H&C Robot Introduction
Published
Introduction: H&C Robot Introduction
This is a car robot that was made and designed by me and Hannah. It is very simple but fun to make, probably only takes you thirty minutes to make the most basic one, but once you made the simplest one, you can easily figure out the way to advance your current car. Let's do it!
First of all, follow this picture and be ready to put all the parts together!
Step 1: Step 1
Put one long beam right the bottom, and build a two beams on the top of it (make sure all the holes are upward). Connect them to the the double side connectors (put more single connectors in if necessary), then connect a single one horizontally in front of the bean that you just built. Nice work!
Step 2: Step 2
Connect the battery with symmetrical beams to build the bottom structure of the car. Yay, almost see the car...
Step 3:
Connect the bottom of the car with the engines sides by using beams and single connectors, then adjust your wheel and find the best wheel for you. Great done! We did it!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
