The very substance of the Gummi Bears is tricky stuff and if you want to be able to identify a tumor and have it removed you need an expert. Someone you can trust. Someone who's been there.
To get a better grasp of this hidden world of Gummi surgery we talked to an expert in the field who was happy to demonstrate his techniques for us.
NOTE: This Instructable contains graphic images of Gummi Bear surgeries. Like the one right below. Gross, right?
Remove these ads by
Signing UpStep 1Get patients and tools
Fortunately, most Gummi Bears are hypochondriacs so even if they don't have a problem right away you can usually convince them to go under the knife in less than a minute. There might be some ethics problem here, but we couldn't think of it and moved on to the slicey dicey fun.
Make sure you have a clean scalpel and metal tubing available. The second picture shows the exact knife you shouldn't use. Dried Gummi gore should be wiped off with a paper towel or you can replace the whole blade. Don't use your tongue to clean! Is bad!
THAT'S WHAT SHE SAID!!
i would get a gummy worm and remove itts brain to the screamin g gummy bear then it would be quiet dahh......'
2. put it in the oven
jeez,im 13 and i cant spel.
I love it!
EPIC FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
