3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Tattoo
Guitar Tattoo
Give your guitar a temporary tattoo with this instructable. This is a very simple and fun procedure, provided you have a few things:
Guitar to Tattoo
PhotoShop (or something similar)
Printable Window Decal paper (avery)
piece of paper (optional)
scanner (optional)
This is great because you can 'decorate' your guitar without damaging the finish! You'll be able to change out your guitar tattoo whenever you like. You can slap your name on your guitar. How about a picture of your significant other? Display the name of your band. Display the name of your bird. Whatever. Enjoy!
Step 1Preparation
Preparation
My first step was to draw the contour of the bottom right area of the body of my guitar. To do this I just set my guitar on a piece of paper and traced the edge... simple right?
61 comments
1-40 of 61next »
Apr 24, 2009. 10:47 AMelijahlucian says:
My advice to all of you who want to do this from a professional graphic designer: use illustrator or corel draw. using a vector drawing program will make your design have very sharp edges, thus making it look like more of a professional job.
Apr 24, 2009. 12:31 PMelijahlucian says:
yeah. well i recommend 'artrage' for any hobbyist artist. full sketch and trace program for 25 bucks! cant go wrong
Aug 16, 2011. 9:23 PMnclarke says:
For people who don't want to pay out the ...nose... for Illustrator or coreldraw, Inkscape is a free vector graphics editor.
Jul 20, 2011. 9:09 PMpaqrat says:
This is very cool.
Feb 19, 2011. 3:16 PMtaywill95 says:
Would it be alright to print something out and make it into a stencil to sharpie onto the guitar? I'm wondering if I need to avoid it...
Mar 26, 2011. 4:57 PMGreaseStains says:
i've tried drawing on my guitar with sharpies before, the clear coat and the alcohol based ink keep it from being permanent. it will slowly wipe off completely, but the plus side is, you can wash any mistakes off with rubbing alcohol.
Jun 16, 2009. 7:00 PMbassdale says:
What if you own a black guitar?, no raceism intended!
Jan 17, 2011. 10:28 AMcompgeek97 says:
try making your image then making it negative so the black is white and viceversa
Jun 22, 2009. 9:19 PMmkkrushmt says:
could you use a lighter color ink?
Aug 29, 2009. 10:08 PMnitrox027 says:
print it white, itll show up lol
Jan 29, 2010. 3:28 PMpenguin.waddle14 says:
no it wouldnt!
Nov 4, 2010. 11:16 AMpinupsplus.com says:
Projects are always fun when you do it yourself, but we do carry some pretty cool waterslide decals and you can get some amazing results. Check out some of the projects that our customers have done:
http://pinupsplus.com/customer-pictures-ezp-4.html
Jul 8, 2010. 10:09 PMamcayanan says:
Great idea! thanks for sharing.
Mar 2, 2010. 12:38 PMthe-ruler-of-craziness says:
where do you buy printable window decal paper from?
May 4, 2009. 6:17 PMJKibs95 says:
Sweet! Questions: 1: Do the tattoos come off? If so, do they ruin the finish of the guitar when they come off? 2:Wasn't Apollo the Greek God of music?
May 23, 2009. 12:49 PMfatfoohy says:
pan was the god of nature, apollo was the god of music.
Sep 6, 2009. 1:56 PMsanty22 says:
pan is also "bread" in spanish. maybe he was also god of food!
Jan 19, 2010. 4:27 PMMr. Brownie says:
i thought it was japanese
May 19, 2009. 7:44 PMkneecaps says:
i believe pan was a piper
Nov 21, 2009. 2:01 PMpardusimo says:
if water/sweat does get on it can it stain the guitar?
Oct 1, 2009. 11:01 AMyouy says:
HI..I've got a strat and was wondering if this would work/damage the pickguard? anyone tried that or something similar? Cheers :D
Sep 24, 2009. 7:58 PMmkkrushmt says:
i was playing at a school picnic the other day and it started to rain. there were only a few drops, but where the water did hit the label it washed off the ink so its all spotted, it actually has a pretty cool effect. i think i might make some more this weekend. -Alec
Sep 4, 2009. 8:28 PMLawlzorz says:
Are you using a laser printer or inkjet??
Apr 28, 2009. 10:11 PMguitarman63mm says:
I went to staples, but a 10 pack of inkjet decal paper was in the neighborhood of $40 US, seemed extremely steep to me, but oh well.
Apr 11, 2009. 9:05 PMguitarman63mm says:
How does this method compare to one of transparent paper -> laser printer -> guitar + clear coat? I read about a guy on ProjectGuitar.com who used that method for his logo. So a standard printer works? Can I change the color of the text? Will this paper dissolve under a lacquer or poly clear coat?
Apr 13, 2009. 10:01 PMguitarman63mm says:
Thanks, point taken. I suppose I'll stick to the transparency!
Feb 9, 2009. 12:04 PMNight910 says:
this will work on a electric right?
Mar 19, 2009. 8:26 AMpinkishfloydus says:
You can also use a regular rubb-on tatoo and just remove it with alcohol or something similar. although I don't know if that would damage the finish. It hasn't damaged mine yet and I've been doing that for a long time. Your idea is the best (if you have all of that fancy stuff) though.
Apr 11, 2009. 9:03 PMguitarman63mm says:
Alcohol will damage lacquer based finishes. If it didn't affect yours, rest assured, you're fine. Your finish is almost certainly a catalyzed polyurethane, so if that technique works for you, keep it up. But for those of us with higher-end guitars or vintage instruments finished in nitro, the alcohol thing is a big no-no.
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:potatojesus(Perry Costello)
https://www.facebook.com/perrysmusic
