HC05 Bluetooth Module Voltage Divider
6,484
7
Posted
Introduction: HC05 Bluetooth Module Voltage Divider
Recently I borrowed a Bluetooth module from my friend, because I had misplaced mine. I noticed that the Bluetooth module had no breakout board. So I read though the data sheets and found that this was a HC05 and it ran on 3.3v logic. But the Arduino TX pin runs on 5v signal, so all you needed to do is build a breakout board for it here is how you do that.
So lets get started...
Step 1: Tools and Components
So you will be needing a
Soldering skills are required for this instructable, you can learn to solder via a wide rang of tutorials on YouTube.
Step 2: Circuit
The circuit is quite simple all you have to do is create a voltage divider using a resistor combination the required output is 3.3v. Assemble he circuit on a pref-board. Try out some test sketches in the examples section of the Arduino IDE to make sure you got it working.
Step 3: Finishing
Do not worry about the messy resistors on my board. Some of it are to power on the led and some of it is to run terminal commands. You may rarely need to use those and if you do you can PM me and I will mail you the circuit on how to do that.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
how did you calculate the values of the resistances to reduce the voltage from 5 volts to 3.3 volts? I understand how to calculate using the voltage divider principle from circuits but it requires you know the resistance of the blue tooth module and the resistance of the resistor you want to use. Where can I find the data sheet for the bluetooth module you used? Difficult to find on google.
Mail me the full diagram.
