Guitar Pick Tray Christmas Gifts
1,732
45
8
Published
Introduction: Guitar Pick Tray Christmas Gifts
About: Disclaimer: The author is not responsible for loss of life, limb or property. The author is not responsible for your actions. The author is not responsible for anything. In fact, the author is completely i...
Last year I made Trivets for everyone on my little CNC machine. This year its candy dishes and pick trays....
Really the same thing. just scale it up or down as needed.
Step 1: Guitar Silouhettes
You start with simple silhouettes. If you want to make your own I would recommend using the Gimp's threshold tool. First convert your image to a gray scale the you can pretty much block it out easily....
I used easel to create the project files. I was inspired by their project for one of these shaped like an electric guitar. I thought an acoustic guitar would be more appropriate for my sister and brother in law....
I used the picture with the neck stub as the outer cut. I set the depth to .75 and shape to "outline". As it turns out my plaque was .758 thick. When you set the cut depth to maximum (must set stock thickness) you get a checkbox labelled "use tabs". Check this and it leaves small tabs along the perimeter so your work doesn't cut completely free and jam the bit. Since I was a bit off on the depth I had more than the tabs to remove on the first one I made.
The second one I made was cut completely through. Don't forget a sacrificial scrap of plywood under the plaque or you'll cut your table too.
Step 2: First Try
This one came out pretty good. Its their demo project. I did have to use the scroll saw to free it up. A quick cleanup on the belt sander and you cant tell the tabs were ever there.
Step 3: Now for the Acoustic Version
I used the two jpegs from step one and after setting the feed rate and bit size I exported the G-code. I dont use their sender directly even though my little machine is running GRBL and was based on their CNC machine.
This way I can also cut them on the larger machine that runs Mach 3.
Step 4: From Trash to Treasure
Not too bad considering that plaque was pulled from a dumpster outside a trophy shop.Even my supervisor approves (she was watching from the stairs).
I 3d printed a few picks to try it out.
Next time I go to Lowe's I have to get more polyurethane........
  • BBQ Showdown Challenge
  • Backpack Challenge
    Backpack Challenge
  • Stick It! Contest
    Stick It! Contest
8 Discussions
Wow! I did not know that you made these! Roy and I LOVE our pick trays!
Eileen yelled at me for posting this instructable before Christmas...
She said now Eletra knows what she's getting for Christmas!
Do you remember the trophy & medal place, classic Medalistics or something like that, next door to Keystone?
And all those plaques daddy and I used to dig out of the dumpster and bring home?
Well, these were cut from one of those plaques.......
I never saw it and didn't until now. I thought you found them for sale somewhere online. They are great! You still have those plaques? I still have one or two but I'm using them as shelves. If you feel like doing it again, could you make one for me to give as a gift to my guitar teacher? I usually give him something at the end of each 10 week class. We are starting the next class on 6/6, ending 8/15 (please).
30+ years later and there's still a few left.
I'm not sure if that's something to be concerned about.........
These are great, and a very cool gift to receive. I'd be thrilled to get one. Nice work!
Thank You!
I have to try adding some text to personalize it for each user.
Maybe this weekend........
