Step 1Danger, Will Robinson, Danger!
This is dangerous, high voltage stuff. OK, it's not "High Voltage," technically, but it's high enough to kill you. The power supply in this projects kicks out 200V, which is plenty, with startup spikes near 240V or more...
Don't believe it when they say "it's not the voltage, it's the amperage that kills you"--because it's both. Amps AND volts together dictate the danger level. If it were amps alone, then even a AA battery can supply many times what's needed to stop a human heart. The volts do the "pushing," and overcome the natural resistance of your skin. And there's plenty of current available to harm you in any tube audio amp...
Remember:
--Always drain the power supply filter caps before touching the circuitry.
--Always unplug the mains cord before working.
--Double-check (with a VOM) to be sure the filter caps are drained.
--DON'T mess with this stuff unless you have a decent understanding of the dangers.
--DON'T mess with this if you believe you know EVERYTHING about high voltage, and think that makes you immune to electrical shocks.
The reason a AA battery doesn't kill you is your body provides enough resistance to bring the amps down to a safe level.
That's another way of making my point. For a fixed resistance, increasing the voltage drives more amps. Take any 6V motor, and measure the current draw. Now increase the voltage outside it's operating range, say to 12V. The amperage increases and the motor burns out.
Yes, the amps killed the motor. But it was the extra voltage that drove those amps through the motor coils. So you really need to think about the whole Ohms Law equation, not just amps and not just resistance...
(Plus the transconductance of human skin is not linear--skin shows less resistance as voltage rises, not a linear change dictated by "Ohms Law," but an actual reduction in resistance, which implies that voltage is quite important, too.)
There's more info here, on my amp rebuild project.
-- OR jumper the positive (+) lead of each large cap to GND for several seconds. A jumper with a built-in resistor (10K or so) will help prevent sparks here...
