) thanks for the constructive comments
    That's a good idea, but personally, I prefer to just drill a straight hole through the pick and put it on a chain around my neck, because to me it seems like the wire around the pick would get to be a nuisance after a while. And as for a keychain version, just drill a hole through a pick, and take one of those metal-ball-chain things that snap together, cut it short, put it through the pick and the split ring you have your keys on and you're set. Good work though.
    the problem is you break them that way... i had a white fender pick on my keys
    I've never had that problem before and I've been keeping picks on my key ring for a few years now. I guess it also depends on the thickness of the pick you're using though.
    well i'm also hard on key chains
    wow! thanks for the nice comments! i had the idea one day after i had been looking for cool pick necklaces and thought of this. i tried making it without notches, but it didnt work. and acaz93 if you figure out a keychain version let me know!
    great first one! looks great, and the pics are better than alot of some I've seen.
    it's original , wondering if it coulld be adapted for a keychain
