Guitar/Mic In Port
Guitar/Mic In Port
ever seen those USB boxes that you connect your guitar into and it gives you a nice little port? Pretty nifty, but a bit pricey. Here one you can make for ~ý1
Step 1What You Will Need
For this, you will need
A 1/8 jack for your guitar, or any other jack you want.
A drill and appropriate bit.
An analogue computer sound cable (mine was from an old CD drive).
Soldering Iron.
22 comments
Sep 22, 2009. 7:31 PMBonejamin says:
If you want to play along with the songs on your computer without disturbing your family or the neighbors, you can do what I did. You'll need 2 inexpensive things: 1. A "Y" cable with at least two 1/8" stereo jacks connected to one 1/8" stereo plug (I used an extra 3-way extension which came with my computer that has one 1/8" stereo plug connected to three 1/8" stereo jacks). 2. A 1/4" female to 1/8" male stereo plug adapter. Plug one end of a guitar patch cord into the 1/4" headphone jack of your guitar amp or direct box (if it has an 1/8" jack, just get another 1/4" to 1/8" adapter, although this adapter doesn’t have to be stereo). Plug the other end of the patch cord into a 1/4" to 1/8" stereo adapter plug. Connect this 1/8" stereo plug and your headphone 1/8" plug into the jacks of the "Y" cable (if you are using one like mine with 3 extensions, just leave the third jack empty). Now connect the 1/8" plug from the "Y" cable directly into your computer headphone jack and jam away! NOTE: It's important to use a stereo "Y" cable and a stereo adapter even though the patch cord from the amp can be mono. Otherwise the mono plug adapter and/or mono “Y” cable will cause the songs and your guitar to only come through one of the headphone speakers. You can certainly use a stereo cable to run from your amp (or direct box) to “Y” cable; but since most amps send a mono signal anyway, and since patch cords are cheap, I went this route.
Apr 18, 2009. 2:32 PMdrigo_kmp says:
It's a nice idea, but you can't just connect a guitar o bass guitar into it. Guitars and such have a high impedance line level and the aux input that sound cards have has a low impedance mic level. This means that you will easily fry something, more likely your sound card. To connect a guitar line to a mic input or low impedance level input you need a devise called "Direct Box" (http://en.wikipedia.org/wiki/DI_unit) that matches the level first (level, not impedance). This is typically used in professional audio to connect guitars or bass guitars directly to a mic input in a mixing console.
And if you want it to be stereo, you need to buy a stereo jack. It's just like the one you used, but it has ground, left and right. That way you don't solder left and right together, which gives you mono anyway.
It will work perfectly for a mic or a mp3, just make sure you don't plug a guitar directly into it though. ;)
Really cool idea, I'll be making one for my computer in a few days.
Sep 29, 2008. 2:28 AMjzellis says:
If your sound card already has a 1/8" input, wouldn't it just be easier to run an 1/8th male to 1/4" female and mount the female end on the front bezel? No soldering required. Though it might be useful to have a gain knob in-line and mounted on the port, to keep people from accidentally plugging "hot" inputs into this and frying the sound card. Cool idea, though, definitely!
Jan 30, 2009. 7:37 PMpbawesome says:
i went to radioshack got a 1/4 to 1/8 and phenominal quality only$1.50 no opening case also works to plug in mp3 player to amp if you dont have 1/8 port on your amp for mp3 in
Jan 17, 2009. 9:53 AMaaronscottaugustinhotmail.com says:
great instructable but 1/8in input jack is your standard head phone / mp3 jack you need 1/4 in jack for guitar cables
Oct 5, 2008. 2:19 PMmadmanmoe64 says:
Long time since I've opened an amp up, how is it easy to put a gain knob in, where could I find out how?
Dec 10, 2008. 2:06 AMshutdown_exploded says:
are you positive you use the reference design? It seems like the output on the little gem would be too much for the soundcard, as it can drive a small speaker itself, I've heard of several people frying their soundcards in similar ways
Sep 27, 2008. 12:27 PMjohnson_steve says:
I hate to be a negative nancy here, but this won't work with a lot of computers. I did this before (with 4 guitar inputs) in this same way. a lot of computers don't have an aux in they only have a cd in and this expects a line level input not a high impendance guitar signal. also feeding a guitar signal directly into a soundcard will result in crappy sound quality as all the emi from the computer gets amplified with the guitar signal. I put a guitar jack like this on my little brothers computer except it has a small pre-amp made from a lm386 (Google 'little gem guitar amplifier') which runs off 12v from the computer psu. this preamp is wrapped in electrical tape and tin foil; the tin foil acts as a Faraday cage blocking the emi from the computer and stopping it from getting into the guitar signal. this results in a very nice and professional sound.
Oct 1, 2008. 9:09 PMUKtheBUNNY says:
If you're really worried about sound quality you can purchase a multi-input card, made for studio use, relatively cheap that has 1/4" jacks. BEHRINGER makes some decent products. Wrapping the unshielded areas with tin foil is a good idea but I recommend using aluminum duct tape. This setup is great if you have something like a Line6 Guitar Pod (I use the bass pod and this setup works great). Anything with a line out will work but you might be able to get away with using an effects pedal as long as you don't crank the levels too high. Someone else asked why not use jack adapters: The jack its self weakens the signal and adapters can only make it worse so using a direct connection may clean up the sound.
Oct 1, 2008. 9:55 PMjohnson_steve says:
I've got a $400 studio card a $100 rackmount preamp a direct in box for the guitars and 4 sure mics to mic up a drumset. all connected to a dedicated headless linux computer (also rack mounted) I'm anal about quality. I build and sell custom guitar amps and effects it is quite possible to make a nice preamp youself and get close to the sound quality of my rig with a standard soundcard. for about $10 and record 2 channels at once.
Oct 2, 2008. 6:46 AMUKtheBUNNY says:
What are you using software wise? I've been using Sonar but I find it very processor intensive.
Oct 2, 2008. 12:08 PMjohnson_steve says:
Ardour on Linux. I canrecord 8 tracks at 24bit digital 96khz at the same time.
Oct 1, 2008. 11:37 PMjohnson_steve says:
BTW: I didn't mean to dis this instructable especially since I doubt I will be able to put together one as detailed and well documented with good pics to boot.
Sep 29, 2008. 10:35 AMPetroleumJelliffe says:
I'm with Roryok. Let's see how to do that!
Sep 29, 2008. 10:41 AMjohnson_steve says:
I think I will. It's going to take me a while as I'm very busy and don't have a camera right now. I have a $400 mAudio sound card for recording but there are probably other people that would like to DIY as cheap as possible.
Sep 29, 2008. 11:11 AMPetroleumJelliffe says:
http://makezine.com/09/crackerboxamp/
The little gem was used to make the crackerbox amp in Make issue #9, I believe.
Sep 29, 2008. 4:14 AMroryok says:
@ johnson_steve Would you be willing to post your own instructable on how to do this? it would be a cool addition
Oct 1, 2008. 5:54 PMsound91 says:
in step 5 you said that you soldered the left and right together to get stereo, but in reality you just made your signal mono.
Sep 30, 2008. 10:12 PMNoodle93 says:
The reason why people buy those little 'USB boxes' is because they have a built-in sound card designed for guitars. Most soundcards built into computers are pretty cheap and pretty much just for a cheap little microphone to talk with.
Sep 27, 2008. 11:37 AMwazupwiop says:
cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:btop
