Introduction: HC-08 Bluetooth UART Communication Module V2.4 User Guide
Picture of HC-08 Bluetooth UART Communication Module V2.4 User Guide
Product Introduction
Bluetooth Modem - Minimum Pass-through Module HC08 is a new generation data transmission module based on Bluetooth Specification V4.0 BLE protocol. Its wireless working frequency band is 2.4GHz ISM with GFSK modulation method. The maximum transmit power is 4d Bm. Its receiving sensitivity is -93d Bm. In the wide open environment, it can reach 80m super long-range communication with iphone4s. It has integrated stamp package holes and pins welding holes. You can both mount package and weld pins. It is very convenient to be embedded into the application system. With built-in LED indicator, you can visually see the connection status of Bluetooth. This module adopts core CC2540F256 configured 256K bit. It supports AT commands. Users can change roles(master/slave mode) as well as parameters like Baud rate and the device name according to their own requirements. It is very flexible to use.
Step 1: Product Size
Pin definition
The HC-08 module has 30 pins on board. Specific definitions of pins are listed in the following table:
Step 2: Pin
Pin
Definition
I/O
Explain
TXD
output
UART output, 3.3V TTL level
RXD
input, weak pull up
UART input, 3.3V TTL level
NC
4
NC
5
NC
6
DC
input
Debug clock
7
DD
Input/output
Debug data
8
PIO20
input, weak pull up
NC
9
PIO17
input, weak pull down
NC
10
PIO16
Input, weak pull down
NC
11
RST
input, pull up
Module reset pin, a low level of not less than 10ms reset
12
VCC
input
Power pin, the requirements of 3.3V DC power supply,
the supply current is not less than 100mA
13
GND
Ground
14
LEDCON
input
LED control pin(Note3)
15
PIO14
NC
16
PIO13
output
LED output(Note1)
17
PIO11
NC
18
PIO12
The master module clear memory(Note2)
19
PIO10
NC
20
PIO07
input, weak pull up
NC
21
USB_D-
NC
22
USB_D+
NC
23
PIO06
input, weak pull up
NC
24
PIO01
input, weak pull up
NC
25
PIO15
NC
26
PIO00
input, weak pull up
27
VCC
input
28
GND
Ground
29
RXD
input, weak pull up
30
TXD
output
Step 3: Note 1:
PIO13 indicates LED output pin, high level output. Please connect LED with resistance in parallel.
Before Connection:
When the master module do not record the address of the slave module, it will illuminate for 100ms per second;
When the master module record the address of the slave module, it will illuminate for 900ms per second;
In the slave module, LED illuminates for 1 second between every 2 seconds.
After connection: LED lights are always illuminated.
Note 2:
Input pin, internal pull-down. This pin is connected to the high electric level. The master module is used to clear the recorded address of the slave module.
Note 3:
Input pin, be used to control the LED. If this pin is grounded, LED off. If this pin is left hanging, LED on.
Step 4: Electrical Characteristics:
Parameter
Test Condition
Representative Value
Working Voltage
DC2.0V~3.6V
Master
not connected / connection
21mA/9mA
Working Current
MODE0, not connected / connection
8.5mA/9mA
MODE1, not connected / connection
340μA/1.6mA
(not LED)
Slave
MODE2, not connected / connection
0.4μA/1.6mA
MODE3, not connected / connection
1.2μA-160μA/1.6mA
Step 5: Manual AT Command
AT command is used to set module's parameter. Before connection, module can operate under AT command. After connection, it enters into serial port transparent transmission mode.
The startup time of this module is about 150ms. So it is better to operate AT command after being powered on for 200ms. Unless otherwise indicated, the parameter setting of AT command is effective immediately. At the same time, the modification of parameters and functions will not be lost once power off.
After the successful modification of AT command, it uniformly returns to OK (Except for information checking commands such as "AT+RX, AT+VERSION"). No success achieved, it will not return to any information.
⑴ AT Command List
AT Command
Function
Default
Role
("x"- parameter
AT
Test command
M/S
AT+RX
Check the basic parameters
M/S
AT+DEFAULT
Restore factory setting
M/S
4
AT+RESET
Reset the module
M/S
5
AT+VERSION
Check version and date
M/S
6
AT+ROLE=x
Change master/slave role
S
M/S
7
AT+NAME=xxxxxxxxxxxx
Revise name
HC-08
M/S
8
AT+ADDR=xxxxxxxxxxxx
Revise address
Hardware
M/S
address
9
AT+RFPM=x
Revise RF power
0(4dBm)
M/S
10
AT+BAUD=x,y
Revise UART baud
9600,N
M/S
11
AT+CONT=x
Set connectability
0(Can be
M/S
connected)
12
AT+MODE=x
Set working mode
S
13
AT+AVDA=xxxxxxxxxxxx
Change the broadcast data
S
14
AT+TIME=x
Mode 3 broadcast cycle
5(s)
S
The master module to clear
15
AT+CLEAR
the slave module address
M
have been recorded.
Note:
1. The AT command behind no newline; if no special instructions, all AT commands are not transmitted using newline.
2. The last 4 senior commands, must be used in combination, can play its due role BLE Bluetooth low energy. Using a Bluetooth low energy, there will be special instructions and program introduced in the following sections.
Step 6: Command Explain
1.Test command
Command:AT
Return:OK.
  1. Check the basic parameters
View the basic parameters such as Bluetooth name, master/slave role, UART baud rate, address and password.
Command:AT+RX
Return:
Name:HC-08 -------->>>> bluetooth name
Role:Slave -------->>>> master/slave role
Baud:9600,NONE -------->>>> UART baud rate
Addr:xx,xx,xx,xx,xx,xx -------->>>> bluetooth address
PIN :000000 -------->>>> bluetooth password
Note: Temporarily does not support change password!
  1. Reset to default
    Command:AT+DEFAULT
    Return:OK
    The module will automatically restart, please carry out new operation on the restart 200ms!
  2. Reset the module
    Command:AT+ RESET
    Return:OK
    The module will automatically restart, please carry out new operation on the restart200ms!
    5.Check version and date
    Command:AT+ VERSION
    Return:HC-08V2.0,2014-08-22
    6.Change master/slave role Set
    command:AT+ROLE=x Query
    command:AT+ROLE=? X:role(M or S),
    M:master; S:slave. Default setting is S(slave).
    Send:AT+ROLE=M
    Return:OK
    Set master role,the module will automatically restart!
    Send:AT+ROLE=?
    Return:Master
    You can view the role is the master module.
  3. Revise name
    Set command: AT+ NAME=xxxxxxxxxxxx
    Query command: AT+ NAME=?
    Default name is HC-08, you can set the other name (Valid within 12 characters, support the visualized ASCII code and part of the escape character. The module supports chinese, but android devices must be converted to "UTF8 code" in order to display normally. More than 12 characters, then it will read the first 12 characters only.). Setup is complete, effective after module automatically reset!
    Example:
    Send:AT+NAME=HCKJ
    Return:OKsetNAME
    Send:AT+NAME=?
    Return:HCKJ
    8.Revise address
    Set command:AT+ADDR=xxxxxxxxxxxx
    Query command:AT+ADDR=?
    The address must be 12 bit "0~F" uppercase characters, namely hexadecimal characters.
    Example:
    Send:AT+ADDR=1234567890AB
    Return:OKsetADDR
    Setup is complete, effective after module automatically resett!
    Send:AT+ADDR=?
    Return:1234567890AB
    Send:AT+ADDR=000000000000
    Return:OKsetADDR
    Send "000000000", module to restore the default hardware address. Module factory default is hardware address.
    9.Revise RF power
    Set command:AT+RFPM=x
    Query command:AT+RFPM=?
    X:RF power,as shown in the following table:
    Parameter
    RF power
    View the current RF power
    4dBm(default)
    0dBm
    -6dBm
    -23dBm
    Example:
    Send:AT+RFPM=2
    Return:OK
    RF power modified -6dBm.
    Send:AT+RFPM=?
    Return:-6dBm
    RF power is -6dBm.
    When peak current is more than 30mA (when RF power is 4dBm) and the current of button batteries is small(under 20mA), if we want to charge with the button battery, we'd better set the RF power to be -6dBm or -23dBm.
    10.Revise UART baud rate
    Set command:
    AT+BAUD=x(Only modified the UART baud rate)
    AT+BAUD=x,y(Modify the UART baud rate and parity bit)
    Query command:AT+BAUD=?
    x:UART baud rate,y: parity bit, As shown in the following table:
    Parameter
    UART baud :x
    Parameter
    parity bit :y
    View the current baud rate
    1200
    1200bps
    N
    No parity
    2400
    2400bps
    E
    Even parity
    4800
    4800bps
    O
    Odd parity
    9600
    9600bps(default)
    19200
    19200bps
    38400
    38400bps
    57600
    57600bps
    115200
    115200bps
    Example:
    Send:AT+BAUD=19200
    Return:OK19200
    UART baud rate modified for 19200bps.
    Send:AT+BAUD=4800,E
    Return:OK4800,EVEN
    UART baud rate modified for 4800bps,and even parity.
    Send:AT+BAUD=?
    Return:4800,EVEN
    View UART baud rate and parity bit.
    During master and slave module transparent transmission, each packet under 9600bps baud rate must not exceed the maximum number of 500 bytes. As for each packet with baud rate above 19200bps, please refer to the following table. Between data packets, it must have a certain time interval. The following table is a variety of communication baud rates, the reference value for the time interval :
    baud rate (bps)
    1200
    2400
    4800
    9600
    19200
    38400
    57600
    115200
    500 bytes time interval (ms)
    6800
    3600
    2000
    1000
    300 bytes time interval (ms)
    4200
    2400
    1200
    600
    400
    100 bytes time interval (ms)
    1500
    800
    400
    160
    100
    120
    80 bytes time interval (ms)
    1000
    650
    320
    120
    80
    60
    100
    60 bytes time interval (ms)
    800
    500
    250
    100
    60
    60
    60
    100
    20 bytes time interval (ms)
    200
    100
    50
    20
    20
    20
    20
    20
    1. The above is the measured data. The theoretical fastest total transceiver speed: 2500 bytes/sec, with the speed controlled within 2000 bytes/sec.
    2. Bytes of each packet shall be an integer multiple of 20.
    3. Module sends automatic subcontracting data is an integer multiple of 20 bytes. It is used to send a 100 bytes packet, and it will receive a plurality of packets at another end. Each data packet is an integer multiple of 20 bytes. The total number of bytes is 100.
    11.Set connectability
    Set command:AT+CONT=x
    Query command:AT+CONT=?
    The X parameter functions are as follows:
    Parameter
    Master Role
    Slave Role
    Central
    Peripheral
    Can be connected, the connection
    (Default)
    after entering ordinary transparent
    transmission mode
    transmission mode
    Observer
    Broadcaster
    The module can not be connected
    Not connected with the master role,
    to other equipment, but will auto-
    but can be combined with low power
    matically scan the HC-08 from the
    mode 3, the realization of broadcast
    broadcast datamachine package,
    packets send.
    fixed 2sec refresh time.
    Example:
    Send:AT+CONT=1
    Return:OK
    Send:AT+CONT=?
    Return:Non-Connectable
    The command please with "AT+MODE", "AT+AVDA" and "AT+TIME" command with the use of.
    Note:
    1. The master/slave module "CONT=1" is mainly used for transmitting broadcast data. Sending broadcast data from the slave module, the master module will receive the corresponding data through the serial output.
    2. This model is for the user to grab this broadcast data package by himself only. The specific communication protocol is not described here. If you want to know, please visit the following official website for consultation:
    http://www.hc01.com/
Step 7: 12.Set Working Mode(Only Slave Module)
Set command:AT+MODE=x
Query command:AT+MODE=?
Command
Parameter
Return
Function
0/1/2/3
Gets the current mode.
=0
Full power mode (default), LED open.
Level 1 power saving mode,LED close.
=1
No connection the current is 340μA, the connection
speed like mode0.
Level 2 power saving mode,LED close.
=2
No connection the current is 0.4μA.
AT+
Can not be found, not connected to wake up
MODE
OK
before, after awakening can be connected.
Level 3 power saving mode,LED close.
No connection the current is 1.2μA~160μA(about
32μA default).
=3
Combined with " AT+TIME" to set the broadcast
time, thus to reduce power consumption.
The use of specific methods please refer to the
"AT+TIME" command.
Note:
  • Mode 3 is mainly used for:
    A. Used to reduce the power consumption.
    B. The slave module send the broadcast data to the master module, can achieve one-way communication of one to many (theoretically it can be from a slave module to infinite master module).
    C. As anti-lost alarm, attendance card, heart rate meter or other wireless device.
    2. Mode 1/2/3 are available through the UART port to send 1 byte data to wake up, but front few bytes of data may be garbled after wake up. Therefore we recommend sending 10 bytes hexadecimal code of "0xFF, 0xFF, 0xFF, 0xFF, 0xFF,0xFF, 0xFF, 0xFF, 0xFF, 0xFF" to awaken the module, avoiding the front several data byte might be garbled. Since then, modules work on the full speed mode, the UART port can be normal to send and receive data.
    Under the unconnected status, module after being awakened into full speed mode, which maintains for 5 minutes, and then return to the original mode. As long as 5 minutes in the UART has received data, then retiming.
    If the module is in the connected state, then after awakening, it will remain in the full speed mode. Before connection, module will return the original power mode.
    3. In addition to mode0, the other mode is to close LED. But after connection, LED will be lighted.
    Example: Send:AT+MODE=?
    Return:0
    View the current mode.
    Send:AT+MODE=2
    Return:OK
    Setting mode 2, effective immediately.
  • Change the broadcast data(Only slave module)
    Command:AT+AVDA=xxxxxxxxxxxx
    Parameter "xxxxxxxxxxxx" can be any 1~12 bytes user data. If at this point the
    master module state of AT+CONT=1, then the master module UART port will output the "xxxxxxxxxxxx" data. The broadcast data will not be preserved permanently. It will be deleted after restart.
    Example:
    Slave role send:AT+AVDA=1234567890AB
    Return:OK
    If at this point the master module state of AT+CONT=1, UART port will output:12345 67890AB.
    14.Mode 3 broadcast cycle(Only slaver)
    Set command:AT+TIME=x
    Query command:AT+TIME=?
    Parameter x setting range is as follows:
    x
    5
    6
    7
    8
    9
    A
    B
    C
    D
    E
    F
    time/
    5
    6
    7
    8
    9
    10
    20
    30
    40
    50
    60
    sec
    (default)
    x
    F
    G
    H
    I
    J
    K
    time/
    10
    30
    60
    min
    Example:
    Send:AT+TIME=F
    Return:OK
    Setting mode3 of the broadcast cycle for 60 seconds. Every 60 seconds, send a broadcast data.
    Send:AT+TIME=?
    Return:60s
    Solution of low power mode (slave module):
    1. The need to wake on wireless:
    Enter "AT+MODE=1" or "AT+MODE=3", the module will enter a low power mode until the master module request connection. After the connection, the current is 1.6mA. Data exchange module will automatically enter the full speed mode before connected, while after connected, it will return to the low power mode.
    2. Can active connection case:
    Enter "AT+MODE=2", it will enter a low power consumption mode2. The module entered the deep sleep state. It can not be discovered by master module. When you connect, you can send arbitrary data to awaken the module, and then it can send and receive data once connected .
    Solution of low power broadcasting mode:
    The first set master role:AT+CONT=1 -> AT+ROLE=M
    And then set slave role:AT+CONT=1 -> AT+AVDA=1234(≦12Bytes data)
    The users' MCU send 10 bytes hexadecimal code of "0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF" to the module of UART port in order to awaken the module into the full power mode. At this point, users can reasonably set according to their need. The above "AT+CONT=1, AT+AVDA=xxxx, AT+MODE=3, AT+TIME=5" is set to: "broadcast and can not connected". The broadcast data is XXXX, mode3(period of 5 seconds). According to the above, the average current is less than 4 μA, TIME will be more than 1 minutes. Longer this time, lower power consumption it will have.
    The user wants to transmit data frequently, proposed to enter mode2 in idle time, need to transmit data to switch to the corresponding mode.
    15.The master module to clear the slave module address have been recorded (Only master)
    Set command: AT+CLEAR
    Query command: OK
    The master module, once connected with the slave module, will remember the MAC address of the slave module in the last time. If you want to connect it to the other slave module, you must remove the current memory. The first way is to put the module 18 pin to high electric level of 200ms, the other way is to use the "AT+CLEAR" command.
Step 8: Reference Schematic
Step 9: Source
This article is from: https://www.elecfreaks.com/11565.html
If you have any questions, you can contact: louise@elecfreaks.com.
About This Instructable
277views
2favorites
License:
Bio: ElecFreaks is an open design house founded in March 2011. Our goal is to create rapid prototypes and give small-batch manufacture solution for makers and ... More »
More by ElecFreaks:Elecfreaks Motor:bit User GuideCreate an Electric Spirit LevelHC-08 Bluetooth UART Communication Module V2.4 User Guide
Add instructable to:
