3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gumstix: GPS Stix Active Antenna Modification
Step 7Solder the other end of the resistor to VCC
Check that everything is lined up. If it isn't and you only need to make a small correction (1 mm) then VERY CAREFULLY bend teh resistor wire. I would suggest using to pairs fo pliers to do this. One pair to hold the resistor and the point of the bend and another to do the bending. This should protect the soldering point at pin 19 from damage. If you are off by more than 1mm or so I would suggest heating up the solder point at pin 19 to make the adjustment.
Once you are all set solder the other end of the resistor to VCC.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:afosterw
