HC-SR04 Based Door Unlock Detection System
1,991
41
Posted
Introduction: HC-SR04 Based Door Unlock Detection System
Lately I have replaced my smoke alarm, the buzzer still operates (at least it makes enough noise even though there is no smoke… haha). I decided to adapted it so it can be a door opening detector. Well it could be a cheap alternative to all the expensive door opening alarm system on the market... you can change the buzzer with a regular one, the architecture and the program will stay the same, even though the one i used is noisy enough to make any intruder changed his mind. Using an Ultrasonic Ranging Module HC-R04 I was able to detect the presence of the door doorknob.
Step 1: What You Will Need...
To build this project you need:
  • An Arduino UNO or compatible.
  • 1 buzzer in my case i have used a smoke alarm buzzer.
  • Ultrasonic Ranging Module HC-SR04
  • A mini breadboard.
  • Some male to male jumper wires
Step 2: Preparing the Buzzer...
I removed the battery of the smoke detector and replace it with DIY 9 volt battery connector, attached to two male jumper wires, as shown in the picture
Warning: some of the smoke alarm contains radioactive material such as the AMERICIUM 241. Precaution is needed when manipulating them.
Step 3: Connecting the HC-SR04
the HC-SR04 connection is given in the pictures above.
Step 4: Programming the Arduino
Past the following program into your Android software, and transfer it to your Arduino UNO
HC-SR04 Ping distance sensor:
VCC to arduino 5v
GND to arduino GND
Echo to Arduino pin 7
Trig to Arduino pin 8
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define BuzzerPin 13 // Onboard LED, Buzzer
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
int secumaximumRange = 10; // secure Maximum range needed
int secminimumRange = 0; // secure Minimum range needed
long duration, distance; // Duration used to calculate distance
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
void loop() {
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
if (distance >= maximumRange || distance <= minimumRange){
/* Send a negative number to computer using Serial protocol.*/
Serial.println("-1");
else {
/* Send the distance to the computer using Serial protocol. */
Serial.println(distance);
if (distance >= secumaximumRange || distance <= secminimumRange){
digitalWrite(BuzzerPin, HIGH);
else {
digitalWrite(BuzzerPin, LOW);
//Delay 50ms before next reading.
delay(50);
Step 5: Installing the HC-SR04 Module
Place the HC-SR04 near your doorknob, it should measure a distance lower than 10cm, this distance can be read in the serial monitor of the Arduino software. you can change this distance in the program if you need to.
Step 6: Testing...
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
