Gumball Machine Fishtank
5,024
143
13
Posted in HomePets
Introduction: Gumball Machine Fishtank
About: Maker from USA. Follow me to stay up to date on my projects and possible kickstarters! Business email: constructed@mail.com
Do you have a old gumball machine hiding around your house? Instead of an ugly unused , why not recycle it into a fish tank that's perfect for your desk! Inspired by many pictures of strange fish tanks I decided to create a tank that would look good wherever it was placed. The result was a fish tank inside a gumball machine.
This gumball machine is the perfect house for a betta fish or any other small caged aquatic animal. If you enjoyed this instructable, Please vote.
Step 1: Supplies
For this project you will need
  1. Gumball Machine
  2. Glass
  3. Aquarium Sealant (cannot use regular silicone or the fish will die)
  4. Sharpie
  5. Glass Cutter
That's all you need!
Step 2: Take Apart
Start by taking your gumball machine and taking it apart. Not all gumball machine are the same so I will list the general steps
  1. Unscrew the lid
  2. Take bowl off
  3. Unscrew and discard the plastic pieces inside
  4. Clean
  5. Put back together excluding the plastic pieces
Step 3: Draw Circle
Flip the bowl upside down and draw a circle around the base of the bowl. Trace the side that is the opposite of the lid.
Now you can see the basic idea is that the circle will fit into the bowl and seal the water.
Step 4: Cut Circle
Using a glass cutter, cut out the circle.
The trick to this is to keep making cuts. Each time slowly put more pressure onto the cutter. After a while you can simply peel the glass around the circle off.
Once the circle is off, Sand so that it fits very tightly into the bowls base of the gumball machine.
Step 5: Seal
Place the glass circle into the bowl and seal off using the aquarium sealant. Now reseal it again so it completely seals the water into the bowl
You should now place it in a well ventilated area to let it dry for one day.
Step 6: Test
Fill with a small amount of water and see if it holds for 1 hour. Now fill with more water and see if that holds for 1 hour. If it has passed fill it all the way and let it test for 1 day. If no water has leaked your gumball machine can now hold water!
Step 7: Finish
Your Done! Just fill with water and your new fish tank is complete! The only thing that you need now is a fish and since this is a pretty small tank, your pretty much limited to 1 betta fish.
Now place your tank anywhere you want!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Spotless Contest
      Spotless Contest
    13 Comments
    OHHH! I'm totally sorry, in the first photo the tank looks tiny!
    In the next few photos the tank looks HUGE!
    Sorry about my previous comment.
    Keep shining!
    Thank You, Finally someone agrees with me!
    Don't you need a bigger tank and a filter?
    It looks cool but it is rather cruel.
    Sorry, I prefer NOT to be negative!
    You seem creative, why not
    a bigger tank out of a seemingly useless object?
    i absolutely agree, it's cruel.
    to those who don't agree: if you were a fish, would you like to be the one fish put in such a tank with no plants, no other fish? i don't think so.
    so please stop tormenting animals.
    1) My fish loves it.
    2) This tank holds around 3.5 Gallons. The minimum is 2. This tank is MASSIVE compared to the tank I purchased it it (see picture below)(not mine)
    3) Two male betta fish in the same area will fight over territory until a clear winner. In the wild, the loser can swim off, In a tank it will be killed by the winner with no escape. Thats cruel. If your going to criticize someone, at least know what your talking about.
    Research here. http://www.bettafish.com/showthread.php?t=20058
    Your calling my tank small? (not my picture) Here is how they are shipped
    Actually its slightly larger then most betta tanks and it holds gallons more then the tiny cage it same in.
    While it might be cruel to put a goldfish or any other larger fish in this, a small betta would be perfectly fine in a cage this size.
    can goldfish survive in it ? I have an old gumball machine & fish coupon, so. lol.
    Probably not, Goldfish need a little more room
    Just a normal steel wheel glass cutter
