3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HD44780 LCD to I2C adapter board for the Bus Pirate
Cheap character LCDs based on the HD44780 chipset come in a variety of sizes: 2x16, 4x20, etc. These displays have two standard interface modes, 4bit and 8bit parallel. 8bit requires a total of 11 data lines, 4bit requires 7 (6 for write-only). Some LCDs support an additional serial data mode, like the VFD I covered at Hack a Day.
HD44780 LCDs are generally 5volt parts with a separate supply for the back light. The Bus Pirate only has five 5volt tolerant I/O pins, so we made a small adapter board with enough pins to control the LCD. The Bus Pirate controls the adapter board through its LCD interface library.
Continue reading about the Bus Pirate HD44780 character LCD adapter board and interface library.
I can have PCBs, kits, or assembled kits produced by Seeed Studio for about $15, including worldwide shipping, more here.
I couldn't include some formatting elements and HTML tables in an Instructable, you can see the original post at the Dangerous Prototypes blog.
Step 1Hardware
Hardware
Overview
In this article we outline an I2C adapter board for HD44780-based LCDs. We demonstrate it with a Bus Pirate universal serial interface. The Bus Pirate source code for the I2C-based HD44780 interface library is public domain, so it's free to adapt to your own projects.
Hardware
Full size circuit image [PNG]. The circuit and PCB were designed with the free version of Cadsoft Eagle. The design files can be downloaded from the Bus Pirate SVN. Before using the adapter board, be sure to verify the datasheet for your LCD against the adapter pinout. Not all LCDs are the same.
PCF8574 I/O expander IC
This is a simple 8 I/O expander chip that's controlled through the two-wire I2C interface. The I2C interface is accessible from header JP1.
The PCF8574 works from 2.5 to 5volts. The I/O pins operate at the supply voltage, so if we feed it 5volts it interfaces the LCD at 5volts. C1 (0.1uF) decouples the IC from fluctuations in the power supply.
One pin of the PCF8574 controls a 3mm LED (LED1) through current limiting resistor R2 (1000 ohms). The LED lights to indicate successful communication between the Bus Pirate and the adapter. The PCF8574 can't source enough current to power the LED, so we power the LED from the 5volt supply and switch the ground.
LCD
The adapter board communicates with an HD44780-based character LCD in 4bit parallel interface mode. The 4bit interface pins - RS, RW, EN, and D4-D7 - are connected to seven of the PCF8574 I/O pins. We like to use 0.1" male pin header to connect the adapter to an LCD, you can usually lean the LCD against the pins to create sufficient contact for a quick test.
Trimmer resistor R1 (10K) provides a contrast adjustment voltage to pin 3 of the LCD header.
We didn't connect the backlight pins because there's so many different backlight styles. Providing power for an LED backlight might damage a screen that requires a negative voltage supply.
Power supply
Most LCDs require 5volts, provide an external power supply through header JP2. We provided a second power supply pin to connect the Bus Pirate's pull-up resistors.
PCB
The circuit and PCB were designed with the free version of Cadsoft Eagle. The design files can be downloaded from the Bus Pirate SVN. The PCB is a single-sided, all through-hole design with a single jumper wire (shown in red).
We can have PCBs, kits, or assembled kits produced by Seeed Studio for about $15, including worldwide shipping, more here.
Partlist
Part
Value (all through-hole)
C1
0.1uF/10volts+
R1
10000 (10K) ohm single turn trimmer/potentiometer, 6mm
R2
1000 (1K) ohm resistor, 1/4 watt
LED1
3mm (T1) LED, red
JP1+JP2
0.1" male header, 5 pins
IC1
PCF8574N, 8bit I2C I/O expander DIP16
ICS1
16 pin DIP socket for IC1
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
128
Author:ian(DangerousPrototypes.com)
