Guitar Pick / Anti-slip / Hole-puch-inator
Introduction: Guitar Pick / Anti-slip / Hole-puch-inator
Lets face it, whether you're just getting started or you've been playing guitar for years, occasionally your guitar pick wanders out of position. Remedies for this are wide and varied, so here's another that may just do the trick for you.
Step 1: Materials
Materials include:
-your preferred size, shape, and gauge of pick.
-a hole punch with your desired shape (I play in a Christian praise band at my church, hence the cross).
-Anvil (or other hard surface)
Step 2: Insert the Pick
Step 1: Insert pick into the shape punch. This can be tricky as on this particular punch, the pick would disappear making it very tricky to position the hole exactly where I wanted it. To help with this, you can make a pencil mark on in the center of the pick and then line that up looking at the underside of the punch.
Step 3: A Good Whack
Step 2: Place the punch on the anvil (or other hard surface) and give it a good whack with the hammer.
Step 4: Stuck!
Step 3: The punch may be stuck in place! If this happens, do not be alarmed. Simply use a nail-set, or other similar item to push the punch back into it's starting position.
Step 5: Remove Pick
Finally remove the pick from the punch. You may need to push it out with another pick. Then play to your heart's content with a firm grip on your pick. :)
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    thank you thank you thank you for this idea. I have a favorite style pick that doesn't come with a hole in it. I also use a different style pick that does have a star hole in it but I'm not that fond of the actual pick. you just solved my problem with this idea. punch Is already on order from amazon. thanks again!!
    I've been doing the same thing for years using a regular paper hole punch. I like your use of the cross shape to personalize it.
