Introduction: Airsoft Camo Suit
this is great for airsoft/paintball or even hunting, and super cheap!
Step 1: First
what you will need;
-a pair of scissors
-a large needle
-large string/wool (camo colors)
-and a large piece of como burlap (now i know this is hard to find but i went to wholsale sports, and i'm sure any large outdoor sports stores will carry these, there designed for duck hunting to set up a blind and will cost about 15-20$ and this can make two)
-and 4-6 safety pins
Step 2: Second
so what you want to start doing is lie on your burlap sheet so that on edge is far enough away from your body to put your arms by your sides once you have that you have your width, now to get length stay lying but move forward so that your head is sticking over one edge there has to be enough room for the distance you want between the bottom and your feet and the height of your head from your shoulder. Now cut down the middle and fold over you body so that your wearing it like a poncho and thus to have a poncho cut a hole in the top for your head. (sorry its kinda hard to explain but i think you will get it)
*NOTE IMPORTANT if this clarifies anything your basically making a poncho that is attached at the sides
Step 3: Third
now that you have your cut you can fit it to your body with safety pins dont worry about over lapping to tighten the fit.
*NOTE IMPORTANT dont pin it to tight or you wont be able to fit it past your shoulders.
Step 4: Forth
now that you have your body you need a hood/ texture. I got a long rectangle left over from fitting it to the proper height and folded two of the corners and sowed them together and then took the pointy tip left and folded it down and sowed it to the hood now since its so long I cut the back into strips and gave it texture since that will lie on my back.
Step 5: Fith
the finished product!
i thought i might mention that after i was done i cut a lot of triangles into the body and hood but don remove them keep them attached to make it look like leaves. (also if you didnt notice you need a long sleeve shirt i camo color green?)
