Gumstix: GPS Stix Active Antenna Modification
The GPS Stix Daughter board for the Gumstix comes set up for passive antennas only. In order to get it to work with a passive antenna you need to make a small (perhaps a little too small) modification.
Step 1Cut the trace from the antenna plug to Pin 19
Take a sharp exacto knife or razor blade and cut througth the copper trace between teh antenna mount and pin 19. BE CAREFUL there is another trace that goes to pin 17 which should not be cut. Use a multimeter to test continuity between the antenna post and the pin. There should be no continuity if you did it correctly.
3 comments
Jun 21, 2008. 12:08 AMdishanker says:
Useful piece of info. Thanks. Any suggestions on where other software usage resources with the gumstix hardware are found. gumstix.net and its wiki is not that interesting at this moment :-).
Aug 7, 2006. 10:11 AMJohntron says:
It needs proofreading and more pictures, but still a good article.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:afosterw
