Step 8: The fret board
While perusing the home depot I found some hardwood screw caps and used them to make the dots out of. Just drilled a bunch of small holes, glued them in, and sanded them flush. Finally the top of the fret board was rounded with a home made radius sander.
The sander is a pretty simple device. I saw one at a store and decided it was to simple and useful to shell out $35 on, so I just made it on my table saw. Its a pretty simple concept. Take a short length of 2x4 and saw a wide channel. The thickness at the bottom should be about a 1/4" glue some sand paper to the bottom and use some nuts and bolts to expand the top and change the curvature of the bottom. It does a surprisingly good job.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
I just wanted to point out that cocobolo has some toxicity from the oil & dust.
This is usually seen from turning, but it might also be present when sanding & so you should consider using respiratory protection when working it.
Here's a link to a page that lists the toxicity of some of the exotic woods: http://hobbithouseinc.com/personal/woodpics/_@_toxicity.htm
I hope it plays as great as it looks!
