3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Tube Amp
Guitar Tube Amp
Want to build your own tube amplifier for guitar? There are many options: build a kit, build from an existing schematic, or branch off like I did, and try something different.
Maybe, like me, you'll design and build from scratch...
Check out the last steps-- information's been added since this guide was first published.
Among the goals for this build:
--Build an amp with that MMM-good tube sound...
--Design it myself.
--Reuse salvaged and vintage components whenever possible, and save good stuff from the landfill.
--Make something unusual (6DG6GT's in a parallel single-ended configuration qualifies as unusual...as does the tone control....)
A whole lot of tweaking later, I've got an amp that pleases me. A small, but surprisingly LOUD amp that outputs something in the neighborhood of 8 watts (see the Power Amp Stage step for more info.) And the combination of 12AX7 and 6DG6GT tubes, though unusual, works quite well...
Oh, and this is a fairly hi-gain amp--i.e., it has a good amount of natural tube clipping and distortion, and a decently "dirty" sound. However, hi-gain and high volume are not the same....this amp is loud for it's wattage, but it's not a Marshall stack. It remains a studio type amp, but it is louder than all those Valve Jrs., Champs, Blackhearts, etc. which are so popular today....
Clean signal, no F/X.
Settings: volume 50%, tone 60%, presence 30% :
Settings near max :
(Some "ghosting" on the highs is a resonating glass-door china cabinet about 5 feet from the amp...)
In fact, there's a little too much gain...
One thing's for sure...tackling such a project means many happy hours pouring over data sheets, studying schematics, checking output transformer specs, and tracking down NOS tubes....
Noteworthy: there's a certain aspect to this build.... I wanted to retain the feel and budget of the radio-amateurs and home-builders of the past. You can easily spend in excess of $1000 USD for a small tube amp kit alone (nothing but the best audiophile components.) There's an elitism about modern tube amps I tried to avoid (or maybe I'm just cheap ;0)
Step 1Danger, Will Robinson, Danger!
Here's the standard disclaimer:
This is dangerous, high voltage stuff. OK, it's not "High Voltage," technically, but it's high enough to kill you. The power supply in this projects kicks out 200V, which is plenty, with startup spikes near 240V or more...
Don't believe it when they say "it's not the voltage, it's the amperage that kills you"--because it's both. Amps AND volts together dictate the danger level. If it were amps alone, then even a AA battery can supply many times what's needed to stop a human heart. The volts do the "pushing," and overcome the natural resistance of your skin. And there's plenty of current available to harm you in any tube audio amp...
Remember:
--Always drain the power supply filter caps before touching the circuitry.
--Always unplug the mains cord before working.
--Double-check (with a VOM) to be sure the filter caps are drained.
--DON'T mess with this stuff unless you have a decent understanding of the dangers.
--DON'T mess with this if you believe you know EVERYTHING about high voltage, and think that makes you immune to electrical shocks.
314 comments
1-40 of 314next »
Nov 30, 2011. 9:45 PMOldMacTech says:
Cool project.
The white boxes with numbers on the side, what are those and what purpose do they serve?
Thanks.
Dec 1, 2011. 6:12 AMOldMacTech says:
Thanks, do these fail or get out of spec? I have a 1481 Silvertone (cousin of your project) and the volume seems low. Did a re-cap, swapped speakers with some improvement-what should I look for as a possible cause of decreased volume?
Thanks.
JB
Dec 1, 2011. 9:27 AMOldMacTech says:
Thanks, I have a 1482 that is a beast-I have swapped tubes in/out from it. This 1481 has good tone and the replacement speaker increased the volume a good bit but is just seems to come up a bit short on volume. Maybe it's correct but If I can swap a $2 resisitor out and make progress a cheap price to pay. If I wanted to get the correct resistor to replace this, what would I ask for at the electronic store.
I really appreciate you help.
JB
Oh, and can describe the test I can run for this and the other resistors with a DMM?
Jul 13, 2011. 10:38 AMaaronadennis says:
Hello,
It comes to mind would a 6W6GT also be suited for this project. I think they also have a higher plate voltage and maximum power dissipation. I'm certain they are as available as a 6DG6GT as well.
cheers
Oct 2, 2011. 1:56 PMpddonovan2011 says:
One really great project
Literally, the best sounding instrument I ever heard was an experimental Hammond Model that used BATTERIES to purify the electricity flowing into the instrument. This guy had taken apart a (I think it was a B3) Hammond Organ that had a huge speaker box and Tubes for amplification. I tried to find out why, exactly, but all I could get out of him was something about the electricity is cooler and the tubes lasted much longer. This chap was nearly 70 and could he ROCK that Organ! He would sit and listen to on record after another and play right along with then all! Uh! Record, the kind that you drop a needle on to listen to them. OH! And the turn table sat on a cement piling that passed through the floor into the ground and must have weighed close to 10 tons! He said that was the only way to make sure the needle never skipped! Oh! And this Organ ran 12 volts D/C exactly.
Jul 14, 2011. 11:31 AMaaronadennis says:
Of coarse I understand, it would be very simple to modify your implementation for 6W6GTs and use any variety of more commonly available power transformers. Two 6W6GTs in parallel would yield 20 watts easy.
I like the nature of this website. But it shames me to notice there is not more tube enthusiasm !
I am working on a revision of your design with 6W6GTs and all Edcor transformers looks like its gonna be about $100 in transformers alone. And i respect the nature of your project completely. I am hoping to do a follow up instruction set on how add active bass and treble to your design as well as modify it for 6W6GTs if you have no objections ill start work on that soon.
I suck at making cabinets. So i am grateful for you added that.
Oct 2, 2011. 9:04 AMpfred2 says:
Sorry I can't get into tubes personally. I like solid state!
Jul 15, 2011. 12:56 PMaaronadennis says:
I see i'm looking at 8 watts wit both of them.
Ill note i have seen plate dissapation form 10 watts GE to around 14 for these tubes.. depending on manufacturer.
But your right i grossly over estimated the power output.
Oct 2, 2011. 12:27 AMLenny24 says:
Cool Instructable, but due to Electrical safety you should connect one lead of the Secondary side of the Output Transformer to ground. In case it fails, the Fuse will be blown instead of your Body.
Jul 13, 2011. 9:56 PMjjunglas says:
I'm wondering, where does a person learn the beginnings of things like schematics and electronic? I don't want to be a noob any more. I want to learn. Where can I learn about electronics and wiring and voltage?
Sep 9, 2011. 12:57 PMKidogo says:
google. wikipedia is a good place to start, then use google to help understand the bits that are over-complecated. when youve starred at it enough in loads of different layouts, it should suddenly make sense:)
Jul 14, 2011. 11:45 AMaaronadennis says:
I started out with old radio shack project books. Implementing 555 timers making simple logic circuits. In the front or back of any respectable electronics handbook should be a list of all the symbols and what they represent. If your not into dusty old books I'm positive the Internet has it.
You should definitely learn about voltage and current flow before you attempt anything with tubes.
As an electrical engineer i would suggest trying to reverse engineer simple populated PCBs and create schematics to them try to understand how they work. Avoid surface mounted devices and more than 2 layer boards for the beginning.
If you want to use a very useful piece of software that has no tubes, but can get you started understanding schematics and laying out PCBs.
http://www.cadsoftusa.com/
its cross platform. OSX Linux and Windows.
PS if you don't understand what I'm talking about Google can answer faster than I can. Also a very powerful resource for electronics questions is stack exchanges electrical engineering forum.
May 4, 2011. 10:01 AM14jpm says:
Hi!!
Congratulation for your proyect!!, i like me a lot. Before start I need you that I don´t speak well English I speak Spanish, so, perhaps you find a lot of mistakes in the comment :). I write for two comments, the first, I want share a program with you, its name is ‘TDSL Personal Edition 1.0.1 Duncan Amplification’, it´s a database of vacumm valves. look at!
The second comment, about technical questions , I´m beginner in electronic topics. So I don´t understand which is the capacitance unit (µF,mF,nF,pF,etc.) of red circles, neither resistance unit (kΩ,MΩ,etc) in blue line and finality about audio transformer, I sought its datasheet (http://www.edcorusa.com/products/522-gxse15-4-1_7k.aspx) and I don´t understand which is the correct wiring. So please help me with my questions. Thanks for your time (I image the time that you spent to understand me):)
Dec 3, 2010. 5:20 PMsmartrobot says:
This person had a bunch of boxes on the curb it said free so I took a look, and one of the boxes was full of vacuum tubes. some of them are not labeled so how can I find out what they are?
Apr 8, 2011. 5:17 PMdaniboy79 says:
an old trick a buddy of mine told me works is to stick the tubes in a freezer for a few minutes, then take em out and look for the condensation, it usually doesn't condense on the letters/numbers of the tubes designation. Try it and see if it works ;)
Dec 5, 2010. 2:25 PMsmartrobot says:
I googled the tubes that had letters on them it looks like they came out of a old tv so it does not matter.
Feb 27, 2011. 5:59 PMcnludwig says:
Cool project. I like how you used otherwise unwanted parts (power tubes and transformer) and created a design around it.
Dec 18, 2010. 12:08 AMeridan says:
Very interesting. Thanx a lot!
Dec 2, 2010. 4:29 PMkatatonicdean says:
Alright, thanks for all your help!
Dec 2, 2010. 1:28 AMkatatonicdean says:
Hey,
First off, I was just wondering if this can be converted into a bass amp with an added bass knob.
Secondly, do you know of a place that I can get a similar choke, power transformer, and output transformer?
And thirdly, what pins were used for the tubes? It would be really helpful to know. (I notices that you used the 12ax7 twice, but on the power supply you only had one of the filament pins powered?)
Thanks for all your help!
Dec 2, 2010. 1:48 AMkatatonicdean says:
Oh, and can i use a higher ohm speaker. I was thinking an 8 ohm or 16 ohm speaker. What would I need to do?
Oct 9, 2010. 4:49 PMski4jesus says:
DUDE. that is sooo sweet haha hey btw, i have that sammmeee guitar haha great job!
Aug 10, 2010. 8:57 PMreinovator says:
Thank you for keeping PURE amplification Alive.This is a keeper!! Thank you.
Aug 8, 2010. 4:58 PMrode says:
Very well explained - maybe too well, as those with no experience might be tempted. Nice job overall though - very thorough.
There are a lot of comments about this amp, so I may have missed it ... Using the 7V tap off the main HT winding is a VERY BAD idea, because you can very easily exceed the maximum heater/cathode voltage (which will cause catastrophic failure), and at the very minimum you get hum if there is any leakage.
Just upgrade the wallwart used for the 12AX7 so it can handle all the heaters. All the circuitry operates at hazardous voltages (including the output valve heaters !!!). This is a potential killer - please amend the circuit to use the small auxiliary heater transformer for all valves - both for safety and to protect the heater-cathode insulation.
The position of the standby switch means that as you switch it off, a HUGE voltage spike is generated in the choke because you've just interrupted the current flow. The spike can (and has) damaged the insulation in the choke.
This can be fixed by using diodes (you'll have to work out where they go, it's too hard to describe in a short message).
Single-ended Class-A output stages always have asymmetrical distortion which many guitarists dislike. A disconnected speaker will usually cause the demise of the output transformer (same mechanism as interrupting the current through the filter choke).
Hope this is helpful.
Aug 8, 2010. 10:31 PMrode says:
gmoon,
If you measure the peak and peak+DC between 6DG6GT cathode and heater, you'll find that it is either right at the very limit of the allowable maximum, or may exceed it. This is generally not recommended & that's what I was concerned about.
The safety issue was mentioned because people expect the heater supply to be "safe" low voltage.  Your arrangement causes peak voltages of over 200V on the heater supply.
A properly designed push-pull valve amp will have almost perfectly symmetrical clipping. It's not the Class-A part, but the fact that it's single-ended.  Symmetrical clipping is almost impossible other than within a very narrow range.
There are countless ways to make a valve amp safe (well, safe-ish) with no load, but single-ended output stages are close to impossible to protect.
I rarely make comments on the Instructibles site, but this is an area that I know very well indeed, having designed and worked with valve amps for over 40 years.   Just trying to help ;-)
Cheers, Rod
(see http://sound.westhost.com/valves/ for the info I have available).
1-40 of 314next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
120
Author:gmoon
