Step 7The Heater Power Supply(s)
The trannie also powered about 12 tubes, and the filament voltage is ~7v, and doesn't drop enough under load to get near 6.3V (load isn't big enough.) In fact, one 12AX7 "went nuclear" and burned out (~$25 "down the tubes".)
Placing two large diodes in parallel but opposite directions in an AC supply limits the voltage by the voltage-drop amount (.5 to .7V), just the same as one diode in a DC supply. That dropped the filament voltage right to 6.3V, and the tubes were happy.
The two-diode trick works only for AC--current flows through one diode at a time, dropping that half of the waveform by the diode's voltage drop amount. One diode would do the trick for DC.
Plan B
However, they weren't quiet. You really need separate windings to setup a false center tap, which can be used to quiet the heaters.
After trying various solutions, I decided to light just the power tubes with the main transformer, and use a cheap "wallwart" for the 12AX7 preamp. Now the preamp has it's own, "dedicated," DC supply This was very quiet, indeed. The wallwart was already on hand.
A ground reference (false center tap) was provided by bridging the 6V by a pair of 180 ohm resistors, tied to the chassis ground. It does make a difference.
For some power transformers, the required 2.7A @ 6.3V is a little much. Many are rated for 2.5A max. Of course, an extra 200 MA might be fine, depending on the transformer. But a separate DC supply for the preamp isn't a bad option.
OK, this is a little, ehem, unconventional, perhaps even ghetto. But it works well.
comment
Add Comment
Add Comment
