3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gun Camo
Gun Camo
These are a few methods of camouflaging with spraypaint. Remember not to spray to much, as this will cause runs and blemishes. It is a good idea to practice aiming on some card board or something before you start.
There are many deviations of the methods I will give, but they all follow the same concept of how they are done. Camo essentially consists of layers of colors in different patterns. in this case, each layer is applied using masks or stencils to create patterns.
It is also important to make sure paint doesn't get anywhere that could damage the gun. Use painters tape or masking tape to cover these parts if they cannot be removed. You should tape orange tips, joints, and holes that lead to the inside of the gun.
Step 1Stencils
Stencils
The method of using stencils involves putting something on the surface to keep paint off certain sections then spraying the entire surface with one color. They are not removed after each coat of paint. The colors will appear to be stacked in the order of application(eg. first color on top to last color on bottom)It is important to apply the stencils so that they are flush with the surface so that they do not let in any paint. Stencils can be applied either by spraying the back with some kind of adhesive or using tape.
56 comments
1-40 of 56next »
Jul 13, 2010. 3:41 PMcdousley says:
you should paint that awful orange tip!
Aug 1, 2010. 8:28 PMTorpe says:
Um, it's illegal in America to paint over or remove the orange tip on an airsoft gun.
May 23, 2012. 2:10 PMowlart101 says:
Um, actually, check with state laws and county laws first. Where I live it is perfectly legal. My entire squad runs with metal flash hiders.
Aug 3, 2010. 8:24 PMcdousley says:
(removed by author or community request)
Nov 11, 2010. 2:31 PMmonsterman2212 says:
Nov 12, 2010. 7:38 PMcdousley says:
canadian gun laws?
But i do have one gun i keep the tip on because it looks real.
Feb 13, 2011. 6:52 PMcdousley says:
i got some new airsoft guns and they look pretty realistic they could easily be mistaken for the real thing
Jan 5, 2012. 4:31 PMgmattison says:
ur not the only one with realistic guns. me with my 1911 and all of my friends have very realistic guns but we hate orange tips. we even play at a professional course and team and they highly recommend that u dont use the orange tips
Feb 15, 2012. 3:37 PMcdousley says:
If youre somewhere around a lot of people you really need them, but if youre playing on a pro course the orange would just make you easier to spot.
Apr 22, 2011. 11:49 PMthing 2 says:
How'd you get the top weaver rail off?
May 11, 2011. 7:59 AMthing 2 says:
Thanks!
Apr 13, 2011. 3:41 AMHitman227 says:
...? the commment i posted on my backup account got flaged?
Jan 31, 2011. 12:21 PMthing 2 says:
What brand is the G36c?
Feb 14, 2011. 7:18 PMthing 2 says:
That's the one I'm saving up for!
Feb 7, 2011. 7:16 PMkve23 says:
i love that camo job =)
Jul 17, 2010. 9:56 PMMadBricoleur says:
i<3UTGM324!!! :)
Jun 9, 2010. 12:05 PMarb1ter says:
A little Hint. Im not trying to be mean but don't mix the different kind of Camos it looks stupid just go with one kind for through out the hole gun
Apr 15, 2010. 9:00 AMNeovenetar says:
 how much does one of those snipers cost?
May 25, 2010. 8:02 PMtubanator-2.0 says:
that one is the gen 3 utg sniper if i  am correct i recently got my gen 5 for around 130 or so and it came with scope and 5,000 rounds .2 with out the scope it around 90 quids also the gen 5's fps is around 450 fps with .2's of course
Apr 11, 2010. 6:42 PMairsoft sniper 655 says:
i have that same sniper its pretty good
Jun 9, 2009. 3:42 PMDL Sloth says:
Thats awesome i'll try that on my M4A1 btw do you know how to make or but a vertical handle for an M4 carbine or where to buy a rail system? P.s. nice sniper i used to have one just like it.
Jan 27, 2010. 9:39 AMdjlewis725 says:
go to
airsplat.com they have tons of stuff.
Jul 17, 2009. 9:17 PMinventor1488 says:
when it comes to RIS systems, if you're talking about the front end of your gun- thats like $140, my friend just got a price quote on the same gun at an airsoft specialty store in Sacramento. You may be able to get em cheaper, but the are a HUGE pain to install, if you're confident with your self around power tools, you would mod the front end and attach them yourself, they can run you as cheap as $20 used $40 new.
Jul 16, 2009. 2:27 PMVertigo666 says:
Airsoft GI.
Dec 5, 2009. 1:41 PMThundertydus says:
Hey, On your bottom Airsoft Rifle, can you please be a bit more clear on the steps?
My interpritation of what you are saying is that I paint it one tone, then stripes of the next, then lay down foilage THEN paint?
Please help, I'm doing a snow camo scheme (Main color:White, Second color: grey, third color: dark grey)
Please give me some steps to follow
Oct 18, 2009. 6:25 PMairsoft pro says:
 coooooooooooooooooooooool
Aug 2, 2009. 5:36 PMGunUdown says:
Sweet instructable... I have the 2 exact same guns as you the g36 and m24 sniper
Jul 20, 2009. 5:21 PMalbylovesscience says:
whats with the uzi is it a airsoft gun
Jul 18, 2009. 8:41 AMRaiden97 says:
SWEET i put this on my m16!
Dec 8, 2008. 6:38 PMsuperquack11 says:
on the G36C, does it have good accuracy?
Jul 17, 2009. 9:29 PMinventor1488 says:
you can get a G36K, its midway between the C and full length G36, I have a tight bore in mine and it outranges a M324 and is more accurate when using .23s or heavier. And for all those M324 owners, google "teflon mod", +80 FPS, very useful on M324s that have lost some of their kick over the years
Jun 13, 2009. 12:58 PMWolf Seril says:
If you look closely at true digital MARPAT or ACU, you'll notice that the squares aren't even. The point of that camo is it can disrupt your vision and depth perception, because you think the squares are even when they really aren't. In other words, using graph paper won't work. If you're just doing it for looks, thats fine, but if you want it to be realistic, either trace stencils from some fabric, or just find an image of MARPAT from the internet, print it out, and use that. Otherwise, good 'ible and paint jobs. G36c FTW.
Jun 11, 2009. 9:25 PMMadBricoleur says:
oooh is that a utg m324 i see in that bottom pic? awesome! i love that gun. i have an army digi camo one so i dont need to paint it but if it wasnt camo already then i'd paint it using this GREAT ible. :D
Jun 1, 2009. 7:25 PMthe "wow shammy" says:
this looks so awesome!!!!!!!
Feb 16, 2009. 9:44 PMNamasteNick says:
on the tiger stripe i dont get how you stenciled out the brown.. please get back.
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Molybdenum(Mo's Airsoft Shenanigens)
