3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar amp tilt stand - easy as Lincoln Logs - small, portable, simple, stable, cheap or free.
Guitar amp tilt stand - easy as lincoln logs. small, portable, simple, stable, cheap or free using scrap plywood. Great for combo amps, larger design can be used for open backs.
Step 1Did I say small and portable?
did I say small and portable?
small and portable.
4 comments
Feb 2, 2011. 6:19 PMfenderphil says:
As regards rubber in the slots a cheap way would be to get some old garden hose and split it so it could be placed over the appropiate area's, you could glue it in place or use small tacks. if you only have green hose a paint job as you did with stand would be simple. I was trying to work out the dimensions as I can't afford pro membership just yet. I didn't even have a coke tin to measure ha ha. It is a very neat idea..I was a pro guitarist for over 45 years (Now retired at 68) well done.
Apr 19, 2010. 2:25 PMRichardLewisBarber says:
Works perfectly.
Took me 4 hours to make with a handsaw using some 3/4" plywood I found in a dumpster.
Sanded it a bit, painted it black.
I'm a working guitarist in Hawaii and am already using this stand. It's as solid as a rock.
Thank you so much for your instructions!
Sep 30, 2009. 5:58 PMiamtoats says:
cool, but it seems likely to rattle..... and the cabinet wouldn't couple with the floor too well, and that would effect your low-end. I would glue the stand together, and put rubber on the bottom.... but my cabs are huge, and i can't put them on stands.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:coolandeasy
e-mail: wuddeva@hotmail.com
