Tools:
An adequately sharpened pencil
Ruler
Piece of string at least 16" long
Thumb tack
Staple Gun and staples
Gaffer's/Duct Tape
A drill
Box of 3" and 1 5/8" screws
Circular saw or Chop saw
Jigsaw
Sawsall
Sanding device (I used a Metabo Compact sander with a rough sanding stone and 220 grit sandpaper)
Supplies:
Two sheets of 3/4" plywood 24" x 24" (~$6 from Home Depot)
4' of 4" x 4" (7' piece ~$7 from Home Depot)
12' of 2" x 4" (7' pieces ~$6 from Home Depot)
24' of 2" x 6" (8' pieces ~$6 from Home Depot)
12' x 1' of outdoor carpet (~$19 from Lowe's)
36" x 9' of rubber carpet padding (would've been $38 from Lowe's, but it had a couple holes and I was given a half-off discount, schyeah!)
4' x 4' of vinyl fabric (faux leather, you can get it cheap by the yard from a fabric distributor)
Cost:
Since I already had all the tools I needed except for some screws, this instructable cost me approximately $90, which is by no means cheap, but if you search for them online they sell for anywhere from $250-$400.
Note: When completely finished this sucker weighs....a lot. I would assemble it where you plan to use it, and if you absolutely need to move it, turn it on its side and roll it. I am not responsible for any bodily harm including hernia, constipation, rug burns, or shattered expectations resulting from performing the outlined steps or while using the mushroom. Play safe.
Remove these ads by
Signing UpStep 1Cut the base and top out of plywood
2. Measure the length of the string to 12".
3. Use a thumb tack to fasten the string to the center of the piece of plywood.
4. Pull the string taught while holding the pencil and draw a circle on the plywood.
5. Using the jigsaw, cut the freshly drawn circle from the plywood.
6. Repeat steps 1-5 for the remaining piece of plywood.
what's nice about the faux-leather vinyl is that it's not slippery, unless wet (something to consider if your hands sweat a lot), it's cheap so it's trial-and-error friendly, and it holds up to harsh weather. i've had mine outside all winter and the snow and rain aren't a bother.
take a trip to a fabric store and feel it out, maybe you'll find something you like better.
I'm not sure how to make the adjusting base so you can change the hight. I'm thinking maybe welding a frame out of steel tubing and then having a outer and an inner peice with a a hole drilled in the outer peice and a nut welded over the hole. Then a few holes drilled in the inside peice and a nut welded over each hole. Then you can lift and lower the pommel horse and then screw a bolt through the two nuts to determine the height. The pommel horse design is a rough design, I didn't hollow it out at all because i can't remember how wide the handles are and things and i haven't fully desided how it is all going to go together.
my only criticism would be to use thicker planks of wood than 1". only cause it would probably be quicker to fabricate, probably would be sturdier with thicker pieces and less chance of warping. all speculation though.
how did you mock up that design graphically?
when you finish it, please post a link in your comment to the instructable. looking forward to seeing how it materializes.
good luck!
