3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gumstix: GPS Stix Active Antenna Modification
Step 8Test it out!
Screw on your antenna and fire up the gumstix! Do a cat /dev/ttyS2 to view the raw GPS data stream. How do you knwo if it worked? do a cat /dev/ttyS2 | grep GPGGA to just see the GPGGA sentences (They contain time, latitude, longitude, ebaring and some other stuff). If the GPS isn't seeing any satallites you will see something like:
$GPGGA0,00,99.99*48
Don't dispair yet, make sure that the antenna has an unobstructed view of the sky, this is important! Let it stand for a few minutes. If nothing changes then go back and check for short circuts or broken connections. If it worked you should start seeing stuff like this:
$GPGGA,141812.00,4221.7816,N,07105.9727,W,1,03,2.45,00033,M,-033,M*59
HUZZAH you have a lock and your location is 4221.7816 North longitude by 07105.9727 West latitude!
1 comment
Jun 21, 2008. 12:08 AMdishanker says:
Useful piece of info. Thanks. Any suggestions on where other software usage resources with the gumstix hardware are found. gumstix.net and its wiki is not that interesting at this moment :-).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:afosterw
