Guitar amp channel switching pedal
This footswitch pedal was created to channel switch my amp as well as bypass the FX. I didn't realize the Vox Valvetronix amp I recently purchased didn't come with a footswitch. Channel switching and FX ON/OFF is accomplished using a TRS (Tip, Ring, Sleeve) input on the rear of the amp.
This is a very simple circuit to build and therefore is a very short instructable.
Step 1Gather Tools and materials
I found a great low-profile enclosure to use for this. You can use anything you desire of course.
Additionally:
(2) Heavy duty SPDT footswtches
(2) 1/4" mono audio inputs (sockets)
A soldering iron and solder
Wires
A multimeter to check continuity (optional)
14 comments
Mar 22, 2010. 3:18 PMjustine3563 says:
can i do it with just one button?i mean i just want to turn the amp's channel on and off..thanks!
Nov 26, 2011. 1:35 PMJ3PPiSH says:
Yes,you can. Just remove one button and the cable between the buttons.
May 23, 2010. 10:23 AMthisonegoesto11 says:
I'm pretty new at this so please excuse my question,...If I have an amp with a clean channel and a distortion channel will this foot-switch switch between the two, my amp doesn't have on-board effects so I could just skip that part couldn't I?
Apr 16, 2010. 2:06 AMjustine3563 says:
the effects bypass,is it for effect pedals or tha amp's effects?
Jan 7, 2010. 8:03 PMHAL 9000 says:
 Awesome!! I have a Peavey Classic 30 Combo that I'll be using this for, though the C30 footswitch does channel switch and reverb on/off. I believe this could be done with a single TRS input on the box, since you're just shorting the L or R to ground when you switch. maybe you already had that cable, i don't know, but still, very cool!!
Also, I was looking at your enclosure, you have a lot of space there, you could easily add some Signal Loops for your FX chain (if you use pedals) and/or FX loop (if you want more from your FX loop than just ON/OFF). It would be a great way to get as much as you can from such a cool little enclosure... Come to think of it, I just might do that when I build one for my C30!!
Again, awesome instructable, you've helped me a lot!! Thanks!!
Feb 5, 2009. 8:33 AMag918w35 says:
I can follow what this box does, but I'm curious to know what signal the amp is looking for. Also, how did you figure this out? Is there a circuit diagram for the Vox jack, or did you just copy an existing footpedal? I ask because I have one of their Valvetronix amps and would like to give this a try.
Dec 28, 2008. 9:42 PMwoodythdog says:
hi I am looking to build a footswitch for my vox amp Would you mind clarifieing the pinout for the 1/4 " stereo plug that goes into the amp?
Dec 2, 2008. 1:22 PMbrian6699 says:
where did you get the heavy duty SPDT footswitches? thanks
Aug 30, 2008. 9:54 AMnavichip says:
i still dont get it....
just the wiring part though
can u explain it a little more plz
=O
or send me photos or sumthing....
thx
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:dentsinger
I am who I am they say, though I know the others really know different.
